Atari 5200 Sophia RGB Mod
40 replies to this topic
#26 -^CrožBow^- OFFLINE
-^CrožBow^-
  • 7,184 posts
  • Collector of Fine Atari and Sega Antiquities!
Posted Mon Feb 4, 2019 10:06 PM
I will be joining you all soon too. I pried off my 5200's RF shield yesterday. What a pain in the backside. I also specifically picked up the RGB version as my projector doesn't seem to like either of the 2 common resolutions the DVI version of Sophia comes in.
Actually I'm still quite content with the s-video output I get from my 5200. Served me well and looked really good for a number of years now.
#27 john_q_atari OFFLINE
john_q_atari
    Chopper Commander
  • 172 posts
Posted Tue Feb 5, 2019 11:30 PM
What is the best way to tap the audio for the 5200 if I don't use the UAC? Should I use a 1uf cap, a 0.1uf cap, or a 10uf cap? and should I tap the resistor connection point (labeled R50 in his picture) as shown in Bryan's blog where he uses a yellow wire going to the UAC even if I don't  install a UAC for my mod?
#28 -^CrožBow^- OFFLINE
-^CrožBow^-
  • 7,184 posts
Posted Wed Feb 6, 2019 12:15 PM
Well there are number of ways to do this. But I've actually just been attaching a 10uf 16v cap (Because it will work fine and I've plenty of them on hand) from off of R50 like you mentioned. The UAC was doing further filtering through the UAC so basically the same as attaching a cap directly off of R50 and running that back out to the center of your RCA. Just make sure to attach the + lead of the cap from R50 with the negative lead going to the RCA jack.
Edited by -^CrožBow^-, Wed Feb 6, 2019 12:17 PM.
#29 leech OFFLINE
leech
  • 1,445 posts
Posted Wed Feb 6, 2019 1:20 PM
Not too sure you can correct the aspect with the OSSC. There might be ways to alter and squish the image back to looking like 4:3 and saving that as a profile. My TV actually has the option to still set a 4:3 aspect on digital inputs so I just have to switch that back and forth manually.
You mean like this? OSSC line multiplier 3x, gives the correct aspect ratio.
Edited by leech, Wed Feb 6, 2019 1:26 PM.
#30 Lan Di OFFLINE
Lan Di
    Space Invader
  • 13 posts
Posted Fri Feb 8, 2019 5:37 PM
Ceramic or electrolytic?
#31 -^CrožBow^- OFFLINE
-^CrožBow^-
  • 7,184 posts
Posted Fri Feb 8, 2019 6:06 PM
Electrolytic. Specifically I've got a small stock pile of Nichicon caps on hand I use for my audio runs.
#32 -^CrožBow^- OFFLINE
-^CrožBow^-
  • 7,184 posts
Posted Mon Feb 18, 2019 4:31 PM
Wanted to get back to this having worked on this very issue this weekend. You can just attached a 10uf 16v cap off of the top of R50. However, it will still be louder than heck so I would advise an additional 1k5 resistor or somewhere around that off of R50 to the + lead of your cap, and then - lead of the cap to the RCA jacks. It is still a tad too loud compared to my other consoles, but it doesn't seem to distort either.
#33 john_q_atari OFFLINE
john_q_atari
    Chopper Commander
  • 172 posts
Posted Mon Feb 18, 2019 4:46 PM
Hmm okay. I will check on my audio levels. I feed them into my receiver and just adjust the volume there. I finished adding in the sophia but I do seem to have a little noise or interference I think. Its not too bad but compared to a perfect DVI/hdmi image I think it is there. I will have to try a few carts and see if/when/how often it occurs. Originally I was just using the sophia ribbon cable (maybe I wouldn't have had noise then, but later I added 2 or 3 inches of wire between the ribbon cable and the mini din8 jack I was using.
#34 leech OFFLINE
leech
  • 1,445 posts
Posted Mon Feb 18, 2019 5:11 PM
Funny, I did what Rayik suggested (.1uf Ceramic Capacitor) and it's way quiet, but I found an audio boost setting in the OSSC so now it's a bit better without me having to crank up the sound just for the 5200.
#35 -^CrožBow^- OFFLINE
-^CrožBow^-
  • 7,184 posts
Posted Tue Feb 19, 2019 3:48 PM
Is that attached off the north end of R50? Because on my setup, everywhere I connected audio with just a cap for filtering additional DC out of it was way too loud and that was with my receiver on -60. Most of my systems are what I consider loud at -35 except the jaguar as that needs to be at like -10 LOL.
#36 leech OFFLINE
leech
  • 1,445 posts
Posted Fri Feb 22, 2019 12:19 AM
I installed mine the same as the earlier images in the thread. North side sort of depends on which way you are holding the board. With the power button closest to me it would be the south side.
#37 -^CrožBow^- OFFLINE
-^CrožBow^-
  • 7,184 posts
Posted Fri Feb 22, 2019 4:43 PM
Good point. In my case I use North as end towards the back of the case...South would be the end towards the front of the case. I might use a 2.2k on my next install to see if that brings the 5200 audio level in line with the rest of my consoles. I also can adjust the audio boost or descrease through the OSSC, but I'd rather not have to do that and create yet another profile to switch over to on the OSSC for the 5200.
#38 Lan Di OFFLINE
Lan Di
    Space Invader
  • 13 posts
Posted Sat Apr 20, 2019 11:07 PM
I finally got time to install the Sophia RGB board. However I'm getting extreme sync issues. I have it hooked up to a Sony PVM. I got the SCART cable from this website https://coolnoveltie...ophia&results=2 .
Any ideas how to fix this? I've included photos.
Edited by Lan Di, Sat Apr 20, 2019 11:09 PM.
#39 Lan Di OFFLINE
Lan Di
    Space Invader
  • 13 posts
Posted Sun Apr 21, 2019 2:30 AM
My 5200 just stopped reading carts. All I get is a black screen. Maybe a bad GTIA?  Maybe the bad sync was due dying chips? I'll keep working on it and I'll post my findings if I get this thing back to working again.
#40 Lan Di OFFLINE
Lan Di
    Space Invader
  • 13 posts
Posted Sat Apr 27, 2019 9:28 PM
OK, I just installed the Sophia on perfectly working 5200. I still have the sync problem. Could it because I'm using a SCART to BNC cable? I doubt it because all my other classic systems work fine on my PVM using SCART to BNC except for the 5200. Any advice?
#41 Lan Di OFFLINE
Lan Di
    Space Invader
  • 13 posts
Posted Tue Apr 30, 2019 4:51 AM
Update. It seems as if my PVM will only accept component mode from Sophia. Using component mode fixed everything! Everything works fine and the picture is awesome thanks to Simius.
