Should I make a new "in-depth" video on 4A/DOS?
27 replies to this topic
Poll: 4A/DOS video (32 member(s) have cast votes)
Would you be interested in a new in-depth 4A/DOS video?
  1. Yes (24 votes [75.00%])
    Percentage of vote: 75.00%
  2. No (5 votes [15.62%])
    Percentage of vote: 15.62%
  3. Not applicable to my needs. (2 votes [6.25%])
    Percentage of vote: 6.25%
  4. Don't care (1 votes [3.12%])
    Percentage of vote: 3.12%
Vote Guests cannot vote
#1 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 13,810 posts
Posted Sun Sep 9, 2018 5:45 PM
I've been getting some questions via PM's and even Chatti about 4A/DOS.  So my question to you guys is; should I make a new in-depth video on 4A/DOS?  If so, what would you like to see covered?
Back in the day it was originally for the old "Supercart", a modified Editor Assembler using a different cartridge for it's base, but more recently it was converted into cartridge format usable with the FG99 and, now with Tursi's help it can be used in a more practical and convenient way in an auto-booting form with an UberCart.
Should I include it's earlier history?  Should I cover how it's used?  Should I show how it makes working with the TIPI so much easier?  Should I include references to new programs that have come out for it recently, or existing programs that make it more functional?
If you have any other questions or comments about what you would like to see addressed (if any) please post them here.
#2 HOME AUTOMATION OFFLINE
HOME AUTOMATION
    Moonsweeper
  • 391 posts
Posted Sun Sep 9, 2018 6:45 PM
I have been wondering? How do you bypass the title screen from a cartridge... Is there a software HEADER to do that... or are the 0,1,2 GROMS being bypassed??? I wonder if I kill/remove the console GROMS could my FG99 do this?
#3 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 13,810 posts
Posted Sun Sep 9, 2018 7:07 PM
You cannot do this with a FinalGROM, you need to use an UberGROM cartridge.  Essentially the 4A/DOS program is written to the 49F040 and the GROM bypass routines are in the 1284P.
The easiest way to do this if you don't have an older used UberGROM laying around, or a MiniPRO is to << CLICK HERE >>.
Ever since the FG99 came out, I've freed up a few UberGROMs for "re-tasking", I imagine others have as well.
#4 wolhess OFFLINE
wolhess
    Space Invader
  • 45 posts
Posted Mon Sep 10, 2018 5:50 AM
Hi Omega,
using 4aDOS with tipi is very fast and your batch menue is clear to me. Using the DOS commands from prompt and examples of starting assembler programs are very interesting for me. Maybe it is possible to automap a tipi Volume as DSK1. and start a program like TI-Writer or the disk version of Parsec from DOS prompt or from a Batch-Menue?
#5 Vorticon OFFLINE
Vorticon
  • 3,621 posts
Posted Mon Sep 10, 2018 7:15 AM
I think an in-depth video would be very helpful.
#6 arcadeshopper ONLINE
arcadeshopper
  • 4,287 posts
Posted Mon Sep 10, 2018 11:09 AM
Hi Omega,
Worst case it's super easy to make a ea5 program to do this..  to start an ea5 image in 4ados you type LOAD DSK1.FILENAME      like to load my editor its LOAD TIPI.UTIL.EDIT80  I'd really like to see 4ados get updated to be more like boot where you could run it from XB and have XB AND EA5 loaders.. but that would make it slower.. maybe a UBER image with both in it.. like XB27 with 4ados as the boot menu..
#7 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 13,810 posts
Posted Mon Sep 10, 2018 3:24 PM
Hi Omega,
Do you have a disk version of Parsec?  I only have the cartridge version.  If you have the disk version, send it my way and I'll see what can be done.
4A/ DOS also does EA/3 files and any commands that can be typed in can also be used in a batch file by stacking commands, so loading a program like that is just as easy as pressing one button.
Many programs do not NEED to be run out of DSK1, so including the path in the batch file is usually good enough with no need to re-map disks.  I might mention that if you put your edited scratch loader program in the ROOT directory, and it has the path included, it's super easy to run a large multi sub-directory deep program with two words, for instance LOAD EDITOR would run TIPI.DOS.EDIT80.
In my case I do not map DSK1. I use my Lotharek HXC as my DSK1, but that is where I have my AUTO-BAT which is a very short batch file that loads MENU-BAT up from the TIPI.DOS. sub-directory (because everything loads faster from the RPi.)
I prefer to have DSK1. available because some legacy programs require 'a real disk format'.
#8 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 13,810 posts
Posted Mon Sep 10, 2018 3:30 PM
Oh boy, I'd like to see Extended BASIC combined with 4A/DOS in the cartridge too!  Until that time, if someone only wanted to only use BOOT they could easily write a tiny batch file to immediately load BOOT from disk straight from power up or from a reset.
#9 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 13,810 posts
Posted Mon Sep 10, 2018 3:44 PM
I'll see how many votes it gets before I commit.  Videos take a LOT of time to film, edit and process (multiple times).
#10 wolhess OFFLINE
wolhess
    Space Invader
  • 45 posts
Posted Tue Sep 11, 2018 9:38 AM
Attached File  tipi.zip   171.22KB   12 downloads
Thank You Omega, today I modified your 4ADOS batchfile and made a second EA5-BAT batchfile with several EA5 Games to start from the 4ADOS Menu and it works fine.
Yes I saw an EA5 Version of Parsec and other cardridges in this Thread http://atariage.com/...-fixing-parsec/
I used also modified LOAD-BOOT files to start the EA5 games.
Thank you to arcadeshopper: It works with EDIT40 too.
In the attached Tipi.zip file I have my start configuration for using with the 4ADOS Environment.
The 4ADOS Files are in TIPI.4ADOS folder
(I maped this as DSK1. because the 4ADOS needs the CHARA1 file in DSK1.)
and
the games files are in TIPI.EA5 Folder
The 4ADOS I starts from my FG99 but it should also start from the module Version.
If you will provide a video about the configuration of the 4ADOS environment, it would be great if you show us to start the different file types "DOS commands", "EA5-files", "EA3-files" maybe XB programs too.
#11 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 13,810 posts
Posted Tue Sep 11, 2018 4:04 PM
Right on Wolhess!  It's nice to see another person dive into 4A/DOS and experience what it's capable of.  So many ways to run it...
1) In Classic 99 (more or less to check it out)
2) From a Super Cart (as originally intended)
3) From a FlashROM or FinalGROM
4) From a dedicated UberGROM cartridge (my favorite method because of the auto-boot & return characteristics).
With method #4 and a TIPI it's a game changer for sure, now throw in an F18A and it's like a different computer.
One benefit of the UberGROM method is Tursi's hack to put CHARA1 in the cartridge.  I find that handy because I no longer have to put copies of that file in multiple places.
Currently, XB is out of the question with 4A/DOS.  :_(  It would be cool though, but 95% of everything I run is ether assembly or compiled coded programs.
With the GROM bypass routine and call to the 'program' in the 512K chip, the currently 8K 4A/DOS program has plenty of room to evolve and grow over time!  Can you imagine the utility and features if it was 'just doubled' in size to a mere 16K?  It would be a snap to download & upgrade by simple over-writing the 49F040 and snapping it back into the cartridge.
I just downloaded you attachment and will check it out!  - Thanks!
#12 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 13,810 posts
Posted Wed Sep 12, 2018 7:24 AM
I really like the way you think!  It would be the best of both worlds.  Getting it done... probably another story.  I know of someone who could probably pull it off... but I'm not gonna ask.
#13 wolhess OFFLINE
wolhess
    Space Invader
  • 45 posts
Posted Wed Sep 12, 2018 7:47 AM
@arcadeshopper, @OMEGA,
currently I prefer RXB, when I use Extended Basic or Basic programs/games.
Is it possible to create a 4A/DOS Suite cardridge with:
- 4A/DOS
- RXB 2015 (maybe RXB 2018)
- REA 2015
- Disk Manager 2.1 (from the XB2.7 Suite)
- Disk Manager 2000 DM2K (from the XB2.7 Suite)
  (or the upcomming new Tipi diskmanager from Jedimat42)
- Compact Flash HDXS (from the XB2.7 Suite)
- TI Writer
I will try to bring the topics above together in a FG99 SD-Card, maybe it works.
#14 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 13,810 posts
Posted Wed Sep 12, 2018 8:14 AM
- 4A/DOS
- REA 2015
- TI Writer
Possible?  Yes.  Probable?  No.  I'd say for your individual needs, your best bet would be to just load up a FinalGROM with all your stuff and forget about a dedicated 4A/DOS cartridge.  You can still use 4A/DOS from the FinalGROM, you'll just have to stick CHARA1 files in places and forget about the auto-booting and reset aspects.
#15 wolhess OFFLINE
wolhess
    Space Invader
  • 45 posts
Posted Wed Sep 12, 2018 8:23 AM
Thank You Omega, that was also in my mind. I will stay with my FG99 and using 4A/DOS from there.
#16 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 13,810 posts
Posted Wed Sep 12, 2018 9:12 AM
FYI - For those of you with FG99's that now have extra UberGROM's laying around unused, you can still have an auto-booting 4A/DOS cartridge (for cheap) by just ordering the pre-programmed 1284P and 49F040 from ArcadeShopper.
#17 twoodland OFFLINE
twoodland
    Chopper Commander
  • 214 posts
Posted Mon Dec 10, 2018 6:28 AM
attachicon.giftipi.zip
and
wolhess,
Thank you so much for your discussion on this topic, and for posting your 4A/DOS configuration files. I do not yet have a 4A/DOS UberGROM cartridge, but I do have a FG99.  I am very interested in using 4A/DOS with my TIPI.  I do not have 80 column capability, so I am grateful for your configuration files that support 40 columns.
How did you create the LOAD files like LOADEDIT, LOADBIG etc.  Can I view/edit them?
Edited by twoodland, Mon Dec 10, 2018 7:02 AM.
#18 videofx OFFLINE
videofx
    Moonsweeper
  • 256 posts
Posted Mon Dec 10, 2018 11:58 AM
I Would love the video. My TIPI is on its way and would love to see a video on the best way to get 4DOS working. I bought the 4DOS cart from arcade shopper
#19 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 13,810 posts
Posted Mon Dec 10, 2018 4:10 PM
Probably will not happen until after the new year.  I've been slammed at work, have other irons in the fire and a lady that wants more attention.
#20 videofx OFFLINE
videofx
    Moonsweeper
  • 256 posts
Posted Mon Dec 10, 2018 5:39 PM
No problem then I will just take help getting 4DOS cart working with my new TIPI :)
#21 videofx OFFLINE
videofx
    Moonsweeper
  • 256 posts
Posted Fri Dec 14, 2018 7:39 PM
and
Wolves,
Thanks for the TIPI files. Can I just copy them to the SD card for the TIPI? Where so they go
vielen dank
#22 arcadeshopper ONLINE
arcadeshopper
  • 4,287 posts
Posted Sat Dec 15, 2018 3:15 PM
Wolves,
vielen dank
if you open the tipi web interface, make a folder called 4ADOS put them in there
or the file share.. same thing just drag and drop.if the files are already tifiles format then nothing else to do other than map DSK1 = 4ADOS  and it will pop up as DSK1 on the TIPI
#23 videofx OFFLINE
videofx
    Moonsweeper
  • 256 posts
Posted Sat Dec 15, 2018 3:17 PM
Thanks! Now I need to read how to set DSK1=4ADOS
#24 arcadeshopper ONLINE
arcadeshopper
  • 4,287 posts
Posted Mon Dec 17, 2018 2:21 AM
ti basic
call tipi
edit the DSK1 section to read 4ADOS
easier:
extended basic
old PI.http://ftp.whtech.co...TIPIMAP/TIPIMAP
run
select 4ADOS with arrow keys, hit 1 to map to DSK1
#25 arcadeshopper ONLINE
arcadeshopper
  • 4,287 posts
Posted Mon Dec 17, 2018 2:24 AM
also watch this video
