Joystick direction gets stuck when fire is pressed
8 replies to this topic
#1 Jron OFFLINE
Jron
    Space Invader
  • 14 posts
Posted Thu Aug 23, 2018 5:35 AM
Hello all!
I am checking to see if I'm doing something wrong in my code, or if I found a compiler or Stella bug.
I am having an issue with the joystick direction getting stuck frequently in Stella when the fire button is pressed.  I have confirmed through the debug tools that the joystick direction switch is stuck on when this happens even though I am not holding down any cursor keys.  The cursor keys on my computer are not having problems in any other software.
It can be duplicated by pressing a direction and tapping the fire key and releasing the direction key.  I think the timing needs to be right, but it will do it eventually.
I am using DPC+
I've attached my debug basic code that is stripped of everything except for the movement, playfield collision, and animation code.  I kept removing pieces of code hoping to find the culprit but no luck. The code that is left is based off from code I found in the "batari Basic Command Reference" which I modified to fit how I wanted the player to move on the screen.
I am running the latest Batari Basic dev software found here in the forums and my Stella version is 5.1.3
I do not have a Harmony cart to be able to test this on a real 2600 (but I am curious if it also happens on a console).
I appreciate everyone's time.
#2 ZackAttack OFFLINE
ZackAttack
    Dragonstomper
  • 762 posts
Posted Thu Aug 23, 2018 7:14 AM
Isn't that exactly what your code is designed to do?
  ; Skip player movement if attacking (preserving player attacking animation)
  if joy0fire || _Bit0_P0_Attacking{0} then goto __Skip_Player_Movement
#3 Gemintronic ONLINE
Gemintronic
    Jason S. - Lead Developer & CEO
  • 9,363 posts
Posted Thu Aug 23, 2018 7:18 AM
I always use a USB joystick when testing builds.  The keyboard can cause problems.  Bluetooth keyboards are worse as with bad signals or low batteries they can repeat keystrokes.
#4 Jron OFFLINE
Jron
    Space Invader
  • 14 posts
Posted Thu Aug 23, 2018 9:35 AM
I added that to try to fix the problem.  I removed that and the next if statement and the problem still persists.
I was thinking about that on my way to work.  Maybe windows or my keyboard driver is doing a "sticky key" type thing?  I will try using a usb gamepad tonight and report back.
#5 stephena OFFLINE
stephena
  • 3,409 posts
  • Stella maintainer
Posted Thu Aug 23, 2018 9:38 AM
I cannot duplicate this in either Linux or Windows.  Haven't tested in OSX, nor with any joysticks (keyboard only).
#6 SpiceWare OFFLINE
SpiceWare
    Draconian
  • 12,807 posts
  • Medieval Mayhem
Posted Thu Aug 23, 2018 9:46 AM
I've had issues with MAME and bluetooth keyboards.
#7 Random Terrain OFFLINE
Random Terrain
    Visual batari Basic User
  • 29,027 posts
  • Controlled Randomness
    Replay Value
    Nonlinear
Posted Thu Aug 23, 2018 10:58 AM
Have you tried firing with the CTRL key instead of the space bar?
#8 Jron OFFLINE
Jron
    Space Invader
  • 14 posts
Posted Thu Aug 23, 2018 4:49 PM
The problem does not happen when using the ctrl key.  Thanks for that tip!
 It also doesn't do it when using a usb game pad.  it must be something specific to my notebook's keyboard.  Thanks everyone!
Edit: I tested with my usb keyboard and could not duplicate it.  I guess it must be a feature of Thinkpad keyboards.
Edited by Jron, Thu Aug 23, 2018 5:09 PM.
#9 stephena OFFLINE
stephena
  • 3,409 posts
  • Stella maintainer
Posted Fri Aug 24, 2018 5:13 AM
Looks like our old friend is back: https://www.sjbaker....boards_Are_Evil
