Can a R6532P from China replace a broken RIOT?
11 replies to this topic
#1 Dionoid OFFLINE
Dionoid
    Chopper Commander
  • 132 posts
Posted Thu Oct 11, 2018 4:54 PM
Hi, I have a '2600 with a faulty RIOT that I want to replace.
I found some cheap R6532P's on AliExpress; are they any good to replace the broken R6532-15 RIOT?
And what is the difference between a R6532P and a R6532AP?
Thanks!
#2 Osgeld ONLINE
Osgeld
  • 5,916 posts
Posted Thu Oct 11, 2018 5:13 PM
I forget what the difference is but the P will work fine in a 2600
#3 Dionoid OFFLINE
Dionoid
    Chopper Commander
  • 132 posts
Posted Thu Oct 11, 2018 5:35 PM
Thanks for the info! I just ordered a R6532P from China for $2 and free shipping.
For that kind of money I'm fine taking the risk :-)
And I did some investigation on the R6532AP, which seems to be a 2MHz version, while the R6532P is 1MHz.
Edited by Dionoid, Thu Oct 11, 2018 5:38 PM.
#4 DrVenkman ONLINE
DrVenkman
  • 3,852 posts
  • Back off, man! I'm a scientist.
Posted Thu Oct 11, 2018 6:20 PM
Yes. The P suffix just indicates a plastic (instead of ceramic) case.  It corresponds to a traditional vintage 6532 from any of the usual manufacturers who had licensed the 65xx chipset from MOS.
#5 Osgeld ONLINE
Osgeld
  • 5,916 posts
Posted Thu Oct 11, 2018 6:31 PM
That was what I was thinking but didnt want to bother looking it up
and yes DrVenkman is correct the P is for plastic shell (vs ceramic) , its the A vs non A that's the important part
#6 Shawn OFFLINE
Shawn
    As Above
  • 18,859 posts
  • So Below
Posted Thu Oct 11, 2018 7:32 PM
Careful ordering those 6532's from China. Some are DOA and most of them are fakes that are out of spec or just don't work at all.
#7 Osgeld ONLINE
Osgeld
  • 5,916 posts
Posted Thu Oct 11, 2018 9:04 PM
well 2 bucks free shipping ... not a lot to loose
  • jhd likes this
#8 carlsson OFFLINE
carlsson
    Metagalactic Mule
  • 8,641 posts
Posted Fri Oct 12, 2018 3:46 AM
Doesn't the 6532 have a custom ROM part and that is what the -15 represents? Or perhaps that only applies to 6530. I know that in Commodore PET circles, each of these are unique though it has been discussed about replacement solutions with a programmable ROM part so one chip should match them all.
#9 DrVenkman ONLINE
DrVenkman
  • 3,852 posts
Posted Sat Oct 13, 2018 12:04 PM
Exactly, I ordered 5 a few years ago for about $8. One didn't work, the other four are fine. Well worth it.
#10 Dionoid OFFLINE
Dionoid
    Chopper Commander
  • 132 posts
Posted Fri Nov 2, 2018 5:54 AM
Update: I received the R6532P from AliExpress today and replaced it with the broken RIOT. All works fine and I've got a working 4-switch woody again. Yay!
#11 Nezgar OFFLINE
Nezgar
  • 1,682 posts
Posted Sat Jan 12, 2019 6:50 PM
Usually on RAM and EPROMs, the trailing numbers indicate the refresh speed/access time of the memory. In this case 15 = 150ns refresh. The 6532 has 128 bytes of onboard RAM, and memory mapped registers for I/O and timer.
#12 john_q_atari OFFLINE
john_q_atari
    Chopper Commander
  • 157 posts
Posted Mon Jan 28, 2019 12:52 AM
A late post to the thread but I had some recent experience with ordering RIOT chips off ebay shipped from China. Of the 10 R6532P chips I ordered only 6 worked, but of the 5 R6532AP chips I ordered, all of them worked. Worked being defined as dropping them into a socket on a Vader and then playing 2 minutes of Pitfall II. The game wouldn't even start with the ones that didn't work, and the ones that did start the game didn't exhibit any noticeable errors during the first 2 minutes of gameplay. Certainly not a thorough and rigorous test, but only about as much effort as I was willing to spend to determine if the chips were good enough or not.
