Need help debugging PLATOTerm TIPI routines
34 replies to this topic
#26 tschak909 OFFLINE
tschak909
  • 3,248 posts
Posted Tue Sep 25, 2018 11:51 AM
Yup, I explicitly filter out any double IAC sequences in protocol.c/h
This code is working in the Spectranet version, which uses a similar approach to the TIPI. I'll be circling back around to this, shortly, as I am tidying up the MS-DOS versions. :)
-Thom
#27 tschak909 OFFLINE
tschak909
  • 3,248 posts
Posted Sun Oct 14, 2018 1:25 AM
Ok, so I've done another test build, finding an interesting glitch in the Apple IIgs version that exhibited the same symptoms, which I fixed by altering the echo packet test condition slightly. Let's see if this helps? Can somebody with a TIPI test, please? :)
-Thom
#28 HOME AUTOMATION OFFLINE
HOME AUTOMATION
    Moonsweeper
  • 435 posts
Posted Sun Oct 14, 2018 5:02 AM
Not knowing how PLATOTERM works. I ran two files using E/A option 5... Nice Big TI logo... TIPI light stays on... other file just returns(press enter to continue)... does this need RS232 or TELNET or IP\protocol? I'm lost.
#29 tschak909 OFFLINE
tschak909
  • 3,248 posts
Posted Sun Oct 14, 2018 9:16 AM
Does it not connect, at all?
the TIPI build should automatically connect.
-Thom
#30 HOME AUTOMATION OFFLINE
HOME AUTOMATION
    Moonsweeper
  • 435 posts
Posted Sun Oct 14, 2018 9:26 AM
I don't know what I'm trying to connect through... I normally don't have my TIPI online... I did try...maybe I need to lower the security settings on my router???
#31 HOME AUTOMATION OFFLINE
HOME AUTOMATION
    Moonsweeper
  • 435 posts
Posted Sun Oct 14, 2018 9:51 AM
There is a curious looking red question mark over the file-name "PLATO" that reports "OS Native File". this is the file that loads the big TI logo.
I lowered the ROUTER'S FIREWALL... My TI monitor is only four inches diag. so it's hard to read the text... I did see "connected" go by fast on the bottom of the screen... than the screen cleared and some text appeared at the top of screen but cleared to soon to be read... only a small strange looking character remained at lower right hand corner... the TIPI light blinks slightly on keystrokes.
I am using a standard VDP driven dispay.
#32 HOME AUTOMATION OFFLINE
HOME AUTOMATION
    Moonsweeper
  • 435 posts
Posted Sun Oct 14, 2018 10:58 AM
OH... I am still using PI 1.0BETAv012
DSR 2018-06-23
CRU BASE 1100
#33 tschak909 OFFLINE
tschak909
  • 3,248 posts
Posted Sun Oct 14, 2018 11:00 AM
ok, so that didn't fix the problem. urgh.
Thanks for testing. :)
-Thom
#34 HOME AUTOMATION OFFLINE
HOME AUTOMATION
    Moonsweeper
  • 435 posts
Posted Sun Oct 14, 2018 2:39 PM
I thought this might help...
Attached File  Tipiplato.gif   12.8MB   7 downloads
  • RXB likes this
#35 tschak909 OFFLINE
tschak909
  • 3,248 posts
Posted Sun Oct 14, 2018 2:45 PM
Yup, appreciated. Same spot. Damn it.
-Thom
