Wizard of Wor Arcade - reboot
94 replies to this topic
#76 MissCommand OFFLINE
MissCommand
    Star Raider
  • 75 posts
Posted Wed Nov 21, 2018 11:19 PM
Thanks for the feedback, I'm glad you're enjoying the game!  As Nathan mentions below, this is an issue that we *think* is related to the Atarivox+ as there have been numerous software tests done to try to eliminate the behavior but none have been successful.
BTW, if you need help with testing, I would be more than happy to help.  I have a pretty reliable platform for the glitching.
I was just thinking, another one that works for me is the Speak and Spell ROM... just as long as you don't use any of the punctuation (like the ? and .)
#77 sramirez2008 OFFLINE
sramirez2008
  • 2,664 posts
  • Stella Foreva
Posted Sat Nov 24, 2018 9:00 PM
  Yeah... it is kind of hidden under a thread for adding more mazes to Berzerk, one could easily miss it. RevEng is the one who did it and he added all (I think) of the phrases in Berzerk with Atarivox... so you can hear phrases during gameplay without blanking the screen.
http://atariage.com/...ew-mazes/page-3
I had totally missed this thread.  Love this version of the game.  Thanks for mentioning it. :thumbsup:
#78 sramirez2008 OFFLINE
sramirez2008
  • 2,664 posts
  • Stella Foreva
Posted Sat Nov 24, 2018 9:08 PM
Do you have an AtariVox+? If so, it's a known issue. It will also glitch on real hardware if it's the same problem.
BTW, I have played many rounds of Wizard of War Arcade with my AtariVox and have not noticed any issues concerning speech.  I know that mine is one of the older models, but thought I should still mention this.
#79 Karl G ONLINE
Karl G
    Dragonstomper
  • 644 posts
Posted Sun Nov 25, 2018 7:50 AM
Yeah, I believe that it has been determined that the hardware glitch is only with the "plus" version of the AtariVox, so older versions are unaffected.
#80 MissCommand OFFLINE
MissCommand
    Star Raider
  • 75 posts
Posted Sun Nov 25, 2018 2:01 PM
Oh, if that is the case, I would think it would not be too difficult to find the differences between the firmware on each... but I know nothing about electronics! :P
#81 SpiceWare OFFLINE
SpiceWare
    Draconian
  • 12,546 posts
  • Medieval Mayhem
Posted Sun Nov 25, 2018 4:40 PM
Part of that difference is it now has 3 modes of operation:
  • AtariVox
  • VecVoice
  • VecVox
#82 Clay B. Hammock OFFLINE
Clay B. Hammock
    Combat Commando
  • 8 posts
Posted Sun Dec 23, 2018 1:57 AM
Fun Demo, but a few things I would like to mention.  I can't use my Sega Controller on this game.
It dos'nt  go all four directions.  The Sega controller works on every other game except this one.
will that be corrected in the final version ?
    This version seems to do like the Coleco version.  It gradually gets harder, until about 5th or 6th
level.  Then the enemy goes so fast, you just lose quick.  Using all your men to clear one level.
Easy mode is the same.  At about the 3rd level it seems to join the same speed as normal mode.
Did'nt think any version gradually got hard untill I saw the Comodor 64 version.  I saw the game
gradually getting harder on 7 - 8 - 9 - 10 level and on the 11th level, I had to turn of the Internet.
     Don't have a Comodor 64, and maybe it's to big of a change in the programming, but would
be nice.
#83 johnnywc OFFLINE
johnnywc
  • 2,001 posts
Posted Sun Dec 23, 2018 7:57 AM
Hi!
The game does support Sega Genesis controllers. The issue is that it also supports the multi-tap (which allows 2 joysticks in the left joystick port) and the detection scheme is the same for each. When you plug in a Genesis controller, the game is detecting a multi-tap. An easy work around is to start the game with the Genesis gamepad button 'C' held down; the game will detect it as a normal joystick (since you don't need both buttons) and it will work fine. I may add a prompt when you power on the game that asks if you have a multi-tap to make it more intuitive.
be nice.
The game is actually designed to be like the arcade, which reaches it's peak difficulty at level 6 (on standard). For NOVICE it starts off slower and hits maximum speed at the 8th level. Also with Novice there is one less monster (max 5) until level 7 (and expert has one extra monster). The game also gets harder after level 7 as the wizard will teleport more frequently and the Worlord mazes (more open spaces) appear.
I agree the game does get difficult pretty fast as it did in the arcade, but we would certainly be open to making NOVICE easier.
Thanks for the feedback!
#84 hermi69 OFFLINE
hermi69
    Space Invader
  • 16 posts
Posted Fri Dec 28, 2018 10:22 AM
awesome! :-o will there be a PAL Version??
#85 johnnywc OFFLINE
johnnywc
  • 2,001 posts
Posted Fri Dec 28, 2018 11:56 AM
Thanks! Yes, there will be a PAL60 version available when the game is released this year. :)
#86 Brian O OFFLINE
Brian O
  • 1,667 posts
  • [THIS SPACE FOR RENT]
Posted Fri Dec 28, 2018 3:17 PM
This year? You better hurry!
#87 johnnywc OFFLINE
johnnywc
  • 2,001 posts
Posted Fri Dec 28, 2018 3:30 PM
LOL I forgot it's *still* 2018! :) WoW Arcade will be released sometime *next* year. :D
#88 MissCommand OFFLINE
MissCommand
    Star Raider
  • 75 posts
Posted Wed Jan 2, 2019 8:06 AM
So over the break I had some time to look at the AtariVox+ and play lots of WOW! After taking taking the casing off I noticed there was some flux around the solder connections so I took some alcohol / hair dryer and cleaned it off. Low and behold everything worked! Played through a whole game of WOW with voice and tried a few other AV+ games as well. Later that evening it was back to the garbled after first level. So I took out the AV+ ICU chips and cleaned those with some alcohol and it was back working again! Later the bad behavior had returned. So one more time, I just applied some alcohol and yep... it was working again. Each time that seems to last around 30 minutes or so...
So I am wondering if this may be a hardware type issue and not  firmware. Any of you electronic guys out there know why it would work after these alcohol / hair dryer sessions and last for 30 minutes or so?
#89 Nathan Strum OFFLINE
Nathan Strum
  • 8,243 posts
  • Enjoying a sandwich
Posted Wed Jan 2, 2019 1:10 PM
Sounds like something could be overheating.
#90 cimmerian OFFLINE
cimmerian
    Moonsweeper
  • 451 posts
Posted Sat Jan 5, 2019 1:14 PM
Maze level editor added to Wizard of Wor!! Amazing work John! :-)
Does anyone know if this is the first instance of being able to save user created information (other than high scores) in an Atari 2600 game? I can't think of another instance off the top of my head.
#91 johnnywc OFFLINE
johnnywc
  • 2,001 posts
Posted Sat Jan 5, 2019 3:12 PM
This is very interesting - thanks for sharing! If you have the time, you should post your findings in this thread where this issue is discussed extensively with people with much more knowledge about the Atarivox than myself, including Richard H. who designed it. :)
Thanks!
#92 cimmerian OFFLINE
cimmerian
    Moonsweeper
  • 451 posts
Posted Sat Jan 5, 2019 3:45 PM
This is a great discovery and I hope I'll be able to replicate your success. I'll give it a try in the next day or so and report back what happened!
#93 johnnywc OFFLINE
johnnywc
  • 2,001 posts
Posted Sat Jan 5, 2019 4:31 PM
Hi James!
Thanks James! I'm glad I was able to squeeze it in. I think it will add replayability to the game. :)
This is the first I know of, although I know Duck Attack will actually save your inventory, etc. so you can continue a game at a later time. But I do believe this is the first to save user created data. :)
#94 MissCommand OFFLINE
MissCommand
    Star Raider
  • 75 posts
Posted Sun Jan 6, 2019 10:23 AM
Let us know... unfortunately it is just a quick fix and only last for 30 minutes or so... at least for me. :_(
#95 MissCommand OFFLINE
MissCommand
    Star Raider
  • 75 posts
Posted Sun Jan 6, 2019 10:27 AM
Thanks!
  Thanks for the link... I am definitely interested in going through and reading that thread!
  I'll move the rest of my posts/testing regarding AVox+ to that thread to keep from muddying the waters further... sorry for hijacking this thread.
Edited by MissCommand, Sun Jan 6, 2019 5:50 PM.
1 user(s) are browsing this forum
0 members, 1 guests, 0 anonymous users
