Algo3
hardware
5 replies to this topic
#1 sage OFFLINE
sage
    Dragonstomper
  • 976 posts
Posted Sun Sep 9, 2018 12:45 AM
Anyone played  bit with algo3? Even so the EPXY doc says  "algo 3 is broken"?
It seems that some circuits are left which work, but mainly for Y.
#2 karri OFFLINE
karri
  • 2,547 posts
Posted Sun Sep 9, 2018 12:47 PM
I remember seeing this note at some point in time. What was algo3 supposed to do?
#3 sage OFFLINE
sage
    Dragonstomper
  • 976 posts
Posted Sun Sep 9, 2018 2:28 PM
as far as I can tell, it should use a 16 bit mask to select the pixels from the sprite.
in Y it somehow seem to do something (but somehow only every second line), but it wont work for X, will stop after few columns.
#4 enthusi OFFLINE
enthusi
    Dragonstomper
  • 531 posts
Posted Sun Sep 9, 2018 2:31 PM
You probably saw it here:
FC81 = SPRCTL1 Sprite Control Bits 1 (W)(U)
reset x,x,x,x,x,x,x,x
B7 = literal attribute, 0=normal, 1=totally literal
B6 = Sizing algorithm choice, 0=adder (algo 4), 1=shifter (algo 3)
SET IT T0 ZERO!!!!, algo 3 is broke
Not too helpful, though.
#5 sage OFFLINE
sage
    Dragonstomper
  • 976 posts
Posted Mon Sep 10, 2018 1:34 AM
I found a better description somewhere
#6 karri OFFLINE
karri
  • 2,547 posts
Posted Mon Sep 10, 2018 4:20 AM
Thanks. Actually I don't really need masked stuff anymore. The "shaped" version combined with a programmable start quadrant takes care of my needs. The only slight problem I have is that tilt/stretch tears the sprite from the anchor point. So in order to tilt my car I need to keep the sprite in one segment.
Also tagged with one or more of these keywords: hardware
