CO 60472 U29 Atari 800XL
20 replies to this topic
#1 alortegac OFFLINE
alortegac
    Chopper Commander
  • 196 posts
Posted Fri Sep 14, 2018 7:25 PM
Looking to purchase 1 good U29 IC to try bringing a computer with black screen back to life.
After a thorough check with logic probe and testing main ICs on my 5200 ( I do not have another 800Xl to test with), I have narrow my options to bad ROM, U30 and/or U29 delay.
I have a rom and u30 on their way. But I Could not find an U29 anywhere other than Best E.
I was hoping someone in this forum will sell me a good U29.
Thanks a lot!
Al
#2 Nezgar ONLINE
Nezgar
  • 1,667 posts
Posted Fri Sep 14, 2018 7:35 PM
That's BASIC Rev B. For troubleshooting, the computer should run fine without it inserted. Only minor issue is the 8K RAM region will still be allocated to nothing unless you hold option on powerup.
#3 alortegac OFFLINE
alortegac
    Chopper Commander
  • 196 posts
Posted Fri Sep 14, 2018 7:57 PM
Nazgar, I show U5 CO61598 as OS 8k x 8 ROM Rev B and U4 as CO60302 BASIC 16k x 8 OS ROM.
I am looking for a U29 Delay. CO60472.
Or maybe I misunderstood your suggestion.
Thanks,
Al
Edited by alortegac, Fri Sep 14, 2018 8:07 PM.
#4 Rybags OFFLINE
Rybags
    Gridrunner
  • 16,021 posts
Posted Fri Sep 14, 2018 8:06 PM
There are off-the-shelf delay line equivalents but no idea if a current day one exists that's a plugin or easy adaption for the Atari.
#5 Nezgar ONLINE
Nezgar
  • 1,667 posts
Posted Fri Sep 14, 2018 8:40 PM
Nazgar, I show U5 CO61598 as OS 8k x 8 ROM Rev B and U4 as CO60302 BASIC 16k x 8 OS ROM.s
D'oh, yes that is indeed delay line.. Embarassing google-fu failure on my part there.
#6 rdea6 OFFLINE
rdea6
  • 2,797 posts
Posted Fri Sep 14, 2018 8:42 PM
Jumper empty socket pin 6 and pin 7
http://atariage.com/...sion/?p=3535338
Check if it will boot.
#7 _The Doctor__ ONLINE
_The Doctor__
    Flux Capacitor Master Craftsman
  • 6,526 posts
Posted Fri Sep 14, 2018 8:49 PM
you want basic revision c in all Atari computers... B is for buggy, crashes and trashes...
#8 alortegac OFFLINE
alortegac
    Chopper Commander
  • 196 posts
Posted Fri Sep 14, 2018 9:57 PM
I will try jumper on empty socket as suggested.
Quick comment, perhaps could lead on to something else. All D lines from D0 to D7 are High instead of Pulse...accross the boad U4, U5, Pokey, etc.....
Is this significant? Or could it be a symptom/confirm from bad U5 ROM, U29 or U30.? Assuming antic,gtia, cpu worked fine on a atari 5200 test. Ram is all new ics, mutiplexer are new as well.
Thanks for any feedback.
Edited by alortegac, Fri Sep 14, 2018 10:00 PM.
#9 Rybags OFFLINE
Rybags
    Gridrunner
  • 16,021 posts
Posted Fri Sep 14, 2018 10:12 PM
What does the display do?  Most XLs will power up initially reddish brown at least 20% of the time and you'll get a click and change to black within 2 seconds.  If that occurs it's a sign that the CPU should be good and that the OS Rom is at least partly working - if there's a hang after that it's probably bad Ram or select logic.
A steady non-rolling display means Antic is at least able to send the VSync commands to GTIA.  Rolling display can mean a failed Antic.
Edited by Rybags, Fri Sep 14, 2018 10:13 PM.
#10 alortegac OFFLINE
alortegac
    Chopper Commander
  • 196 posts
Posted Sat Sep 15, 2018 6:09 AM
Hi!
I get a brownish/black screen when I turn it on every time and all the time. No signs of any clicks, mode steps/changes, no blinking, no sounds..
I tried the jumper on pin 6-7 empty U29. No change at all.
Turning a bit the Color control does not make any difference either.
Edited by alortegac, Sat Sep 15, 2018 6:19 AM.
#11 alortegac OFFLINE
alortegac
    Chopper Commander
  • 196 posts
Posted Sat Sep 15, 2018 6:17 AM
Antic worked fine in a 5200. Appears to be good. Gtia and cpu as well. I understand this is not the best test but all I can do with what I have.
Thanks!
Edited by alortegac, Sat Sep 15, 2018 6:17 AM.
#12 1050 OFFLINE
1050
  • 1,084 posts
Posted Sun Sep 16, 2018 3:55 AM
R23-30 on the 800XL pull the data lines high so it's
not unusual to see that unless you were expecting data.
How can a machine function if it's not using data?
It can't.
Without a working U29 you have no ram or even stack
for the CPU. The CPU is likely stuck doing something
internal forevermore?
Best is probably the only one that stocks it, so outside
of killing other Atari for it there is the below circuit
that is supposed to be the equivalent. I got this from
across the pond from a site where they don't speak
english.
And I didn't save the url for it either so you could
find it today. At any rate it is using one 74LS14 Hex
Inverter with Schmitt Trigger Inputs plus a handful of
discrete parts such as resistors and capacitors to
generate time delayed signals that purportedly work
as well as the stock U29. I've never built it so I've
never tested it to see if it does work. I can see that
it does have potential too or I never would have saved
it.
http://www.futurlec....LS/74LS14.shtml
Only thing wrong with your swap it method is the lack
of a full complement of ammo to work with. It is the
fastest way to find a faulty IC that there is. And
almost anybody can do it.
#13 Rybags OFFLINE
Rybags
    Gridrunner
  • 16,021 posts
Posted Sun Sep 16, 2018 7:26 AM
The eventual outcome of a runaway situation is usually execution of an illegal "kill" opcode, so "The CPU is likely stuck doing something
internal forevermore?"
is a pretty true description since the internal 6502 PLA Rom tables cause certain instructions to put the CPU into a nonrecoverable idle state https://www.pagetable.com/?p=39
#14 1050 OFFLINE
1050
  • 1,084 posts
Posted Sun Sep 16, 2018 9:47 AM
If you don't have phase 2 clock on pin 1 of U29
with a pulse then the problem is even more rudimentary
with phase 2 clock and U29 might be an innocent here.
Lack of phase 2 clock would be a bad U18, a 74LS08 AND
chip. I do strongly suggest it be replaced with 74HCT08
AND chip for the better/stronger clock signal shape
that this chip will provide over the LS version. HCT08
even when it's not a problem is the rule in my house.
OR the lack of phase 2 clock could be a bad ANTIC U7.
Short list.
I see where your swapping to a 5200 should have ruled
this one out entirely.
Further, pins 6 and 8 of U30 need to be showing some
logic state changes in order for ram to work as well.
U29 is not solely responsible for no ram situation
which is what you have when all data lines are high
on the 800XL.
#15 mytek ONLINE
mytek
  • 3,295 posts
Posted Sun Sep 16, 2018 10:21 AM
Better still, use a 74F08 :).
#16 alortegac OFFLINE
alortegac
    Chopper Commander
  • 196 posts
Posted Sun Sep 16, 2018 12:38 PM
If you don't have phase 2 clock on pin 1 of U29with a pulse then the problem is even more rudimentarywith phase 2 clock and U29 might be an innocent here.Lack of phase 2 clock would be a bad U18, a 74LS08 ANDchip. I do strongly suggest it be replaced with 74HCT08AND chip for the better/stronger clock signal shapethat this chip will provide over the LS version. HCT08even when it's not a problem is the rule in my house.OR the lack of phase 2 clock could be a bad ANTIC U7.Short list.I see where your swapping to a 5200 should have ruledthis one out entirely.Further, pins 6 and 8 of U30 need to be showing somelogic state changes in order for ram to work as well.U29 is not solely responsible for no ram situationwhich is what you have when all data lines are highon the 800XL.
Thank you so much for your response.
I swapped U18 for a fresh IC I had in my stash. I read all U18 pins again with the probe, they are still all correct. Still no change.image.jpg image.jpg image.jpg
As I said before (I think), I have a new ROM U5 and a U30 on the way.
Thanks a lot!
Edited by alortegac, Sun Sep 16, 2018 12:54 PM.
#17 1050 OFFLINE
1050
  • 1,084 posts
Posted Mon Sep 17, 2018 12:13 AM
U29.
U30 is just the puppet of U29.
#18 alortegac OFFLINE
alortegac
    Chopper Commander
  • 196 posts
Posted Wed Sep 19, 2018 12:45 PM
Well, it is not the ROM chip or U30. I just ordered a U29 from Best. I will report back once I receive it.
Thanks!!!
#19 alortegac OFFLINE
alortegac
    Chopper Commander
  • 196 posts
Posted Fri Sep 21, 2018 2:27 PM
Thank you so much all!! Your support throughout this process has been tremendous!!!
Computer with all black screen of death. Is now Alive and well!!!
....the last and final suspect was U29. And it was the sole culprit apparently. Why did it fail? I do know. All seems ok now.
Thanks so much all!!!
Al
#20 _The Doctor__ ONLINE
_The Doctor__
  • 6,526 posts
Posted Fri Sep 21, 2018 2:55 PM
as usual it comes down to delay line or mmu or memory...
glad to see it working
https://atariage.com...472-delay-line/
#21 alortegac OFFLINE
alortegac
    Chopper Commander
  • 196 posts
Posted Fri Sep 21, 2018 3:40 PM
Thank a lot! This is the pic. All put back together. :)
Edited by alortegac, Fri Sep 21, 2018 3:40 PM.
