GeekDragon Posted October 12, 2018 Share Posted October 12, 2018 When I go to stream stella on OBS, I can get the game list to stream fine. But, when I choose a game, the OBS screen goes black. I have tried game capture, window capture and display capture. I have all 3 open at the same time and still no game. What am I doing wrong? Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted October 14, 2018 Share Posted October 14, 2018 When I go to stream stella on OBS, I can get the game list to stream fine. But, when I choose a game, the OBS screen goes black. I have tried game capture, window capture and display capture. I have all 3 open at the same time and still no game. What am I doing wrong? Check whether you've got the correct window or executable name selected. Create a Scene named Game or whatever you want. In the Sources pane, click the "+" symbol and add the soruce you want. Here I have Window Capture selected. Double-click that for the settings. See the annotated screen caps below. I'm capturing a window here, but I tested with a full-screen recording earlier, which worked fine: Quote Link to comment Share on other sites More sharing options...
GeekDragon Posted October 15, 2018 Author Share Posted October 15, 2018 Check whether you've got the correct window or executable name selected. Create a Scene named Game or whatever you want. In the Sources pane, click the "+" symbol and add the soruce you want. Here I have Window Capture selected. Double-click that for the settings. See the annotated screen caps below. I'm capturing a window here, but I tested with a full-screen recording earlier, which worked fine: Annotation.png Yars.png Ok, I think I got it. So, every time I want to change the game I have to double click window capture and change the setting to the game. Yes, I tried this and it works. Thank you. This is the first time I have really played around with OBS, so still learning. I've been streaming on XBOne and PS4 so far, so this is new to me. Again, thank you. Quote Link to comment Share on other sites More sharing options...
