Altirra 3.10 released
altirra emulation
655 replies to this topic
#76 mr-atari OFFLINE
mr-atari
    Dragonstomper
  • 587 posts
Posted Tue Aug 28, 2018 11:55 PM
Hi Avery,
http://atariage.com/...ased/?p=4097311
Perhaps you missed my second reply/remark.
When I start-up altirra its 7F, but later, when I use shift+F5 its FF
Grtz,
Sijmen.
Works for me.
Note that FDC status bit 7 is not universal for all drives. It is only valid for drives with certain floppy drive controllers and which have a drive latch hooked up, i.e. 1050 derivatives. 810 and XF551 drives do not.
#77 NSonic OFFLINE
NSonic
    Combat Commando
  • 4 posts
Posted Fri Aug 31, 2018 6:23 PM
Hello Phaeron
Can you add the cassette loading option called Injektor? For you to understand me better, look at this pair of videos.
#78 Mclaneinc ONLINE
Mclaneinc
    Retro Madman
  • 6,718 posts
Posted Fri Aug 31, 2018 6:31 PM
Avery has looked in to this but there were problems, I don't know if any progress has happened apart from a unit has been recreated in the real world by others....
Just for info....
http://atariage.com/...-7#entry3838999
#79 NSonic OFFLINE
NSonic
    Combat Commando
  • 4 posts
Posted Sat Sep 1, 2018 7:47 PM
Just for info....
Thanks for that information. Now it is possible to add to the Altirra emulator the option to load games from real cassette? As does the ZXspin emulator?
Edited by NSonic, Sat Sep 1, 2018 7:47 PM.
#80 Mclaneinc ONLINE
Mclaneinc
    Retro Madman
  • 6,718 posts
Posted Sun Sep 2, 2018 3:56 AM
Firstly neither I or anyone bar Avery can answer for him so who knows what options will be added to Altirra but although Avery has added far more tape items to Altirra than seemed likely I personally would doubt that being added. The reason I mainly think so is that Avery has went out of his way to add various emulated ways to load tapes as digital images, I doubt he would like to move it in to the real world considering his comments in the past regarding tape usage..
I don't even know if there's an interface to allow tapes directly from an Atari cassette unit to attach to any emulator or sampling software actually out there....If there is then great..Not really my sort of thing
Also from what little technical knowledge I have I would imagine syncing all this up to a complex (unit based?) emulation engine would not be very fun and take a lot of time and break stuff on the way..
Best advice, don't hold your breath waiting for such things...If Avery is / was interested he would most likely say..
#81 256 colors OFFLINE
256 colors
    Moonsweeper
  • 302 posts
Posted Thu Sep 6, 2018 12:50 AM
Any chance of Multi Joy 16 and a net-play feature in a future release at some point please :-D
Edited by 256 colors, Thu Sep 6, 2018 12:50 AM.
#82 baktra OFFLINE
baktra
    Dragonstomper
  • 657 posts
Posted Thu Sep 6, 2018 5:39 AM
The INJEKTOR loader would be tough.
If it is to be ever implemented, we would need at least full schematic of the INJEKTOR circuit, or very detailed explanation on how it works. Altirra would have to emulate the extra circuitry in the data recorder that comes with INJEKTOR.
A video of the loader is not enough. From what I have seen at atariware.cl, even enhancements of the POKEY and PIA emulation might be needed.
#83 Mclaneinc ONLINE
Mclaneinc
    Retro Madman
  • 6,718 posts
Posted Thu Sep 6, 2018 5:47 AM
I know Avery likes a challenge but that's a big ask to do all that  just (and I know you love your tapes Baktra) for a tape loader that isn't overly known..
At least Avery has a more detail source to look at thanks to you..I think the original request maker confuses (and its so easy to do so no gripes at him) with soldering a few wires and adjusting the code of an emulator even its its all module based..
BUT, Avery is known for throwing a huge curve ball on what you are least expecting so who knows, only him...
Paul..
#84 phaeron OFFLINE
phaeron
  • 2,781 posts
Posted Sat Sep 15, 2018 8:08 PM
http://www.virtualdu...-3.20-test2.zip
http://www.virtualdu...0-test2-src.zip
  • Breaking change: Debugger scripts (*.atdbg) are no longer automatically loaded for images unless the debugger is enabled (/debug or via menu).
  • /portabletemp runs off an INI file but doesn't save any changes back to it, for testing.
  • Added support for ATX physical sector size tagging.
  • Fixed disk Not Ready status bit updating inconsistently in some cases.
  • Rotational delays are skipped for disk drives that have a ready signal -- 1050 emulated modes no longer have long delays reading from uninserted disks.
  • Fixed Not Ready being signaled for drives that don't support it (810).
  • Optimizations to ANTIC emulation and NTSC standard artifacting.
  • @(...) in debugger expressions evaluates the subexpression immediately. Example: bx pc=@(pc+100)
  • The .diskdumpsec debugger command now shows all physical sectors associated with the given virtual (logical) sector.
  • Added 'widescreen' overscan mode for the horizontal area commonly shown by modern widescreen LCDs. The visible area is 176 color clocks.
  • Added setting for scanline intensity.
  • Added intensity scale setting.
The intensity scale setting allows the entire display image to be easily scaled up or down without adjusting the rest of the controls. This could be done previously but required moving several controls in sync. The reason for this is to make it easier to darken the image produced by the emulator and turn up the physical monitor brightness for better color reproduction. This is especially useful when trying to match the colors from an 800, which naturally produces a dimmer and highly saturated image. Without this adjustment, the colors are warped due to hitting the limits of RGB space:
Turn the image down to 66%, and the purple turns to blue:
With regard to some requests:
  • Netplay: Sorry, not currently interested. Networking code is a hassle and multiplayer has a lot of real-time synchronization problems that I'm not wanting to deal with right now.
  • Injektor: Not enough information about the hardware. The difficulty is that there is no schematic for the hardware and it is somehow able to read both FSK and Manchester encoding without having a signal from the computer to switch.
  • Live tape: Sorry, pass. Pre-recording the audio is a much better idea, and on top of that the Atari is able to stop and start the tape by computer control, which the emulator would not be able to do with a tape player connected to line-in. The emulator does support loading WAV files directly as tapes.
#85 Mclaneinc ONLINE
Mclaneinc
    Retro Madman
  • 6,718 posts
Posted Sun Sep 16, 2018 4:25 AM
The intensity is a brill addition...Well it all is but being honest I probably would not spot what the other things are doing bar maybe the artifacting....Top update..(as always)..
Thank you...From all that love Altirra...
Paul..
Edited by Mclaneinc, Sun Sep 16, 2018 4:26 AM.
#86 Docwiz OFFLINE
Docwiz
    Space Invader
  • 38 posts
Posted Sun Sep 16, 2018 5:29 AM
What about Atari 8-bit Printer Support to PDF?  So, you can take the input of different types of native Atari printers and others such as Dot Matrix and print them on to PDF files so we can print them out on today's printers.  Also output of ATASCI would be awesome too for dot matrix printers and other printers with graphic support.
Edited by Docwiz, Sun Sep 16, 2018 5:30 AM.
#87 serj OFFLINE
serj
    Chopper Commander
  • 213 posts
Posted Sun Sep 16, 2018 8:59 AM
thanks Avery.
I've been waiting for this for a long time.
#88 Kyle22 OFFLINE
Kyle22
  • 4,098 posts
  • broadway1.lorexddns.net 10001
Posted Sun Sep 16, 2018 9:24 PM
Any chance for 1400XL V: PBI ROM and emulation of the Votrax SC-01A chip?
#89 danielcg OFFLINE
danielcg
    Space Invader
  • 44 posts
Posted Sun Sep 16, 2018 11:50 PM
Scanline intensity is one I wanted for Altirra and I waited for very long time for this feature! Stella already have adjustable scanline intensity. Thank you!
#90 Nezgar OFFLINE
Nezgar
  • 1,976 posts
Posted Mon Sep 17, 2018 5:29 PM
Might as well take the 1400XL T: along with it - a buffered PBI serial handler that doesn't lock out the SIO bus could be interesting to explore...
#91 mr-atari OFFLINE
mr-atari
    Dragonstomper
  • 587 posts
Posted Mon Sep 17, 2018 11:52 PM
Like this ? :-)
#92 Mclaneinc ONLINE
Mclaneinc
    Retro Madman
  • 6,718 posts
Posted Tue Sep 18, 2018 4:58 AM
Mr Fish, was that a potato you film ed it with :)
If I know you it was an Atari doing the capture...
Sounded great....Not sure what bootleg VHS film I was watching tho :)
#93 flashjazzcat ONLINE
flashjazzcat
  • 14,613 posts
Posted Wed Sep 19, 2018 11:38 AM
Is there any possibility of wrapping the memory window back to $0000 in 6502 mode? The segment numbers knock the alignment out:
In 65C816 mode, perhaps the base segment could be labelled 00 to keep things lined up? Hardly a big deal, anyway, but something I just noticed with a recent test build.
#94 Atari_Force OFFLINE
Atari_Force
    Space Invader
  • 34 posts
Posted Tue Sep 25, 2018 1:52 PM
Thanks for the new release.
About Injektor, it looks complicated. Meanwhile, Is it too much to ask to add fsk mark writing in a8cas format (simple recording)?
#95 morelenmir OFFLINE
morelenmir
  • 1,544 posts
Posted Fri Sep 28, 2018 4:20 PM
is Altirra BASIC v1.44 still the newest? For some reason I can never find the latest release whenever I check for a new one, although I am absolutely sure it is staring me in the face!!!
#96 CharlieChaplin OFFLINE
CharlieChaplin
  • 3,134 posts
Posted Fri Sep 28, 2018 4:25 PM
The latest version of Altirra Basic I have is V1.55 - though I would not be surprised if there are already newer versions...
#97 Keatah OFFLINE
Keatah
    Missile Commander
  • 22,194 posts
Posted Fri Sep 28, 2018 4:44 PM
You can use Tools> Export ROM Set> to get the Altirra BASIC Rom. Then you can drag and drop it to the Altirra window to boot it. When the emulated machine starts it will show the version and drop you into BASIC.
You can also configure the emulated system to start straight away into BASIC - using either an external ROM or the built-in Altirra BASIC.
#98 morelenmir OFFLINE
morelenmir
  • 1,544 posts
Posted Fri Sep 28, 2018 5:19 PM
and
Many thanks indeed guys!!!  It looks like I need to update my U1MB!
In regards getting at the Altirra BASIC ROM, that is pretty much what I was wondering. I have been away from the A8 so long, especially as emulated that I am a bit out of touch. Exporting the ROM image seems like a way to reliably get hold of the newest whenever a new iteration Altirra appears. I guess Phaeron no longer offers it as a separate file from the get go?
#99 rdea6 OFFLINE
rdea6
  • 2,836 posts
Posted Fri Sep 28, 2018 5:21 PM
The additions.atr shipped with the test versions has the executable file.  Just load the atr and copy to where ever you want to store it..
#100 DrVenkman OFFLINE
DrVenkman
  • 4,089 posts
  • Back off, man! I'm a scientist.
Posted Fri Sep 28, 2018 5:27 PM
Huh. I have v. 1.51 flashed to my U1MB. I need to get hold of the newer version from the Additions disk or something. :)
Also tagged with one or more of these keywords: altirra, emulation
3 user(s) are browsing this forum
1 members, 2 guests, 0 anonymous users
