The Mummy's Tomb
53 replies to this topic
#1 Retrospect OFFLINE
Retrospect
  • 1,139 posts
Posted Thu Sep 20, 2018 11:26 AM
This is the final revision of my game.  It's got all sorts of extra stuff thrown in now including a bonus stage between levels where you have to jump over snakes in a tunnel on your way to the next room.
EA5 files for download here;  can be turned into a cartridge bin file too.
Attached File  newmummytomb.zip   2.82MB   15 downloads
Attached File  newtomb.png   286.85KB   5 downloads
Edited by Retrospect, Sun Sep 23, 2018 11:29 AM.
#2 adamantyr OFFLINE
adamantyr
  • 1,471 posts
Posted Thu Sep 20, 2018 11:41 AM
Nicely done! I love the opening title screen, although if you got speed mode turned on in Classic99 it zips right by...
#3 Retrospect OFFLINE
Retrospect
  • 1,139 posts
Posted Thu Sep 20, 2018 3:10 PM
You might have a previous version of Classic99 whereby the CPU Throttle mode does that sort of thing?  The latest version solves that.
Have you managed to collect all 20 pieces of treasure?  I can't!  I had to cheat to do it.
To cheat, break the program and type
200 CALL COLOR(12,16,1)
#4 adamantyr OFFLINE
adamantyr
  • 1,471 posts
Posted Thu Sep 20, 2018 3:16 PM
I do have an earlier version indeed. :) I'll be sure to upgrade.
I only played it once, I'm technically at work. :D But yes, it IS very difficult. Unless someone has a very good eidetic memory, it's probably going to be difficult to win without cheating.
A suggestion on how to bypass that is to have individual traps "flash" occasionally. That way even after both torches are expended you have a means of potentially seeing a trap before walking into one. Coding wise, you'd probably have to store the coordinates of all the traps (two string arrays for row and column would work) So you could do a quick flash, maybe when a counter value runs to zero on your main loop.
#5 Retrospect OFFLINE
Retrospect
  • 1,139 posts
Posted Thu Sep 20, 2018 3:20 PM
Well ... there's an old game called "Chalice" which has you moving through old ruins of a temple in the night time during a thunderstorm, and that game flashes the walls of the temple up everytime there's a thunderclap.  Then back to darkness.  I guess it would be easy to do this for my Mummy's Tomb game?  Each time the player (or the mummy) makes a move, say two variables are paired (R1=INT(4*RND)+1 and R2=INT(4*RND)+1) and if R1 is same as R2 then CALL COLOR(12,16,1) for just a split second then back to black. See the way I think is that having a constant timer running in a stock TI Basic game could slow down gameplay by 50 percent easily   :)
EDIT:
Just tried it.  Makes game too easy!
Edited by Retrospect, Thu Sep 20, 2018 4:08 PM.
#6 arcadeshopper OFFLINE
arcadeshopper
  • 4,274 posts
Posted Fri Sep 21, 2018 11:17 AM
bad value in 2010 when i got mummied
and 2040 looks like they are call char when they should be hchar?
#7 Retrospect OFFLINE
Retrospect
  • 1,139 posts
Posted Fri Sep 21, 2018 2:09 PM
Damn ... Thanks for the error report.  I'll fix it up soon enough.  Right now, I'm compiling a version that runs in XB and it's great.  It'll be on here and on the facebook groups real soon.
#8 adamantyr OFFLINE
adamantyr
  • 1,471 posts
Posted Fri Sep 21, 2018 2:12 PM
EDIT:
A common problem in game design. :) Coming up with the right balance of difficulty!
#9 Retrospect OFFLINE
Retrospect
  • 1,139 posts
Posted Fri Sep 21, 2018 3:17 PM
Attached File  mummyXB.zip   17.19KB   14 downloads
Here's the 32K Extended Basic version (there's an EA5 version in the folder too)
Enhancements:
Animated sequence where the man blows a hole in the pyramid to get into it, on the title screen
Better sounds
There's 3 mummies on the rampage in the tombs
Everytime you succeed in collecting all the treasure you "level up" and different style treasure with different colours appear in the next room. (Will not change after level 10 but you'd have to be insane to GET to level 10)
There's sometimes more than two torches in the room
High score will score up to 32767 (you'll basically never get that far)
Each time you level up there's more treasure and more traps in the rooms!
The lengthy title screen music will play only once and then when you die and it goes back to title screen it's silent so you can get straight back into the game
Happy Friday! :)
Edited by Retrospect, Fri Sep 21, 2018 3:20 PM.
#10 arcadeshopper OFFLINE
arcadeshopper
  • 4,274 posts
Posted Fri Sep 21, 2018 3:39 PM
39..level 2.. very nice Joe!
#11 Retrospect OFFLINE
Retrospect
  • 1,139 posts
Posted Fri Sep 21, 2018 3:51 PM
Thanks Gregory.  I had the same highest score.  It shows no mercy when you're on your last life you can guarantee you'll hit a trap!
#12 Vorticon OFFLINE
Vorticon
  • 3,611 posts
Posted Fri Sep 21, 2018 4:35 PM
Fun game :) You really churn these projects out don't you!
#13 Retrospect OFFLINE
Retrospect
  • 1,139 posts
Posted Fri Sep 21, 2018 4:49 PM
Cheers Vorticon.  Aye, I like to have a dabble now and then. :)
#14 arcadeshopper OFFLINE
arcadeshopper
  • 4,274 posts
Posted Fri Sep 21, 2018 6:48 PM
here is a cart bin
score 69 level 4 later levels you seem to finish without getting all the treasures dunno if that's by design
#15 Retrospect OFFLINE
Retrospect
  • 1,139 posts
Posted Fri Sep 21, 2018 6:54 PM
here is a cart bin
Thanks Gregory, and for the cart bin .... it's not by design no ... seems something might have cropped up ... well, I'm just sat finishing off the "final" version now, with 6 lives, 4 mummies, extra text, extra music, and I know why it's doing what it does it's just struck me now!  When you progress to the next level, there's more treasure and more traps.  The only thing that didn't get "more" was the counter for the treasure it's stuck at 20!!!  Darn it.  Hey thanks for the heads up.  This'll be fixed real quick :)
If anyone would like to put my finalized version on any sites feel free.  It's shareware.  It'll be ready in about half hour!
#16 senior_falcon OFFLINE
senior_falcon
  • 1,413 posts
Posted Fri Sep 21, 2018 8:34 PM
Very nice! A couple of suggestions:
-You might want to restore the instructions that were in the TI BASIC version.
-It might be interesting to have the sound of footsteps that started to echo more strongly when you got near a trap. (I take it the traps are holes that you fall into, so an echo would make sense.)  You wouldn't know if the trap is in front of you or to the sides so this may not convey any useful information. Food for thought.
-If you haven't already done so, make sure you can't get trapped by the initial setup. i.e. you're in the upper left corner with traps to the right and below.
Just scored 89. Pretty sure the max score of 32767 is safe!
#17 Retrospect OFFLINE
Retrospect
  • 1,139 posts
Posted Fri Sep 21, 2018 8:40 PM
Thanks for trying the game, Senior_Falcon. :)
Yeah, the instructions are back in the game now, at least a sort of prologue text anyhow .... (forthcoming finalized version) .... as for the footsteps thing, it would be a bit beyond my scope to do so, at least it would bump up the byte count a little too far, the way it's all coded.  I've redone some things, there's 6 lives now, randomly a heart will appear that is an extra life, there's a way to tell where the traps are too if you have chance to watch the movement of the mummies (there's four of them in this new version coming up) ... they will skirt around the traps ... it's see-able just about.  :)
#18 Retrospect OFFLINE
Retrospect
  • 1,139 posts
Posted Fri Sep 21, 2018 8:50 PM
Attached File  TOMB32K.zip   19.51KB   16 downloads
Thanks to everyone who played so far. And again to Gregory for pointing out an issue the previous version had which has been fixed now.
Senior_Falcon's footsteps volume idea is excellent.... but too difficult for me to work into the code... but there are now six lives, and a random chance of a heart symbol appearing in the tomb for another life plus you get a bonus life every level you get through.
Watch the motion of the mummies, (all four of them!) they do skirt around the invisible traps.
Sometimes you get three torches in the tomb to help you out more.
Text added as a prologue/instructions type thing.
Music and text will play the first time you play the game then if you play again in the same session it skips this and just goes to the animation where Mr Banner fires the TNT to blow his way into the Pyramid.
Also if you've ever watched any of the old Mummy films you'll recognise the music I've used. :)
#19 arcadeshopper OFFLINE
arcadeshopper
  • 4,274 posts
Posted Fri Sep 21, 2018 11:53 PM
updated cart image
#20 Retrospect OFFLINE
Retrospect
  • 1,139 posts
Posted Sat Sep 22, 2018 5:12 AM
updated cart image
nice one Greg, tried to do it myself but I always fail! lol
#21 Vorticon OFFLINE
Vorticon
  • 3,611 posts
Posted Sat Sep 22, 2018 9:12 AM
Game up on the tigameshelf.net site :)
#22 arcadeshopper OFFLINE
arcadeshopper
  • 4,274 posts
Posted Sat Sep 22, 2018 10:51 AM
with modulecreator it's pretty damn easy.. you just have to convert the files to be v9t9 as Fred only uses that format..  I put the files in a folder under c:\modulecreator\ then use ti99dir to convert them to v9t9.. then run it.. works every time
Greg
#23 Retrospect OFFLINE
Retrospect
  • 1,139 posts
Posted Sun Sep 23, 2018 11:30 AM
last revision, i promise!
I just couldn't help myself putting in a bonus stage with the few bytes I had left for code among other things.
Attached File  newmummytomb.zip   2.82MB   18 downloads
#24 arcadeshopper OFFLINE
arcadeshopper
  • 4,274 posts
Posted Sun Sep 23, 2018 5:11 PM
one more time!
#25 1980gamer OFFLINE
1980gamer
    Dragonstomper
  • 984 posts
Posted Sun Sep 23, 2018 6:19 PM
in latest version of Classic99,  this bin does not LOAD, that is after selecting the new cart, it is not inserted.  Only 1 option on the menu.
I tried a few other bin's with no problem.
thanks.
