Cant get 3.5" floppy to work
20 replies to this topic
#1 videofx OFFLINE
videofx
    Moonsweeper
  • 255 posts
Posted Tue Oct 9, 2018 12:10 PM
Is there a special drive thats works?  I have a cable thats configured for drive 3. Do you change the drive select on the 3.5" drive?  I am using Corcomp controller, I go into DM2, initialize the disk, the drive light comes on and it starts to initialize then I get ERROR 16
I removed the term resistor from drive 1
The drive works perfect in my PC
Thanks
#2 arcadeshopper OFFLINE
arcadeshopper
  • 4,286 posts
Posted Tue Oct 9, 2018 12:22 PM
are you using a 720k disk? or a 1.44?  if you are using a 1.44 try putting a label over the hd hole before formatting that will make the drive auto-set to 720k
Greg
#3 Schmitzi OFFLINE
Schmitzi
  • 4,509 posts
  • ToXiC
Posted Tue Oct 9, 2018 12:32 PM
Wot does it mean, "cable configured for drive 3" ?
#4 videofx OFFLINE
videofx
    Moonsweeper
  • 255 posts
Posted Tue Oct 9, 2018 12:35 PM
Greg
Greg I'm using a real 720k disk
#5 arcadeshopper OFFLINE
arcadeshopper
  • 4,286 posts
Posted Tue Oct 9, 2018 12:39 PM
cable should be straight through, drive select needs to be set on the drive.. unless you have configured the cable specifically for the ti controller..the pc version doesnt work
#6 videofx OFFLINE
videofx
    Moonsweeper
  • 255 posts
Posted Tue Oct 9, 2018 12:55 PM
correct the cable is twisted for drive 3. What do I set the drive select to on the floppy?
#7 arcadeshopper OFFLINE
arcadeshopper
  • 4,286 posts
Posted Tue Oct 9, 2018 1:02 PM
most 3.5" floppys only have D1 or D2 options.. depends on the drive.. got a model no?  or you can get one of these:  https://shift838.fws...3_19020461.aspx
#8 videofx OFFLINE
videofx
    Moonsweeper
  • 255 posts
Posted Tue Oct 9, 2018 1:12 PM
Greg with the drive select board does it override the drive settings?
I am using a Mitsumi D359
#9 arcadeshopper OFFLINE
arcadeshopper
  • 4,286 posts
Posted Tue Oct 9, 2018 1:13 PM
Yes it retoutes the selected disk select line to d1 so you set your drive to d1
Sent from my LG-H872 using Tapatalk
#10 videofx OFFLINE
videofx
    Moonsweeper
  • 255 posts
Posted Tue Oct 9, 2018 1:21 PM
Sent from my LG-H872 using Tapatalk/?
So straight through cable, drive set to D1 then the board to 1,2, 3 or 4?
I can use any 3.5" drive?
#11 videofx OFFLINE
videofx
    Moonsweeper
  • 255 posts
Posted Tue Oct 9, 2018 1:30 PM
Here is the drive.  I dont see a drive select
Attached File  IMG_3266.jpg   1.05MB   3 downloads
#12 arcadeshopper OFFLINE
arcadeshopper
  • 4,286 posts
Posted Tue Oct 9, 2018 1:37 PM
That drive doesn't send the ready signal without modification that may be an issue also. lots of Google info on how to fix that if it's the issue
#13 videofx OFFLINE
videofx
    Moonsweeper
  • 255 posts
Posted Tue Oct 9, 2018 1:49 PM
What model 3.5 inch is the best to get?
#14 arcadeshopper OFFLINE
arcadeshopper
  • 4,286 posts
Posted Tue Oct 9, 2018 3:26 PM
The best to get is a 720k drive.. the 1.44 drives tend to be designed for the PC in mind without drive select or ready signal jumpers..  they figured why bother if its just going in a peeceee
sony, alps and toshiba drives tend to be better made.. but ymmv  I have 3.5" drives on my 4/a and Geneve that are 1.44 drives and they work pretty well.. I have no idea what make/model they are I just grabbed drives that had disk select jumpers and called it good.
The geneve has a hfdc which is the only controller that does HD as stated before
#15 videofx OFFLINE
videofx
    Moonsweeper
  • 255 posts
Posted Tue Oct 9, 2018 4:18 PM
If anyone has any 3.5 " drives for sale that work please let me know or if you have model numbers that work thats good too!
Thanks
#16 Schmitzi OFFLINE
Schmitzi
  • 4,509 posts
  • ToXiC
Posted Tue Oct 9, 2018 4:26 PM
Maybe this list can help a little bit.
But did I tell ? No warranties ;)
If you have more or better infos -> thanks ;)
Attached File  TI-99-4A-FLOPPY-DRIVES-TI-99-v1.12a-ALL.pdf   40.72KB   8 downloads
Attached File  TI-99-4A-FLOPPY-DRIVES-PEB-short-1.10.JPG   25.48KB   2 downloads
#17 Shift838 OFFLINE
Shift838
  • 2,539 posts
  • SHIFT838
Posted Tue Oct 9, 2018 7:28 PM
Thanks
I have had good luck with Alps 1.44mb drives and decent luck with Bytecc (i think that's what they were).   i just have to place a piece of tape over the HD hole in order to get a good format of 720k of course with my Myarc 80 track FDC and they work great with my 838 Drive select boards..
HERE
#18 OLD CS1 OFFLINE
OLD CS1
    >OLD CS1█
  • 6,027 posts
  • Technology Samurai
Posted Tue Oct 9, 2018 8:56 PM
Real 720k disks are easy enough to find.  Use them with the 720k format if you want your disks to live long and prosper.
#19 videofx OFFLINE
videofx
    Moonsweeper
  • 255 posts
Posted Wed Oct 10, 2018 12:38 PM
HERE
How do you set the drive select if there even is one on the drive when using  the 838 drive select board
#20 Lee Stewart OFFLINE
Lee Stewart
  • 3,947 posts
Posted Wed Oct 10, 2018 3:14 PM
HERE
The 3.5" drive is presumed set to drive #2 (for the PC world) and the 838 board’s dip switch allows switching the line for drive #2 to whatever drive # you want the controller to see, obviating the necessity of manhandling the ribbon cable to make twists, etc
...lee
#21 videofx OFFLINE
videofx
    Moonsweeper
  • 255 posts
Posted Wed Oct 10, 2018 3:23 PM
...lee
Thanks Lee
