sanny Posted August 23, 2018 Share Posted August 23, 2018 Hi, I've read thru the 4.48 programming and user manuals, but haven't found anything. How can I programatically get and set date and time on SDX? I see that there's a CLK: driver, but don't know how to access it. regards, chris Quote Link to comment Share on other sites More sharing options...
sanny Posted September 2, 2018 Author Share Posted September 2, 2018 No answer? No SD-X developers on this site? Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted September 2, 2018 Share Posted September 2, 2018 10 c=peek(10)+256*peek(11) 20 day=peek(c+13):month=peek(c+14):year=peek(c+15) 30 hour=peek(c+16):min=peek(c+17):sec=peek(c+18) Quote Link to comment Share on other sites More sharing options...
mono Posted September 3, 2018 Share Posted September 3, 2018 Look at SDX User Guide: - 6.4. SpartaDOS User Accessible Data Table (DATER, TIMER, ODATER, OTIMER, TDOVER) - 6.7. Vectors under the OS ROM (VGETTD, VSETTD, VTDON, VFMTTD) - 6.8. Page seven kernel values - 8.6.3.6. Z.SYS I suspect all datetime device drivers like JIFFY.SYS, APETIME.SYS etc. have common interface, but it's better to ask Draco about it. Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted September 3, 2018 Share Posted September 3, 2018 (edited) It's easier to COMTAB than vectors under the OS ROM. COMTAB=DPEEK(10) If you have Incognito or U1M, and the new BIOS, the Z: device is also available. Edited September 3, 2018 by Kyle22 Quote Link to comment Share on other sites More sharing options...
sanny Posted September 18, 2018 Author Share Posted September 18, 2018 Look at SDX User Guide:- 6.7. Vectors under the OS ROM (VGETTD, VSETTD, VTDON, VFMTTD) I suspect all datetime device drivers like JIFFY.SYS, APETIME.SYS etc. have common interface, but it's better to ask Draco about it. I had sent @drac030 a PM on Sep-6, but didn't get an answer. But, according to AtariAge, he hasn't read it yet. Following up on this, I want to try the I_GETTD and I_SETTD SDX functions (not by using the vectors under the ROM, but by more future-proof means). I haven't found documentation about these functions in neither the SDX user manual nor the SDX programming manual. Is there documentation available for these functions? Input/Output parameters, etc. Any hint is appreciated. regards, chris Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted September 18, 2018 Share Posted September 18, 2018 (edited) no, If you are going to use the symbols like that, look at section 16.1 in the programming guide you are going to have to get a feel for this using S_LOOKUP. you will have to look through this section it's helpful and should contain an example pertaining to time clock as well. You will have to go to Drac's site and contact him through his posted contact there. see also TRUB ! for great help Edited September 18, 2018 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted September 18, 2018 Share Posted September 18, 2018 (edited) 10 c=peek(10)+256*peek(11) 20 day=peek(c+13):month=peek(c+14):year=peek(c+15) 30 hour=peek(c+16):min=peek(c+17):sec=peek(c+18) What about this don't you understand? This is simple BASIC. RTFM! Edit: You guys DO know, I hope that I was only using BASIC to show you a simple way of doing this. It can be accomplished using Assembly more easily. Any language, actually. I was only providing a template.to help new users who haven't read the manual, available here: http://sdx.atari8.info/sdx_files/4.48/SDX448_User_Guide.pdf (Banging my head off the wall now, if you guys can't figure it out yet.)...... Edited September 18, 2018 by Kyle22 Quote Link to comment Share on other sites More sharing options...
sanny Posted September 18, 2018 Author Share Posted September 18, 2018 no, If you are going to use the symbols like that, look at section 16.1 in the programming guide you are going to have to get a feel for this using S_LOOKUP. you will have to look through this section it's helpful and should contain an example pertaining to time clock as well. I looked at sc 16.1. This is very helpful, thanks. Still, now I should be able to get the addresses of I_SETTD and I_GETTD, but don't know their parameters (new time in case of I_SETTD) and results (current time with I_GETTD). You will have to go to Drac's site and contact him through his posted contact there. see also TRUB ! for great help Thanks for the hint. I'll send him an email directly. regards, chris Quote Link to comment Share on other sites More sharing options...
tschak909 Posted September 18, 2018 Share Posted September 18, 2018 I was able to do this in CC65 by doing: void timedate(TimeDate* td) { struct regs r; assert(td!=NULL); r.pc = 0x703; // KERNEL r.y = 100; // GETTD *(byte*) 0x0761 = 0x10; // DEVICE _sys(&r); // Do Kernel Call. td->day = *(byte*) 0x77B; td->month = *(byte*) 0x77C; td->year = *(byte*) 0x77D; td->hours = *(byte*) 0x77E; td->minutes = *(byte*) 0x77F; td->seconds = *(byte*) 0x780; return; } Quote Link to comment Share on other sites More sharing options...
sanny Posted September 18, 2018 Author Share Posted September 18, 2018 What about this don't you understand? This is simple BASIC. I did understand it. I guess it can be used to get the current time. But how to _set_ time? And update the RTC if present. For a simple version of "setting" I could try to overwrite these variables with a new time, but don't know whether it will persist (maybe a RTC driver sporadically updates those fields from the RTC). regards, chris 2 Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted September 18, 2018 Share Posted September 18, 2018 What you need is described in section 6.8 of the current SDX User Manual (Page Seven "Kernel" Values). date $77B see below (3 bytes) time $77E see below (3 bytes) The 'kernel' routine is called by doing a jump subroutine (JSR) to address $703 with the desired command in the 6502 Y register and the desired device number previously stored in the memory location 'device'. For example, with a $10 in device, a value of 100 in the Y-register will cause the current time and date to be placed in the variables 'time' and 'date'. A 101 will cause the current time to be set to the values contained in the variables 'time' and 'date'. kd_gettd 100 get current time and date kd_settd 101 set time and date 1 Quote Link to comment Share on other sites More sharing options...
sanny Posted September 18, 2018 Author Share Posted September 18, 2018 @flashjazzcat, this looks promising. I somehow overlooked (or maybe read and forgot) that. Will report back.. Thanks, chris Quote Link to comment Share on other sites More sharing options...
sanny Posted September 19, 2018 Author Share Posted September 19, 2018 Yep, this seems to work. Tested on SDX with an RTC and without an RTC (JIFFY.SYS). Thanks @flashjazzcat and @tschak909! /* $Id: sdxtime.c,v 1.1 2018/09/19 20:25:03 chris Exp $ * * SpartaDOS-X time/date test */ #include <stdio.h> #include <stdlib.h> #include <string.h> #include <conio.h> #include <time.h> #include <assert.h> #include <atari.h> #include <cc65.h> #include <6502.h> static void exitfn(void) { if (doesclrscrafterexit()) cgetc(); } /* from Thom Cherryhomes: */ static void timedate(struct tm *td) { struct regs r; assert(td != NULL); r.pc = 0x703; /* KERNEL entry */ r.y = 100; /* GETTD function */ *(unsigned char *)0x0761 = 0x10; /* DEVICE */ _sys(&r); /* do the kernel call */ td->tm_mday = (int)*(unsigned char *)0x77B; td->tm_mon = (int)*(unsigned char *)0x77C - 1; td->tm_year = (int)*(unsigned char *)0x77D; td->tm_hour = (int)*(unsigned char *)0x77E; td->tm_min = (int)*(unsigned char *)0x77F; td->tm_sec = (int)*(unsigned char *)0x780; /* fix century */ if (td->tm_year < 79) td->tm_year += 100; } static void timedate_set(struct tm *td) { struct regs r; assert(td != NULL); *(unsigned char *)0x77B = (unsigned char)td->tm_mday; *(unsigned char *)0x77C = (unsigned char)td->tm_mon + 1; *(unsigned char *)0x77D = (unsigned char)td->tm_year % 100; *(unsigned char *)0x77E = (unsigned char)td->tm_hour; *(unsigned char *)0x77F = (unsigned char)td->tm_min; *(unsigned char *)0x780 = (unsigned char)td->tm_sec; r.pc = 0x703; /* KERNEL entry */ r.y = 101; /* SETTD function */ *(unsigned char *)0x0761 = 0x10; /* DEVICE */ _sys(&r); /* do the kernel call */ } static void print_time(struct tm *time_to_print) { timedate(time_to_print); printf("time: %s\n", asctime(time_to_print)); // DEBUG: printf("mday=%d mon=%d year=%d\nhour=%d min=%d sec=%d\n", time_to_print->tm_mday, time_to_print->tm_mon, time_to_print->tm_year, time_to_print->tm_hour, time_to_print->tm_min, time_to_print->tm_sec); } int main(int argc, char **argv) { static char c; static int s; static struct tm cur_time; atexit(exitfn); if (_dos_type != SPARTADOS) { /* check version? */ printf("not on SpartaDOS, exiting...\n"); return 1; } if (argc <= 1) { print_time(&cur_time); return 0; } if (argc != 3 || strcasecmp(*(argv + 1), "set")) { printf("usage: SDXTIME [set DD-MM-YY-HH-MM-SS]\n"); return 1; } s = sscanf(*(argv + 2), "%d-%d-%d-%d-%d-%d", &cur_time.tm_mday, &cur_time.tm_mon, &cur_time.tm_year, &cur_time.tm_hour, &cur_time.tm_min, &cur_time.tm_sec); if (s != 6 || cur_time.tm_year > 99 /* other input values aren't being verified... */) { printf("invalid time/date format\n"); return 1; } --cur_time.tm_mon; if (cur_time.tm_year < 79) cur_time.tm_year += 100; /* adjust century */ printf("\nyou are about to set the time to\n--> %s\n\nContinue (y/n)?", asctime(&cur_time)); while (c != 'y' && c != 'Y' && c != 'n' && c != 'N') c = cgetc(); printf("%c\n", c); if (c == 'n' || c == 'N') { printf("user abort\n"); return 0; } timedate_set(&cur_time); printf("time set!\n"); //DEBUG test begin memset(&cur_time, 0, sizeof(cur_time)); print_time(&cur_time); //DEBUG test end return 0; } /* Local Variables: */ /* c-file-style: "cpg" */ /* c-basic-offset: 4 */ /* End: */ 1 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted September 19, 2018 Share Posted September 19, 2018 w000000000000000000000000t! Glad that worked! -Thom Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted September 23, 2018 Share Posted September 23, 2018 I did understand it. I guess it can be used to get the current time. But how to _set_ time? And update the RTC if present. For a simple version of "setting" I could try to overwrite these variables with a new time, but don't know whether it will persist (maybe a RTC driver sporadically updates those fields from the RTC). regards, chris Ok, I thought you only wanted to read the time. Quote Link to comment Share on other sites More sharing options...
