My homemade 5200 controller
228 replies to this topic
#226 eegt97 OFFLINE
eegt97
    Moonsweeper
  • 305 posts
Posted Sat Mar 16, 2019 12:12 PM
 Hi, can you share a pic of your cable modification? thanks.
Sure, nothing complicated, just going around the 4 sides with a cut off wheel and don't take out the pins.  Let's just say it's not my most accurate hack job, but it works  :)
#227 amiman99 OFFLINE
amiman99
  • 1,261 posts
Posted Sat Mar 16, 2019 10:10 PM
Hi amiman99, I sent you a PM, thanks.
Replied
#228 DrVenkman OFFLINE
DrVenkman
  • 4,085 posts
  • Back off, man! I'm a scientist.
Posted Sun Mar 17, 2019 11:00 AM
I've actually thought about using "hot snot" (e.g., a bead of hot glue) around the outer edge of the controller connector jack and then inserting the Console5 extension and seeing if it holds it more securely.
Edited by DrVenkman, Sun Mar 17, 2019 11:01 AM.
#229 eegt97 OFFLINE
eegt97
    Moonsweeper
  • 305 posts
Posted Sun Mar 17, 2019 1:58 PM
Something like that would have probably solved the intermittent issue with the pots I was having before cutting, but I had another issue with the #,0,* key row.  That was constant, and I finally realized that the common pin for this row was ever so slightly recessed even more than the others in the extension cable.  Then I cut the shell, and everything worked and is secure, no issues.  I wished I had done that from the beginning, probably would have saved some unnecessary solder re-flow. ;-)
BTW, I have already damaged the thumbstick.  It gets stuck down sometimes and doesn't come back to center.  I wonder if without a case I move it more than it is really meant to move.  At any rate, I'm going to see if I can find something a little more robust to replace with.
-Brian
