Horizon Ram Disk
35 replies to this topic
#1 BeeryMiller OFFLINE
BeeryMiller
    Dragonstomper
  • 752 posts
Posted Wed Aug 8, 2018 8:03 AM
I heard someone that had the rights was considering the production of new Horizon Ramdisks.  Will this become a reality?
Beery
#2 atrax27407 OFFLINE
atrax27407
  • 1,177 posts
Posted Wed Aug 8, 2018 8:44 AM
Ask Jim Fetzner - it is his project.
#3 Ksarul OFFLINE
Ksarul
  • 5,021 posts
Posted Thu Aug 9, 2018 4:15 AM
It is on my list. I have been slowly building a layout for it, but it has been slow going between work, health, and family obligations this past year or so.
#4 Gary from OPA OFFLINE
Gary from OPA
    Moonsweeper
  • 417 posts
Posted Sat Aug 11, 2018 3:02 PM
More than willing to help out with project, DSR and other info.
#5 RickyDean OFFLINE
RickyDean
  • 1,020 posts
Posted Mon Aug 13, 2018 6:03 AM
Gary, not wanting to take this off topic, but just a quick question. Is there any hope of getting TIM again, or the ability to have the source code for son of a board? Thanks.
#6 arcadeshopper OFFLINE
arcadeshopper
  • 4,054 posts
Posted Tue Aug 14, 2018 8:41 AM
This..
  • RXB likes this
#7 RXB OFFLINE
RXB
  • 3,457 posts
Posted Tue Aug 14, 2018 4:29 PM
OMG I loved the TIM and SOB combo. Also SAMS and SCSI hard drives was how I did most of my work in 80 columns using that 128 of VDP for single DV80 files.
Going back to insane number of small chained DV80 files was like  passing stones thru my pee hole. Slow and painful.
My gawd trying to remember which file of 12 had my routine to fix was just so hard vs one single file with search keyword.
#8 BeeryMiller OFFLINE
BeeryMiller
    Dragonstomper
  • 752 posts
Posted Mon Aug 27, 2018 5:02 PM
I picked up a Horizon Ramdisk with V8.34 of the ROS. It has the Rambo modification to the card.  Does anyone have the complete ROS?  I have unable to find it in my collection nor anything on whtech.
Beery
#9 peterfleeman OFFLINE
peterfleeman
    Space Invader
  • 29 posts
Posted Mon Aug 27, 2018 5:06 PM
Im not sure if this is what you mean, but this is what Ive been using to load 8.34 onto the cards Ive been selling.
http://atariage.com/...ttach_id=465843
#10 BeeryMiller OFFLINE
BeeryMiller
    Dragonstomper
  • 752 posts
Posted Mon Aug 27, 2018 5:33 PM
What I am looking for is John Johnson's 40 column Menu program that works with this version of ROS 8.34.  It wasn't part of the package, and yes, I got the card and it is working well.
Beery
#11 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,315 posts
Posted Mon Aug 27, 2018 6:33 PM
Beery, MENU v7.39 is probably what you want. It is encoded to work with ROS 8.  This is one reason I did not push the ROS version beyond 8; it would break other programs.
There is a 40 column BOOT that might also work with the Horizon; I have not tested it in that manner.  Supposedly it catalogs based on the level 3 IO, which would work well with TIPI.
#12 atrax27407 OFFLINE
atrax27407
  • 1,177 posts
Posted Mon Aug 27, 2018 7:09 PM
Isn't ROS 8.38 the latest release?
#13 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,315 posts
Posted Mon Aug 27, 2018 7:43 PM
It was only released to a handful of people for test purposes.   8.34 is the latest public release.
#14 BeeryMiller OFFLINE
BeeryMiller
    Dragonstomper
  • 752 posts
Posted Mon Aug 27, 2018 10:04 PM
I did not find V7.39, but I did find V7.3.  I installed it on the Ramdisk, and the Menu program that came with it works.  I can load TIPI.NET.TELNET from the Horizon menu option.
If there is a complete V8.3 or higher version available for release, let me know where.  Otherwise, I guess V7.3 is it for  me.
Beery
#15 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,315 posts
Posted Mon Aug 27, 2018 10:20 PM
Here's the current lay of the land:
ROS/CFG 8.14F, latest released by Bud/OPA.  This is the most familiar, stable release.
ROS/CFG 8.34, latest version I've released.  Based on reconciled source code for 8.12/8.14F. Fixes and capacity increase are the most notable changes.
MENU - 7.39 is the last formal release by JJ.  Hit Fctn-8 or V, I think that shows you the version in MENU.
BOOT - various versions in 40 and 80 columns
9640 menu - variant of the Geneve menu people used with GPL.  Standalone and updated to work with the F18A and V9938.
#16 BeeryMiller OFFLINE
BeeryMiller
    Dragonstomper
  • 752 posts
Posted Tue Aug 28, 2018 6:52 AM
The MENU that was in the 7.3 archive gave a version mismatch with the 8.34 ROS.
I'll look on Heatwave and see if by chance you had it on your BBS.
Beery
#17 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,315 posts
Posted Tue Aug 28, 2018 6:10 PM
Beery
I am fairly certain MENU 7.39 is included with the ROS 8.14F release disk.  The disk image should be on WHT in one or more folders.
#18 apersson850 OFFLINE
apersson850
    Dragonstomper
  • 534 posts
Posted Fri Sep 7, 2018 2:26 AM
I found out that the latest drivers for the Horizon RAMdisk don't work with the p-code card. Earlier did, but in the last versions, some clever tricks have been applied in the DSR, to save memory and/or speed things up. These tricks rely on specific behavior (memory usage) in the console's DSRLNK routine, things that aren't in the DSR interface specification. The p-code card does follow the specification, but implements it in a different way, so bypassing that specification fails.
Very good example of why one should avoid shortcuts in the interface between different software modules.
It is the ROS that fails. I wrote my own ROS, an extremely basic one, only allowing sector access, but in the specified way. Then it works with the p-system. So it's not the card hardware or similar that fails.
#19 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,315 posts
Posted Fri Sep 7, 2018 3:24 AM
You have made similar statements in other topics.   Incompatibility with the p-code card does not mean the ROS is the problem.
Can you share more specifics about these tricks and shortcuts, and the specification failings?
#20 BeeryMiller OFFLINE
BeeryMiller
    Dragonstomper
  • 752 posts
Posted Fri Sep 7, 2018 5:32 AM
Tim,
I downloaded last night the ROS814FARC file from Heatwave.  The archive would not unarchive completely.
I was going to update the 7.xx version I had to the 8.14 as I saw an issue with MDM5 and the 7.xx version.  After running MDM5 run the MENU program of 7.xx, MDM5 could no longer access floppy drives.  Was hoping this was fixed in the 8.xx version as I saw notes in the README file indicating some fixes with the HFDC.
If anyone is aware of another location where the ROS814 (or higher) can be obtained, please let me know.
Beery
#21 Shift838 OFFLINE
Shift838
  • 2,461 posts
  • SHIFT838
Posted Fri Sep 7, 2018 7:36 AM
Tim,
Beery
Here is 814F
#22 BeeryMiller OFFLINE
BeeryMiller
    Dragonstomper
  • 752 posts
Posted Fri Sep 7, 2018 8:33 AM
Thanks.
#23 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,315 posts
Posted Wed Sep 12, 2018 6:58 PM
Tim,
Are you referring to the MENU or ROS?  If it is a ROS issue and we can pinpoint the cause, I can incorporate a fix.
I am slowly getting some things back in order. Of course, seeing as how it took me 20 years to finish one of my utility programs recently, I won't make any promises ;)
Heatwave has some DF128 archive files that wreak havoc with file transfers.  For BBS purposes, the better option is "always" to use the compressed (IF128) option.  It has been 7 years since some of those files were uploaded so there is the chance a few could have succumbed to bit rot.  Or, the file was corrupt all along and you are the first to encounter.
#24 BeeryMiller OFFLINE
BeeryMiller
    Dragonstomper
  • 752 posts
Posted Thu Sep 13, 2018 5:24 AM
I am going to have to do a bit more research on this as I am getting some odd behavior.  There may be a cabling issue in play as I have had the PEBox open and tried to pull one floppy out of the system so I could put the DREM in the bay besided the other floppy.
Between adding the TIPI, a HRD, and then the DREM, there has been a lot going on with that system.
Beery
#25 --- Ω --- OFFLINE
--- Ω ---
    Sunbaenim
  • 13,474 posts
Posted Thu Sep 13, 2018 8:24 AM
Beery, I'm curious what is the advantage of having a HRD if you also run a TIPI?  Is it just being used to an old software program or is is there something else I'm missing?
