How do we assign the extra w/r SC RAM?
5 replies to this topic
#1 ultima OFFLINE
ultima
    Chopper Commander
  • 216 posts
Posted Thu Sep 27, 2018 1:12 PM
 I have been experimenting with SC RAM and can't for the life of me figure out how to assign and change values
I tried this first I tried to assign w with  "w127=1 " then check it later with "if r127=1 then goto __ModdedHKVP70" for a comparison and that came up short.
Am I missing something?
#2 Gemintronic ONLINE
Gemintronic
    Jason S. - Lead Developer & CEO
  • 9,315 posts
Posted Fri Sep 28, 2018 11:11 AM
No idea without seeing your actual code.  But, re-reading Random Terrains reference I'd play it safe by loading SuperChip variables into normal variables THEN doing any math.  Maybe overkill but.. yeah.
http://www.randomter...ml#superchipram
#3 Random Terrain OFFLINE
Random Terrain
    Visual batari Basic User
  • 28,964 posts
  • Controlled Randomness
    Replay Value
    Nonlinear
Posted Fri Sep 28, 2018 1:44 PM
You'd have a hard time with 127 because that's always used by the playfield if I read the bB page correctly. Look at the charts to see what special variables are available depending on what number you use with pfres:
randomterrain.com/atari-2600-memories-batari-basic-commands.html#superchip_charts
pfres
#4 ultima OFFLINE
ultima
    Chopper Commander
  • 216 posts
Posted Fri Sep 28, 2018 3:11 PM
I thought when I read the page that 127 would be the one to start with I'll try w001 and see if changing it to the other end works as soon as I get home. Will post an update later thanks guys.
#5 Random Terrain OFFLINE
Random Terrain
  • 28,964 posts
    Replay Value
    Nonlinear
Posted Fri Sep 28, 2018 3:18 PM
Yeah, it seems to go backwards.
#6 ultima OFFLINE
ultima
    Chopper Commander
  • 216 posts
Posted Sat Sep 29, 2018 9:30 AM
w000 worked after re-reading about it a pfres 24 playfield allows 000-031 Thanks RT. I also found you can clear SC variables with
  asm
  LDA #0
  STA W000 ; add SC variable here
end
**I just realized that stella shows the ram you can use :)
Edited by ultima, Sat Sep 29, 2018 2:07 PM.
