CX40Hero Posted August 17, 2018 Share Posted August 17, 2018 (edited) Hi all, I have an AV modded 6 switcher and ive just picked up one of these cheap little easycaps, has anyone used these to any sucsess? I'm using a modernish windows desktop and want to record some of my gameplay (for high score attempts etc) but don't fancy running Stella, I much prefer original (all be it slightly modded) hardware. Any advice re setup, best programs to run the device with, will be greatly appreciated Edited August 17, 2018 by CX40Hero Quote Link to comment Share on other sites More sharing options...
FireStar Posted August 18, 2018 Share Posted August 18, 2018 I can recommend using OBS studio or AmarecTV for capture, OBS is a bit more modern and will let you livestream if you're interested in that, whilst AmarecTV has a ton of options relevant to retro gaming, such as a bunch of deinterlacing options. Personally I use yadifx2 deinterlacing in OBS when recording consoles from composite. Also a word of warning on the easycap if you are using s-video, the s-video input may not actually be s-video but just s-video converted to composite, my particular easycap model does this. It's pretty easy to tell since it'll look like a mess. 1 Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted August 19, 2018 Share Posted August 19, 2018 OBS Studio works great for S-video and composite from my 1088XEL. It should work similarly great for my AV-modded 4-Switch Woody, though I've never actually tested it. 1 Quote Link to comment Share on other sites More sharing options...
CX40Hero Posted September 15, 2018 Author Share Posted September 15, 2018 I may have made this more difficult for myself, Windows has now been changed to Ubuntu 18.04 64 bit LTS.... Mainly because the hard drive died that was running Windows...... and I hated it.... Quote Link to comment Share on other sites More sharing options...
CX40Hero Posted September 15, 2018 Author Share Posted September 15, 2018 https://youtu.be/g-VzDspB5CU Quote Link to comment Share on other sites More sharing options...
CX40Hero Posted September 19, 2018 Author Share Posted September 19, 2018 Hi Guys! I'm getting nowhere with VLS and Ive been recommended OBS by quite a few people, when I run it however I get the following error, any ideas? david@dday1sc:~$ obsAttempted path: share/obs/obs-studio/locale/en-US.iniAttempted path: /usr/share/obs/obs-studio/locale/en-US.iniAttempted path: share/obs/obs-studio/locale.iniAttempted path: /usr/share/obs/obs-studio/locale.iniAttempted path: share/obs/obs-studio/themes/Dark.qssAttempted path: /usr/share/obs/obs-studio/themes/Dark.qssinfo: CPU Name: Pentium® Dual-Core CPU E5200 @ 2.50GHzinfo: CPU Speed: 1639.848MHzinfo: Physical Cores: 2, Logical Cores: 2info: Physical Memory: 3910MB Total, 466MB Freeinfo: Kernel Version: Linux 4.15.0-34-genericinfo: Distribution: "Ubuntu" "18.04"info: Portable mode: falseQMetaObject::connectSlotsByName: No matching signal for on_advAudioProps_clicked()QMetaObject::connectSlotsByName: No matching signal for on_advAudioProps_destroyed()QMetaObject::connectSlotsByName: No matching signal for on_program_customContextMenuRequested(QPoint)info: OBS 0.0.1 (linux)info: ---------------------------------info: ---------------------------------info: audio settings reset: samples per sec: 44100 speakers: 2info: ---------------------------------info: Initializing OpenGL...error: X Error: GLXBadFBConfigerror: Failed to create OpenGL context.error: Failed to create context!error: device_create (GL) failederror: Failed to initialize video. Your GPU may not be supported, or your graphics drivers may need to be updated.info: Freeing OBS context datainfo: == Profiler Results =============================info: run_program_init: 6818.66 msinfo: ┣OBSApp::AppInit: 1.812 msinfo: ┃ ┗OBSApp::InitLocale: 1.474 msinfo: ┗OBSApp::OBSInit: 142.896 msinfo: ┣obs_startup: 22.623 msinfo: ┗OBSBasic::OBSInit: 39.142 msinfo: ┣OBSBasic::InitBasicConfig: 0.141 msinfo: ┣OBSBasic::ResetAudio: 0.413 msinfo: ┗OBSBasic::ResetVideo: 38.468 msinfo: obs_hotkey_thread(25 ms): min=0.095 ms, median=0.284 ms, max=9.47 ms, 99th percentile=3.397 ms, 100% below 25 msinfo: audio_thread(Audio): min=0.04 ms, median=0.062 ms, max=0.368 ms, 99th percentile=0.181 msinfo: =================================================info: == Profiler Time Between Calls ==================info: obs_hotkey_thread(25 ms): min=25.2 ms, median=25.359 ms, max=34.556 ms, 93.8224% within ±2% of 25 ms (0% lower, 6.17761% higher)info: =================================================info: Number of memory leaks: 172david@dday1sc:~$ ^Cdavid@dday1sc:~$ Ive run sudo apt-get update and still get the same error message..... I really want to get some form of capture ready for HSC season 8!!!! Quote Link to comment Share on other sites More sharing options...
