BATMAN (Popeye Hack)
Jamcat Reloaded
Here is a revision that uses the background graphics from KevinMos3's Popeye hack.
I really dig this project! I was not aware of KevinMos3's 32k Popeye hack, need to locate that. It shouldn't be too hard to swap out the music , if you could locate it in memory. How much memory is free in the 8k Popeye?
  • 6 months later...
There is a Popeye hack that works on the AFP... try this ...
http://atariage.com/forums/topic/260650-is-it-possible-to-put-a-playfield-in-popeye-together-with-hackomatic-3/page-2?do=findComment&comment=3677908
If that works, then the Batman sprite hacks can be done with that one.
  • 7 months later...
How about making it into a BATMAN & ROBIN game (with a rotating villain for each level).  Batman could be depicted in blue, while Robin shows up (in this game) in red.  As for the rotating villains:  Purple may be used for Joker, gray for Penguin, green for Riddler, a darker bluish-purple for Catwoman, ... .  Try to have the Neal Hefti-composed theme programmed for inclusion.
