TIPI and Mass Transfer
49 replies to this topic
#1 BeeryMiller OFFLINE
BeeryMiller
    Dragonstomper
  • 733 posts
Posted Wed Sep 19, 2018 8:06 PM
I've been making progress and now have Mass Transfer (40 columns) talking with Telnet BBS's using TIPI.  I ran out of time this evening to get the XMODEM transfer code completed, but it is very close to be done.
After the XMODEM code is done, I am going to tackle the phone directory.  First goal is to get Telnet BBS's listed in the directory.
I will have the following BBS's in the directory:
9640NewsBBS.ddns.net:9640
Fusionbbs.ddns.net:9640
Heatwave.ddns.net:9640
If you have others you want listed in the default listing, please post their URL and port numbers here.
There will have to be some XB recoding "I think" for the phone make/edit utility at some point in time.  It will initially be easier to sector edit the phone list first to confirm the assembly coding is working, then work on the XB coding as needed.
So, please post any BBS's that are Telnet accessible you want listed.
Beery
#2 --- Ω --- OFFLINE
--- Ω ---
    HexaCoreRunner
  • 13,179 posts
Posted Wed Sep 19, 2018 8:11 PM
Looking forward to the 80 column color ANSI version with Xmodem and dialing menu!
#3 BeeryMiller OFFLINE
BeeryMiller
    Dragonstomper
  • 733 posts
Posted Thu Sep 20, 2018 5:01 AM
If I only had an 80 column F18 V2 (or V1) capability, or if the TIPI worked with the stock Geneve.
Beery
#4 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,298 posts
Posted Thu Sep 20, 2018 11:58 AM
I changed my signature line so that my BBS url cannot be scraped as a direct link.  I had been getting a lot of router hits and they have subsided since changing it.  I don't know if it is coincidence but they were impacting my connectivity for a while.
#5 arcadeshopper OFFLINE
arcadeshopper
  • 3,936 posts
Posted Thu Sep 20, 2018 6:30 PM
Beery
thekeep.net 23
#6 BeeryMiller OFFLINE
BeeryMiller
    Dragonstomper
  • 733 posts
Posted Wed Sep 26, 2018 5:15 AM
I got the 4 BBS's listed above added to a dialing directory, and got the phonebook working last night.  As far as the extended basic program that adds entries, etc., that will come a bit later.  At present, I just sector edited the PHONE1 file.  Next, need to add some code if the telnet connection is busy.  Not an issue with my BBS as I have my BBS setup with 20 inbound connections.  Everyone else has I think only a single connection.
After that, then a manual way from within Mass Transfer to dial a new website.  Not hard.
Then, Tim's request for the toggle for the IAC character and toggle for TI/Myarc mode.  Then, need to redo some menus.
Beery
#7 BeeryMiller OFFLINE
BeeryMiller
    Dragonstomper
  • 733 posts
Posted Thu Sep 27, 2018 7:35 AM
OK, I have  4 websites configured in the Phone directory at present (9640News, Fusion, HeatWave, The Keep).  I've got Xmodem implemented.
I have not tried saving files to TIPI's DSKx drives yet, rather to actual 5.25" floppies.  Need to test/see if that works to TIPI's DSK directories.
It is 40 columns, no ANSI.  I do not have source for any ANSI terminal emulators with Xmodem capability.
Question for TIPI users, will anyone use Mass Transfer with the Phone directory and Xmodem capability?
Trying to figure out how much I need to polish up the program for release.  I will release the source code so others can implement TIPI's communications in assembly for their programs, etc.
Beery
#8 --- Ω --- OFFLINE
--- Ω ---
    HexaCoreRunner
  • 13,179 posts
Posted Thu Sep 27, 2018 8:02 AM
I used to use the F18A version of TIMXT when I still used a UDS-10 with an RS-232.  I loved the phone directory, even if it had to be modified with a sector editor.  Currently, as a TIPI user I've been using the TELNET program that comes with TIPI. It's great as it handles the ANSI graphics in 80 columns perfectly.  Sadly though there is no Xmodem file transfer capability or dialing menu.
My 'ultimate' wish list' for a TIPI compatible terminal program for the TI...
1) 80 Column ANSI graphics.
2) Fully editable dialing menu (similar in design and application to Telco's).
3) Xmodem file transfer capability (It's been a while since I've been able to upload to the BBS).
4) Macros (auto scripting the login to the BBS would be nice).
#9 FarmerPotato OFFLINE
FarmerPotato
    Chopper Commander
  • 178 posts
Posted Thu Sep 27, 2018 10:41 AM
Hi Beery,
your post inspired me to spend all day Saturday trying to bring up a telnet TI-Net BBS.
most of that was troubleshooting my Lantronix (an ETS-4P model). My current router, ASUS RT68U, doesn't like it!  Wireshark shows that Lantronix convinced ASUS to rename my Roku to ETS-4P-xxxxx (at a completely unrelated DHCP IP!) while pointing out that all the Lantronix DHCP packets have framing errors.
I sort of got it working, but I think it will be easier to ditch the Lantronix and just connect NanoPEB to my Centos box and write a tiny server program. Lantronix is nice in that it implements DSR/DTR just like a modem.
Next Saturday maybe.
#10 BeeryMiller OFFLINE
BeeryMiller
    Dragonstomper
  • 733 posts
Posted Thu Sep 27, 2018 10:58 AM
I wonder if you got a WiModem232 whether that would be better than the Lantronix setup.  I've got a WiModem232 on my Geneve and would prefer to be using the TIPI if it would work on a stock Geneve, but sadly, the issue has not been resolved yet and Matt doesn't have the hardware to figure it out.
#11 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,298 posts
Posted Thu Sep 27, 2018 11:44 AM
tcpser works well to provide functionality similar to the UDS device.  Some time ago, Shift838 provided me with a version that sorted out the IAC Telnet issues.  I use tcpser with a real serial port on one of my old Shuttle SFF PCs whenever I want to connect my nanoPEB to the outside world.  I also have the wimodem232 for my Geneve.
#12 arcadeshopper OFFLINE
arcadeshopper
  • 3,936 posts
Posted Thu Sep 27, 2018 12:35 PM
Proper ANSI too, Matt and I went back and forth a few times with  TELNET to get it to work correctly with the ANSI on my BBS
Greg
#13 BeeryMiller OFFLINE
BeeryMiller
    Dragonstomper
  • 733 posts
Posted Sat Sep 29, 2018 8:46 PM
I have just added to the top subject in this area an upload that includes TIPI with uploading and downloading capabiltiy along with a phone directory.
Includes source code as well.
Beery
#14 BeeryMiller OFFLINE
BeeryMiller
    Dragonstomper
  • 733 posts
Posted Sat Sep 29, 2018 8:54 PM
Tim,
I found the last "glitch" this evening with using the TIPI.  Everything would work fine on my BBS downloading files, but on either Fusion or Heatwave, I kept getting all kinds of errors.  Finally, it dawned on me I was not testing if I had received a character.  With my BBS on a Windows 10, the PI was buffering the block that was being transferred.  However, with Heatwave and Fusion, the TI on my end was waiting on characters from those BBS's as they could not pump out the data quick enough.
So, I did successfully transfer multiple files from Heatwave and uploaded a couple of files to the test area.
It should be good to go now.
Beery
#15 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,298 posts
Posted Sat Sep 29, 2018 9:42 PM
Nicely done. If the TI had a direct network connection instead of a serial port to the outside world, we could eek out more speed. Nothing like a PC, of course :)    Thanks for uploading the source for everyone to look at and learn from.
#16 arcadeshopper OFFLINE
arcadeshopper
  • 3,936 posts
Posted Sun Sep 30, 2018 2:42 PM
wow well ok it works..but SOOOSLOWWWWW
Like 110 baud  TELNET Is usually faster than 19200
#17 BeeryMiller OFFLINE
BeeryMiller
    Dragonstomper
  • 733 posts
Posted Sun Sep 30, 2018 2:48 PM
It is working within the limitations of Mass Transfer. TIPIs get and receive character routines require more CPU cycles than direct addressing of the RS232 port.
It does do XMODEM file transfers and has a phone directory for BBS Telnet sessions which nothing else has at present.
I would have thought the screen displays is running close to 2400 baud, but that is me. If you are really seeing stuff you think is at 110 baud, then I think something else may be going on.
What hardware do you have in your system? PEBox TIPI or sidecar TIPI?
Beery
#18 arcadeshopper OFFLINE
arcadeshopper
  • 3,936 posts
Posted Sun Sep 30, 2018 2:58 PM
sidecar .. It should be identical Ill test on the peb as well.
also it seems to answer my bbs's auto ansi detect and then doesnt do ansi
#19 arcadeshopper OFFLINE
arcadeshopper
  • 3,936 posts
Posted Sun Sep 30, 2018 3:28 PM
[quote name="arcadeshopper" post="4124489" timestamp="1538341092"]
https://photos.app.g...ZTmKW3uEtAgYGv5
an example it works fine just very slow
Sent from my LG-H872 using Tapatalk
#20 BeeryMiller OFFLINE
BeeryMiller
    Dragonstomper
  • 733 posts
Posted Sun Sep 30, 2018 4:36 PM
I see what you are talking about.  it does not behave like that on my system, so something must be very different.
Let me know how the TIPI-PEBox version test proceeds.
What version of the Raspberry PI do you have? How does the TIPI client behave in regular 40 column mode (non-ANSI)?  I am using a Version 3.
If your TIPI-PEBox version runs faster than than the sidecar version and you are using different Raspberry PI's, then I think it is time to swap the PI's around and see if things change.
We need to get some feedback from some other Raspberry PI users with Mass Transfer to see if there is something we can isolate unique between your system and mine.
Myself, I have a HRD, HFDC, Myarc 512K, TIPI, with NO RS232 card in the system.
Beery
#21 --- Ω --- OFFLINE
--- Ω ---
    HexaCoreRunner
  • 13,179 posts
Posted Sun Sep 30, 2018 5:42 PM
Beery, send me a copy in ZIP format and I'll try it out and get back to you with my results.
#22 BeeryMiller OFFLINE
BeeryMiller
    Dragonstomper
  • 733 posts
Posted Sun Sep 30, 2018 7:02 PM
Hopefully this works.
#23 --- Ω --- OFFLINE
--- Ω ---
    HexaCoreRunner
  • 13,179 posts
Posted Sun Sep 30, 2018 9:05 PM
It works.  Sorry for the bad typing in the video, but honestly from a speed perspective it's not bad at all.
I'm using an the P-Box TIPI RPi 3.  Besides the TIPI, the only other non standard cards in my box are a 1024K SAMS and a CorComp Triple Tech.  I've also removed the RS-232 cards.
Wow... it feels weird going back to 40 columns in two colors.
#24 arcadeshopper OFFLINE
arcadeshopper
  • 3,936 posts
Posted Mon Oct 1, 2018 1:23 AM
Ok it's much faster on his system than it was on mine..
#25 BeeryMiller OFFLINE
BeeryMiller
    Dragonstomper
  • 733 posts
Posted Mon Oct 1, 2018 11:24 AM
if the speeds are not the same, then we (I) need to ask:
1.  What version of the Raspberry PI do you have?
2.  Are you using side card or PEBox TIPI?
3.  What devices do you have attached?
I did leave some RS232 code in the software for log buffers/printing.  On my system, the RS232 card was pulled, not an issue.  If users are seeing something slow, compare with and without an RS232 card in the system as I could see no other reason for the system to be running at different speeds.
Does anyon if the sidecar 32K that is working with the sidecar TIPI, has the same memory speeds?  Just wondering if there could be an impact on memory speeds slowing things down.
Beery
