+DZ-Jay Posted August 22, 2018 Share Posted August 22, 2018 (edited) I have created a "Software Development Kit" (SDK) for IntyBASIC, a BASIC compiler for the Intellivision. The SDK not only offers a "turn-key" installation of all the tools necessary (compiler, emulator, etc.), but also includes sample files, libraries, and a bunch of tools to simplify the development work-flow of Intellivision games in IntyBASIC. I have packaged all this in an "installer wizard" for Windows and it works very well. Unfortunately, I can't seem to figure out how to do the same for the Mac. The installer not only has to copy the files (that's easy), but must also set up some environment variables for the tools to work adequately. It should match the configuration of its Windows counterpart as closely as possible. Here are the requirements I have: "Turn-key" installation: just double-click, next, next, next, and you're done. The entire distribution is copied to a new folder in the user's "Documents" folder. It creates a new sub-folder for users' projects. A couple of environment variables are set for the tools to know where everything is. A link (shortcut) is created on the Applications folder (or on the Desktop, wherever) that opens the Terminal app in the SDK's installation folder, with the environment variables set. Needs to run in latest Mac OS X, and all the way to Mountain Lion (10.8.5) -- because that's what I use. Re-running the installer (or running a newer version) should update all folders except the special user "Projects" folder. That's it. Simples. I'm just not a Mac programmer (well, I'm not much of a programmer at all). Preferably, I would like to have a custom configuration for Terminal, you know with a specific settings. That and the environment variables is what trips me. I would appreciate any help on this. Thanks! -dZ. Edited August 22, 2018 by DZ-Jay Quote Link to comment Share on other sites More sharing options...
Flojomojo Posted August 22, 2018 Share Posted August 22, 2018 I think it would be nicest if you just distributed a zip that had everything in the proper place in a self-contained, portable folder that didn't touch the system environment. But if you want to make a package installer: https://stackoverflow.com/questions/11487596/making-os-x-installer-packages-like-a-pro-xcode-developer-id-ready-pkg If you do this, please consider making an UNinstaller to bring everything back to where it was before. Quote Link to comment Share on other sites More sharing options...
+DZ-Jay Posted August 25, 2018 Author Share Posted August 25, 2018 I think it would be nicest if you just distributed a zip that had everything in the proper place in a self-contained, portable folder that didn't touch the system environment. Nah, most people don't want to go through the trouble. (I think most veteran programmers severely over-estimate the inclination and disposition of newbies in setting up and configuring their programming environment. Sure, you can say "if they were really interested, they would do it; but part of the point is to attract a new audience and build that interest in the first place.) The installer is intended to put everything in a self-contained folder in the user's Documents, add three environment variables, and add one folder to the executable path. Of course, the idea is to be able to uninstall cleanly as well. We do this on Windows right now. But if you want to make a package installer: https://stackoverflow.com/questions/11487596/making-os-x-installer-packages-like-a-pro-xcode-developer-id-ready-pkg If you do this, please consider making an UNinstaller to bring everything back to where it was before. Thanks for that. That tutorial seems more complicated than I have experienced. I already built an installer with PackageMaker. I was just stuck on how to make it update the environment variables and importing customized settings to Terminal.app. Nonetheless, I'll give it a shot. Alternatively, instead of modifying the environment globally, is there a way to have an icon that launches Terminal and runs the "export" shell commands to set the environment during the Terminal session? Sort of like what "bash.rc" does, but for a single specialized instance of Terminal, rather than having to much around with the user's environment. Something like what a "PIF" file does in DOS. Thanks, -dZ. Quote Link to comment Share on other sites More sharing options...
Flojomojo Posted August 25, 2018 Share Posted August 25, 2018 I guess you could just script it. https://developer.apple.com/library/archive/documentation/AppleScript/Conceptual/AppleScriptX/AppleScriptX.html Quote Link to comment Share on other sites More sharing options...
