Yet Another Masterplay Clone
111 replies to this topic
#1 smbaker OFFLINE
smbaker
    Chopper Commander
  • 107 posts
Posted Fri Oct 12, 2018 7:01 PM
I made this a couple weeks back, but haven't got around to making a video about it yet:
It's based on a design I found here on the forum by low_budget, using a DG413DJZ quad switch IC, readily available at digikey (https://www.digikey....DJZ/DG413DJZ-ND). There's a couple pots for adjusting the centering of the stick. As an alternative to my other projects, on this one I chose to put the buttons on the opposite side of the pcboard from the components, for what I hoped would be a cleaner design, once mounted in some kind of case.
Atari 2600 joystick plugs into the small DB connector, and a 15-pin 5200 extension cable plugs into the larger DB connector.
The black button is the second fire button, in case the 2600 stick is of the single-fire-button variety.
Scott
#2 DrVenkman ONLINE
DrVenkman
  • 3,861 posts
  • Back off, man! I'm a scientist.
Posted Fri Oct 12, 2018 7:09 PM
Scott
SIGN ME UP FOR A PAIR OF BOARDS!!! :D
Building your thumbstick controllers this past week actually had me thinking about trying to learn a PCB design program and laying out something like this myself. I'd even considered messaging you to ask if you had something stashed away I might use.
Seriously, when you've got a design finished and ready, I'm dying to get hold of a pair.
Edited by DrVenkman, Fri Oct 12, 2018 7:11 PM.
#3 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 13,813 posts
Posted Fri Oct 12, 2018 7:13 PM
I can already envision a 3D printed case for this thing with buttons that float on top of those pads....
#4 0078265317 OFFLINE
0078265317
  • 6,522 posts
Posted Fri Oct 12, 2018 10:24 PM
I have on of the early low_budget models.
#5 bohoki OFFLINE
bohoki
  • 1,571 posts
Posted Sat Oct 13, 2018 12:22 AM
neato it just needs a mono earphone jack for an aux button or just a header
#6 Swami ONLINE
Swami
  • 2,703 posts
Posted Sat Oct 13, 2018 3:31 AM
Scott
What did you end up using as the controller pinout? Is it the Genesis configuration?
#7 ave1 OFFLINE
ave1
    Dragonstomper
  • 513 posts
Posted Sat Oct 13, 2018 9:46 AM
Like that black button for use on the 2 button games like Moon Patrol and Defender. Nice!
#8 Airshack OFFLINE
Airshack
    Dragonstomper
  • 964 posts
Posted Sat Oct 13, 2018 10:20 AM
Please add me to the preorder list.
#9 john_q_atari OFFLINE
john_q_atari
    Chopper Commander
  • 159 posts
Posted Sat Oct 13, 2018 1:43 PM
These are available in the states around 7 dollars and on ebay and aliexpress for around 3 dollars. Probably would work out better for an enclosure. Also I think it's the same keypad used in the atariguy1021 masterplay clones.
https://www.ebay.com...ST/152875096171
#10 Shawn OFFLINE
Shawn
    As Above
  • 18,873 posts
  • So Below
Posted Sat Oct 13, 2018 3:48 PM
The 4x3 array with the start, pause and reset separated is my personal preference.
#11 DrVenkman ONLINE
DrVenkman
  • 3,861 posts
Posted Sat Oct 13, 2018 3:53 PM
Ditto. I also much prefer the microswitch switches Scott typically uses rather than membrane bubble-type contacts on those integrated keypad units.
Now, if one want's to "build for a case" using Scott's PCB, a search in Digikey shows literally THOUSANDS of switch types. It would probably take a bit of work, but I know there are switches with removable buttons that could be used instead. Find a pair of buttons/switches that raise up enough to extend above the top of a case and you're good to go.
Edited by DrVenkman, Sat Oct 13, 2018 3:58 PM.
#12 Shawn OFFLINE
Shawn
    As Above
  • 18,873 posts
  • So Below
Posted Sat Oct 13, 2018 4:23 PM
I like all the button options from the microswitches, carbon dots on pcbs to the membrane keypads. The membrane layered ones can be tricky if they are not quality builds though. I just had one with broken traces between the layers arrive the other day.
#13 smbaker OFFLINE
smbaker
    Chopper Commander
  • 107 posts
Posted Sat Oct 13, 2018 6:12 PM
I used the standard 2600 pinout, and wired the second fire button to pin9 on the connector. If you wanted to wire the second fire button somewhere else, you could probably hack that change in.
Here's the current order list, let me know if I've missed anyone:
   DrVenkman - 2 boards
   Airshack - 2 boards
If I've missed anyone, please let me know. Cost is $10 per board, plus shipping. I only have a limited quantity on hand.
Keep in mind these are bare pcboards only, you will have to source all components (almost everything can be had from a place like digikey).
BOM and schematic are up on my blog, at http://www.smbaker.c...asterplay-clone
Edited by smbaker, Sat Oct 13, 2018 6:13 PM.
#14 Swami ONLINE
Swami
  • 2,703 posts
Posted Sat Oct 13, 2018 6:23 PM
   Airshack - 2 boards
Like this? That would be the same as an Amiga, although pins 5 and 9 would be analog, rather than digital, on the amiga itself (for POTA and POTB)..
Pin
1 UP
2 DOWN
3 LEFT
4 RIGHT
5 N/C
6 FIRE1
7 +5V VCC
8 GND
9 FIRE2
#15 john_q_atari OFFLINE
john_q_atari
    Chopper Commander
  • 159 posts
Posted Sat Oct 13, 2018 6:25 PM
I'll take 2. Thanks.
#16 Swami ONLINE
Swami
  • 2,703 posts
Posted Sat Oct 13, 2018 8:22 PM
and a switch to have the x Atari paddle on pin 5 as analog on the x-pot of the 5200.
#17 Protestari OFFLINE
Protestari
    Dragonstomper
  • 910 posts
Posted Sat Oct 13, 2018 8:33 PM
I will take 2 and you are on a roll :)
#18 Swami ONLINE
Swami
  • 2,703 posts
Posted Sat Oct 13, 2018 8:53 PM
   Airshack - 2 boards
I'll take two as well, I like the microswitches, too.
#19 smbaker OFFLINE
smbaker
    Chopper Commander
  • 107 posts
Posted Sun Oct 14, 2018 12:06 AM
The list is now
   drvenkman - 2 boards
   airshack - 2 boards
   john_q_atart - 2 boards
   protestarti - 2 boards
   swami - 2 boards
Scott
#20 rayik OFFLINE
rayik
    Moonsweeper
  • 441 posts
Posted Sun Oct 14, 2018 5:42 AM
Is there any way or need to adjust up/down and left/right resistance values? I built a 2600 to 5200 adaptor years ago. I can't find the source, but there are 2 pots for adjusting those values.
#21 rayik OFFLINE
rayik
    Moonsweeper
  • 441 posts
Posted Sun Oct 14, 2018 5:45 AM
Also, if you have 2 extra boards I'd appreciate a chance to make a couple.
#22 DrVenkman ONLINE
DrVenkman
  • 3,861 posts
Posted Sun Oct 14, 2018 7:20 AM
If you check out the pics and/or Scott's blog post, you'll see two small pots to adjust the X- and Y-axis centering.
#23 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 13,813 posts
Posted Sun Oct 14, 2018 8:24 AM
I really hope someone starts selling completed units ready for use.  <<<<<<  HINT HINT! icon_biggrinwink.gif
I hope that was obvious enough.
#24 DrVenkman ONLINE
DrVenkman
  • 3,861 posts
Posted Sun Oct 14, 2018 8:51 AM
This shouldn't be hard to put together at all. The parts for 2 devices, absent the caps, diodes and resistors which most hobbyists buy in bulk, come to about $20.
That would come down in larger quantities. If Scott made arrangements for someone to sell authorized builds - using his board design and paying some $$ per board as a royalty or something - this would be a big seller in the 5200 community.  That's entirely up to him, of course, but there are a few folks in the AtariAge community already doing stuff like this in the A8 and 2600 world (e.g., Marlin Bates, 'MacRorie').
#25 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 13,813 posts
Posted Sun Oct 14, 2018 8:58 AM
I'll be here, waiting to see what develops.  I only need one device myself.
