Yaron Nir Posted August 26, 2018 Share Posted August 26, 2018 i have downloaded the language plugin for notepad++ from here: https://github.com/kenjennings/NotepadPlusPlus-Atari-Syntax-Highlighting it highlights the syntax for my asm code in notepad++. this works ok. now, is there a way to compile and run it using altirra? 1 Quote Link to comment Share on other sites More sharing options...
shanti77 Posted August 26, 2018 Share Posted August 26, 2018 I use "cmd" (windows command prompt) and make.bat file: mads.exe -t -l %1.asm I simple write : "make file_name" ,than I have second file go.bat: c:\b\Altirra.exe %1.obx To run I write : "go file_name" 3 Quote Link to comment Share on other sites More sharing options...
Yaron Nir Posted August 26, 2018 Author Share Posted August 26, 2018 (edited) tnx for the reply Shanti77 I have managed to compile and run altirra from notepad++ to whom it may concern: - first i've installed notepad++ plugin manager - then installed the NPPExec plugin - then created a batch (*.bat) file and added the mads (altirra) command lines: for example: ..\[PathToMads]\MADS\mads.exe ..\[PathToMainAsmFile]\Main.asm -o:[PathToOutputMainFile]\Main.xex ..\[PathToAlttira]\Altirra64.exe /singleinstance ..\[PahToMainXexFile]\Main.xex you can additionally add the -p -t -l to generate lab file and lst file all that is left is to execute this script using the NPPExec plugin hope that helped someone Cheers Yaron Edited August 26, 2018 by Yaron Nir 1 Quote Link to comment Share on other sites More sharing options...
tebe Posted August 26, 2018 Share Posted August 26, 2018 mads\syntax\notepad++ FunctionListRules.xml Notepad++.pdf readme.txt SourceCookifier.mads.xml userDefineLang_mads.xml VS2015-Dark.xml 2 Quote Link to comment Share on other sites More sharing options...
