Fixed numbers in intybasic v1.2.9
intybasic
4 replies to this topic
#1 artrag OFFLINE
artrag
  • 1,212 posts
Posted Fri Aug 10, 2018 8:12 AM
Apart the bug spotted elsewhere that leads this kind of expressions  #ex(0) = -1.0+.#ex(0) to fail, it seems that it is missing a proper support to multiplications/divisions.
I was trying to multiply a fixed point number by a constant, but due to the fact that the fractional part in in the high byte, normal multiplication fails...
Is there a dedicated multiplication for 8.8 fixed point numbers ? BTW what is the reason for this inversion (high/low byte)?
Am I missing something or the support for fixed point numbers is just immature in v1.2.9 ?
#2 DZ-Jay OFFLINE
DZ-Jay
  • 12,031 posts
  • The P-Machinery AGE is almost here!
Posted Fri Aug 10, 2018 9:32 AM
Perhaps the multiplication by constant uses the macro Joe Z. and I worked on which assumed 16-bit integers.
#3 nanochess OFFLINE
nanochess
    Processorus Polyglotus
  • 5,793 posts
  • Coding something good
Posted Fri Aug 10, 2018 12:39 PM
I'm afraid I forgot completely about the fixed point number support in IntyBASIC.
Supposedly it would have helped to integrate fractions to ease writing of Asteroids-like game but the support come with far too many bugs because it was too early.
#4 artrag OFFLINE
artrag
  • 1,212 posts
Posted Fri Aug 10, 2018 1:21 PM
Well, once you fix addition and subtraction by constants, product of two 8.8 numbers is just a 32 bit multiplication where you keep the upper 16 bits as result.
You need
But, why the up/down bytes inversion? Does it help somehow?
Edited by artrag, Fri Aug 10, 2018 1:51 PM.
#5 artrag OFFLINE
artrag
  • 1,212 posts
Posted Fri Aug 10, 2018 2:59 PM
Actually if you keep the same convention used for usual integers you should end up with this
*. = * on 32 bits >>16
Also tagged with one or more of these keywords: intybasic
