"Weird & Bizarre" -- Modification ideas for the TI
17 replies to this topic
#1 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 14,012 posts
Posted Sat Sep 29, 2018 5:56 AM
Here's one you'll probably never see...
A "truly portable" TI!
Imagine if you will, a TI console devoid of all external connections.
AUDIO & VIDEO
Inside would house an F18A MKII hooked to a wireless HDMI transmitter.
POWER
The bottom of the case would be replaced with a 3D printed replacement giving it an extra inch or so of space... for a grouping of flat lithium batteries.
For the gamer types, a modified TI like that with a FinalGROM and a 32K sidecar would be the bomb.
#2 atrax27407 OFFLINE
atrax27407
  • 1,272 posts
Posted Sat Sep 29, 2018 7:25 AM
See MICROpendium 3/1, 7/1, and 8/1/89. A similar project has already been done.
#3 Ksarul OFFLINE
Ksarul
  • 5,319 posts
Posted Sat Sep 29, 2018 8:40 AM
I've seen that original modified TI demonstrated at a MANNERS meeting back in 1989-1990 or so. . .
#4 Airshack OFFLINE
Airshack
  • 1,029 posts
Posted Sun Sep 30, 2018 8:31 PM
This may be better in a completely new form factor with laptop style LCD display connected. Add a fully loaded FinalGROM plugged in and a Shift838 remote control panel installed you wouldn’t need access to the cartridge port. 32k sidecar included and F18A with USB port for keyboard.
We could use something like this at the VAST meetings. Totally do-able with available parts.
Get on it Omega!
Sent from my iPhone using Tapatalk Pro
#5 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 14,012 posts
Posted Sun Sep 30, 2018 9:26 PM
Get on it Omega!
Too many irons in the fire at the moment.  You first!
#6 twoodland OFFLINE
twoodland
    Moonsweeper
  • 277 posts
Posted Mon Oct 8, 2018 6:54 PM
Greetings Professor Falken...
Recently, I have been enjoying my quest for the best ANSI terminal configuration.  I would like to see an updated terminal emulator cartridge that includes an updated terminal emulator program that supports 40,80 column (native & F18A), ASCII & ANSI terminal emulation, Baud rates from 300 to 256000 bits per second, the TEII Speech GROM capability, and finally the ability to tap into the speech from the terminal program.  I would like to see TI BBS's that are speech capable (like in the movie "War Games").  Not just reading text copied to a clipboard but an actual speech command that could be sent from the BBS which would contain the phonetic spelling of what is being displayed on the screen.  I think this would set apart the TI from all other vintage computers giving another reason to continue to enjoy this hobby and community.  Hopefully it would support configurations of just a sole stock console, to a TIPI configuration and other popular configurations in between.
Edited by twoodland, Mon Oct 8, 2018 7:25 PM.
#7 Airshack OFFLINE
Airshack
  • 1,029 posts
Posted Mon Oct 15, 2018 12:08 AM
I wrote a Wargames-style title Back in 1980 called “NukeWar” I believe. I’m still trying to find a copy online.
#8 twoodland OFFLINE
twoodland
    Moonsweeper
  • 277 posts
Posted Wed Oct 17, 2018 5:03 PM
Did BBS software ever have the capability to use speech or is it vaporware?  I know the War Games movie used recordings of actor John Wood's voice through a vocoder, but has this capability ever existed? I would imagine that both the BBS server and terminal emulation client software would have to support the method to send speech commands (maybe via ANSI escape codes?).  I know about ANSI music, but do not know if there are codes available in the ANSI spec to send commands to the client software that could be used for speech.  I am also guessing that both the BBS server and client would need to support specific speech commands for certain hardware.
It would be awesome to have a BBS speak to you though...
#9 Tursi OFFLINE
Tursi
  • 5,666 posts
  • HarmlessLion
Posted Wed Oct 17, 2018 7:38 PM
Terminal Emulator 2 could read the screen, as could many other terminals that came later. I don't know if there was any protocol convention for side-band speech though (that is, not reading the screen but speaking independently...). The TE2 protocol had a lot in there, though, was speech? :)
#10 JB ONLINE
JB
  • 9,305 posts
  • With Stereo-Of-The-Art-Sound
Posted Wed Oct 17, 2018 8:01 PM
I believe the provision was there. Can't swear to it off-hand, though.
#11 FarmerPotato OFFLINE
FarmerPotato
    Moonsweeper
  • 358 posts
Posted Thu Oct 18, 2018 8:55 AM
Yes, speech was in there.
The TE2 protocol manual http://atariage.com/...121-te2-manual/
http://www.whtech.co...ocol_manual.pdf
The command opcodes for speech:
>26 Speak and display text
>27 Speak text without display
>28 Speak Allophones (refer to TE2 manual)
>29 Look up words (and associate with a number)
>2A Speak words associated with numbers
Text must be from the Speech ROM, or an allophone string (not sure if this means plain text, or preprocessed into allophone numbers by Text-to-Speech utility). I don't think there is a routine to play back LPC data (like from SPGET.)
#12 BeeryMiller OFFLINE
BeeryMiller
    Dragonstomper
  • 955 posts
Posted Thu Oct 18, 2018 9:42 AM
There was one BBS back around 1984 out of Florida that utilized the full features of the TE2 cartridge.  It played music, graphics, and speech.  As a college student, I sent the guy that had developed it something like $60 or $80 for the software and got ripped off as he never sent me anything in return.  I've got his name written down somewhere. Somewhere in the 90's, I think I recall seeing the guy had a number of legal issues.  I was pretty bummed out as that was a LOT for me at the time.
I do know, though I do not know if it works, Tim's ANSI interpreter code has something with music capability as it was part of the ANSI standard.  I saw some information out there suggesting the ANSI music code sequence conflicted with another ANSI sequence.  To date, I do not think I have ever seen a BBS with ANSI music.
As far as speech for the TI, one would need to be able to run an assembly language coded emulator, while having the TE2 cartridge plugged in.  The TIPI would allow something like that to load from Basic.  The use of the TE2 emulator software kills its use if you want ANSI or 80 column capability.  If you are really trying to use speech for what comes across the screen, you would really be limited to 300, maybe 1200 baud on any emulator.  To me, that would be unbearable.  For a blind person, not so.  Hopefully, no members here are going blind.
Beery
#13 BeeryMiller OFFLINE
BeeryMiller
    Dragonstomper
  • 955 posts
Posted Thu Oct 18, 2018 9:49 AM
Much of what you are requesting is in Telco outside of speech and 256,000 baud capability.  Any terminal emulator for RS232 in the best of circumstances will peak out at baud rates of 57.6K with generally, 38.4K being the maximum.
Anyone have a feel under what the best of circumstances the maximum throughput speed of the TIPI would be?  I do not have a handle on how much overhead the DSR has with character/string handling versus direct serial i/o through the RS232 port to know if effective speeds are faster or slower.
One also has to keep in mind regarding what one does with a big transfer block of data.  Does one write it to the screen, save it to a file, etc.  We only have so much free space of memory depending upon the program and something has to be done with it it gets sent to us.
Beery
Edited by BeeryMiller, Thu Oct 18, 2018 9:50 AM.
#14 willbilly OFFLINE
willbilly
    Space Invader
  • 39 posts
Posted Thu Oct 18, 2018 3:36 PM
TMS 34020 graphics card for the PEB has been bouncing around my noggin for some time.
#15 twoodland OFFLINE
twoodland
    Moonsweeper
  • 277 posts
Posted Sat Oct 20, 2018 5:43 PM
Wow! the TE2 protocol is so cool!  I wish that I could have used a host BBS that utilized it's capabilities!  Is there a possibility of creating a new updated version that supports faster baud rates?
#16 twoodland OFFLINE
twoodland
    Moonsweeper
  • 277 posts
Posted Sat Oct 20, 2018 6:01 PM
Beery
I am so anxious to use TELCO!  Arcadeshopper is sending me a disk (Thank you Arcadeshopper!!).  38.4k would be fantastic!  Any chance of incorporating the TE2 protocol speech capability into or in tandem with TELCO?
Maybe I am wanting the TI to do something it just was not designed to do.  I am excited to get a TIPI to see how it can be incorporated!
#17 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 14,012 posts
Posted Sat Oct 20, 2018 6:48 PM
I hate to bust anyone's bubble, but 4800 baud is about the absolute maximum your likely to get out of Telco.  Other than the emulations it comes with, I've never seen or heard of any hacks for Telco.
#18 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,467 posts
Posted Sat Oct 20, 2018 7:58 PM
I remember a Milwaukee BBS in the 80s that used TE2 protocol.  It was called The Prancing Pony, themed after Tolkien's world from Lord of the Rings.  It had speech, color, and more from what I recall.  Although I can't be 100% certain,I think it was this same BBS that upon login 'spoke' to you with the words "Welcome to the best TI BBS".
With other terminal emulators coming available - like FastTerm,Mass Transfer, Telco, Triad, and others -  there was better emulation, faster speeds, and a way to transfer files from most any system using Xmodem.  It helped that these programs could be shared and updated unlike the static TE2 cartridge.
