Current: The Missing Manual
10 replies to this topic
#1 massiverobot OFFLINE
massiverobot
    Star Raider
  • 98 posts
Posted Mon Aug 6, 2018 9:04 PM
Starting a new thread to have a top post here with always-current URLs for the Missing Manual for the U1MB/1088XEL. I'm also creating a ePub doc version of it as well.
The most current versions should always be available at these URLs:
PDF:
https://www.dropbox....urrent.pdf?dl=0
ePUB:
https://www.dropbox....rrent.epub?dl=0
Please post any comments, suggestions, corrections or gripes below and I'll add them to the document if they will make it better!
This document should help anyone who knows about classic A8 devices but is just getting back into the modern scene and had purchased or aquired a 1088XEL or U1MB and wants to effectively use them.
#2 flashjazzcat OFFLINE
flashjazzcat
  • 14,165 posts
Posted Tue Aug 7, 2018 4:28 AM
I'm not sure what specific relevance MrAtari, MYIDE-II or MYBIOS have to the 1088XEL project at all. No offence to either, of course, but MYBIOS is not part of the 1088XEL firmware. One may flash any OS to the U1MB OS slots, of course (MYBIOS included), but to acknowledge them all (Q-Meg, for example, which is supplied in one of the default OS slots) would be a lengthy and pointless exercise. Likewise one may plug in an Ultimate Cart, UNO Cart, etc, all of which are equally useful.
The stuff about 32MB partitions still requires correction; as I wrote previously, only the available filesystem imposes any limitation on size (aside from the limitation imposed by 28-bit LBA addressing). So really it would be appropriate to say that most available file systems - owing to 16-bit cluster addressing - are limited to 16MB partitions, while SDX can address 32MB partitions by virtue of the fact that it's the only currently available DOS capable of using 512 byte sectors. Using FATFS.SYS, even that limitation is removed (since clusters may typically be 4KB in size).
Likewise the 15 drive limit is really a software limitation. If SpartaDOS X - for example - chose to use more than four bits for the device ID, we could have 26 or 100 or 256 hard disk partitions mounted and addressable simultaneously.
The other salient point - which may already have been observed - is that SDX is not a requirement for the use of FDISK, etc. Most of the APT tools may be used with MYDOS, etc, if the user so desires.
Edited by flashjazzcat, Tue Aug 7, 2018 4:49 AM.
#3 massiverobot OFFLINE
massiverobot
    Star Raider
  • 98 posts
Posted Tue Aug 7, 2018 1:16 PM
You are correct- I'm going to re-organize the manual to have 1088XEL / U1MB sections and then a misc part at the end. I have just been collecting so much information about these add-ons and HD projects that I may have gotten carried away.
I realize that the limitations are not due to your FW, I want to keep the Manual on a level that will allow quick reading and understanding without getting too deep into the weeds- I want to direct people back to your more comprehensive manuals for that level of technical explanation.
#4 massiverobot OFFLINE
massiverobot
    Star Raider
  • 98 posts
Posted Tue Aug 7, 2018 8:44 PM
Posted revision G.
Change Notes:
1.0g - Updated People diagram, Altirra BIOS screenshots, new section Copying, new section customizing startup, new section advanced setup, lots of minor edits
#5 massiverobot OFFLINE
massiverobot
    Star Raider
  • 98 posts
Posted Thu Aug 9, 2018 7:42 PM
Posted revision H.
1.0h -     Updated and finished sections, added new sections COL64, Dir Dirs LS and numerous edits.
Lots more screenshots and I'm having a blast examinging all the goodies that come on the SDX toolkit disk.
#6 massiverobot OFFLINE
massiverobot
    Star Raider
  • 98 posts
Posted Sat Aug 25, 2018 8:55 AM
Latest updates on dropbox.
1.0i 8/25 -     Added new 800 system and funct diagrams (re-created from Atari Ref Manual), new acros, UAV info from AA, lots of minor edits and fixes.
#7 mytek OFFLINE
mytek
  • 3,142 posts
Posted Sat Aug 25, 2018 9:40 AM
Looking better all the time  :thumbsup:. just one minor thing... on page 6 it goes into a lot of detail about the SIDE2 cartridge which is good background info, but would not be something you would normally use in the 1088XEL with a CF3 upgrade. The CF3 takes over all of this functionality, and precludes the use of the SIDE2 Cart (it's a one or the other situation). Not to say you couldn't still use a SIDE2 Cart, but it would require a different PBI Bios and Loader to do so in place of the custom XEL-CF3 ones that are part of the 1088XEL/U1MB specific Bios. So maybe a note to explain this would be good to add.
#8 massiverobot OFFLINE
massiverobot
    Star Raider
  • 98 posts
Posted Sat Aug 25, 2018 9:48 AM
Fair point- that is left over from when I was very overwhelmed and grabbing lots of different pieces of tech and lumping them all in the doc. Since the SIDE also runs a similar FW from FJC it ended up in there. I will catagorize pieces that are part (and not part) of the 1008XEL ecosystem in a more clear format.
Thanks for the feedback, I'm willing to listen to anything as it will make the document better and clearer for people just coming into the scene. As you probally know after you read your own words many many times you tend to glaze over parts that are obvious to fresh readers.
#9 massiverobot OFFLINE
massiverobot
    Star Raider
  • 98 posts
Posted Sun Sep 23, 2018 11:10 AM
Updated and released version k.
1.0k 9/23 -    Added Go Code, On-Line section. Minor Edits
#10 mytek OFFLINE
mytek
  • 3,142 posts
Posted Mon Sep 24, 2018 11:03 AM
Looking good  :thumbsup:  :) .
Since we now know that Lotharek is producing the U1MB with vertical headers, you might want to update the image you use in your manual that refers to it.
#11 MacRorie OFFLINE
MacRorie
    Dragonstomper
  • 992 posts
  • No matter where you go, there you are.
Posted Fri Oct 5, 2018 11:52 PM
Just out of curiosity, has anyone tried those on a 1088 build yet?
