JZINTV and Raspberry Pi
43 replies to this topic
#1 dalves OFFLINE
dalves
    Chopper Commander
  • 150 posts
Posted Mon Oct 15, 2018 12:05 PM
I didn't see a specific forum for this, so I figured I'd ask here. I have recently build a Raspberry Pi 3 and got a bunch of emulators running on it. I have JZINTV as my intellivision emulatior, and it works fine. However, on games that use a colored boarder, the border on the right side of the screen is cut in half. I never noticed this when using JZINTV on my computer, but since I still use MESS as my main emulator, it may be true there as well. When I asked about this on the Retropie forums,I was told this is a flaw in JZINTV. I'm just wondering if any one has noticed this before, and if it may be a screen setting issue.
Cut boarder
Thanks...
Edited by dalves, Mon Oct 15, 2018 12:16 PM.
#2 mr_me OFFLINE
mr_me
  • 3,682 posts
Posted Mon Oct 15, 2018 12:36 PM
Space Armada has an expanded left border, so it should always look bigger than the right border. Try Vectron or Frog Bog for comparision. Those cartridges don't have expanded borders.
Programmers expand the left borders for horizontal scrolling and the top border for vertical scrolling. Some cartridges have expanded borders even if it doesn't make use of scrolling; not sure why. Space Armada might be using horizonal scrolling to animate the armada.
Edited by mr_me, Mon Oct 15, 2018 12:37 PM.
#3 ColecoJoe OFFLINE
ColecoJoe
    Moonsweeper
  • 463 posts
Posted Mon Oct 15, 2018 1:36 PM
Yeah mine is like that too but more severe than yours especially on Cloudy Mountain. And like you, on the computer it looks fine but on my retropie running through a CRT some of the games have alignment issues.
Edited by ColecoJoe, Mon Oct 15, 2018 1:37 PM.
#4 mr_me OFFLINE
mr_me
  • 3,682 posts
Posted Mon Oct 15, 2018 1:57 PM
AD&D (cloudy mountain) has an expanded left and top border. Like Space Armada the left border should be about eight intellivision pixels wider than the right border. If the borders are thin than the left border will look a lot thicker. If the borders are thick the eight pixel difference is less noticeable. Look at a cartridge that does not have expanded borders to check if there's an alignment issue.
#5 ColecoJoe OFFLINE
ColecoJoe
    Moonsweeper
  • 463 posts
Posted Mon Oct 15, 2018 1:59 PM
But when I run the game (cloudy) from a cartridge it looks fine and fits nice on the screen.
#6 mr_me OFFLINE
mr_me
  • 3,682 posts
Posted Mon Oct 15, 2018 2:12 PM
A real intellivision shifts the picture to the left. Try a real cartridge that doesn't expand the left border on a real intellivision with crt and you'll see.
#7 dalves OFFLINE
dalves
    Chopper Commander
  • 150 posts
Posted Tue Oct 16, 2018 10:55 AM
I will check various games tonight to check the extended scroll boarder. The thing that makes me wonder if it's that, is the games that show the border offset using JZINTV on my Raspberry Pi, have perfectly aligned borders when I use the same ROM in my MESS emulator. I will check, but my memory is that every game with a colored boarder used on my Raspberry Pi had the border offset.
#8 Lathe26 OFFLINE
Lathe26
  • 3,798 posts
Posted Tue Oct 16, 2018 12:25 PM
If it helps (and if I remember to do it), I'll take a photo of test ROM I wrote where the user can toggle whether the left & top borders are extended or not. This way, you'll be able to compare before and after.
Going from memory (others may correct me), the Intellivision displays the screen slightly offset to the left normally and a bit more offset to the right when border extensions are turned on... at least as seen on a 1080p HDTV.
#9 ColecoJoe OFFLINE
ColecoJoe
    Moonsweeper
  • 463 posts
Posted Tue Oct 16, 2018 7:24 PM
This is what mine looks like. Still playable, just annoying.
#10 mr_me OFFLINE
mr_me
  • 3,682 posts
Posted Tue Oct 16, 2018 7:37 PM
That's correct for emulation.  There is a row of tiles at the top and a column of tiles on the left that are covered by the expanded border.  If the remaining picture were centered than part of the top and left of the screen would be cut off for cartridges that don't expand the border.  What's the emulator?  Jzintv by default should have a thin border at the bottom.
With a real Intellivision, it use to annoy me that the picture was shifted to the left for cartridges that didn't expand the border.  It's either one or the other.
Edit:
To make it more realistic on a crt television. You can thicken the border in jzintv and add some overscan to raspbian.
Edited by mr_me, Tue Oct 16, 2018 8:13 PM.
#11 ColecoJoe OFFLINE
ColecoJoe
    Moonsweeper
  • 463 posts
Posted Tue Oct 16, 2018 7:49 PM
I'm using jzintv here.
Man, I spent so much time trying to fix this in the config files when I was adjusting the retropie for CRT :) Thanks for the info!
I made a lot of changes to the config files so that's probably why it's not showing the bottom border. I suppose the fact that it's a 8" screen doesn't help :)
Edited by ColecoJoe, Tue Oct 16, 2018 7:54 PM.
#12 Lathe26 OFFLINE
Lathe26
  • 3,798 posts
Posted Tue Oct 16, 2018 10:11 PM
As promised here are 2 photos of my test ROM running on a 1080p HD TV, which looks a little different than on a CRT from back in the day.  Yes, the colors are garish; that is deliberate.
Side note: I had just thrown this ROM together a few days ago after reading Oscar's book "Programming Games for Intellivision" (purchase here)
No border extension
Both left and top borders extended
#13 IMBerzerk OFFLINE
IMBerzerk
    Chopper Commander
  • 232 posts
Posted Wed Oct 17, 2018 1:05 PM
I have this same issue on my LCD screen as well. What makes emulation different that the original picture becomes shifted like this? Anything that can be tweaked or changed?
#14 Lathe26 OFFLINE
Lathe26
  • 3,798 posts
Posted Wed Oct 17, 2018 1:36 PM
Forgot to clarify that my photos are from a real Intellivision, not a Raspberry Pi (just case anyone was confused).
This doe not address IMBezerk's question.
#15 mr_me OFFLINE
mr_me
  • 3,682 posts
Posted Wed Oct 17, 2018 2:12 PM
Emulation centres the picture. A real intellivision shifts the picture left. In jzintv you can thicken the border on all sides with the -b switch; then you won't notice the difference in border size so much. In Raspbian you can adjust the overscan settings but that effects everything not just jzintv.
#16 ColecoJoe OFFLINE
ColecoJoe
    Moonsweeper
  • 463 posts
Posted Wed Oct 17, 2018 2:19 PM
If you look at my screenshot, that's as good as I could get it manipulating the overscan settings since like Mr_me said, it affects all games the same way. Other games with no borders look fine of course.
#17 intvnut OFFLINE
intvnut
  • 3,207 posts
Posted Wed Oct 17, 2018 3:59 PM
You can tell jzIntv to add a thicker border all around to make the effect less noticeable with the -b flag.  (I see mr_me mentioned that a few minutes ago as well.)  Something in the range -b10 to -b20 works pretty well.
I don't think it's correct to say that the TV shifts the image to the left.  Rather, it's just less noticeable on a TV due to the larger border displayed there.  If I toggle the left border on/off the rest of the image stays put
#18 TPR ONLINE
TPR
  • 2,191 posts
Posted Wed Oct 17, 2018 9:00 PM
Speaking of the Pi - Is there a way to re-map the buttons so that two buttons pressed equals a keypad button?
For example, if I'm using a SNES controller and I want to map:
L+A = 1
L+B = 2
L+X = 3
L+Y = 4
Etc. etc.... Last I checked I thought that couldn't be done but it's been quite some time since I've looked into this.
#19 mr_me OFFLINE
mr_me
  • 3,682 posts
Posted Wed Oct 17, 2018 9:30 PM
With jzintv you can designate one button to act as a "shift" and assign secondary actions to all other buttons.
If you have an xbox or playstation type controller you can map all buttons without shifting.
#20 TPR ONLINE
TPR
  • 2,191 posts
Posted Wed Oct 17, 2018 9:35 PM
How exactly is that done?  For example here is my current hackfile:
How do I assign a button to be the "shift" key?
JS0_BTN_16 QUIT
JS0_BTN_13 PD0L_A_T
JS0_BTN_15 PD0L_A_L
JS0_BTN_14 PD0L_A_R
JS0_BTN_00 PD0L_KP1
JS0_BTN_12 PD0L_KP2
JS0_BTN_10 PD0L_KP3
JS0_BTN_11 PD0L_KP4
JS0_BTN_08 PD0L_KP5
JS0_BTN_09 PD0L_KP6
JS0_BTN_20 PD0L_KP7
JS0_BTN_20 PD0L_KP8
JS0_BTN_01 PD0L_KP9
JS0_BTN_20 PD0L_KPC
JS0_BTN_02 PD0L_KP0
JS0_BTN_03 PD0L_KPE
#21 mr_me OFFLINE
mr_me
  • 3,682 posts
Posted Wed Oct 17, 2018 9:42 PM
Assuming that's all under MAP 0. Add this line in there.
JS0_BTN_x PSH3
Where x is the button number to act as shift. Then create a MAP 3 section and add all your shifted mappings there.
#22 TPR ONLINE
TPR
  • 2,191 posts
Posted Wed Oct 17, 2018 9:55 PM
JS0_BTN_x PSH3
Looks like I only have a MAP 0.
map 0      ; activate with F5
; map the Keyboard arrow keys
UP         KEYB_UP
DOWN       KEYB_DOWN
RIGHT      KEYB_RIGHT
LEFT       KEYB_LEFT
; joystick #0 - left controller
JS0_BTN_16 QUIT
JS0_BTN_13 PD0L_A_T
JS0_BTN_15 PD0L_A_L
JS0_BTN_14 PD0L_A_R
JS0_BTN_00 PD0L_KP1
JS0_BTN_12 PD0L_KP2
JS0_BTN_10 PD0L_KP3
JS0_BTN_11 PD0L_KP4
JS0_BTN_08 PD0L_KP5
JS0_BTN_09 PD0L_KP6
JS0_BTN_20 PD0L_KP7
JS0_BTN_20 PD0L_KP8
JS0_BTN_01 PD0L_KP9
JS0_BTN_20 PD0L_KPC
JS0_BTN_02 PD0L_KP0
JS0_BTN_03 PD0L_KPE
JS0_BTN_04 PD0L_J_N
JS0_BTN_05 PD0L_J_E
JS0_BTN_06 PD0L_J_S
JS0_BTN_07 PD0L_J_W
JS0_N      PD0L_J_N
JS0_NNE    PD0L_J_NNE
JS0_NE     PD0L_J_NE
JS0_ENE    PD0L_J_ENE
JS0_E      PD0L_J_E
JS0_ESE    PD0L_J_ESE
JS0_SE     PD0L_J_SE
JS0_SSE    PD0L_J_SSE
JS0_S      PD0L_J_S
JS0_SSW    PD0L_J_SSW
JS0_SW     PD0L_J_SW
JS0_WSW    PD0L_J_WSW
JS0_W      PD0L_J_W
JS0_WNW    PD0L_J_WNW
JS0_NW     PD0L_J_NW
JS0_NNW    PD0L_J_NNW
What would the MAP 3 look like?
#23 mr_me OFFLINE
mr_me
  • 3,682 posts
Posted Wed Oct 17, 2018 10:01 PM
You can add the following to the end of your file.
MAP 3
JS0_BTN_00 RESET
Now when you hold the designated shift button and press the first controller button the game will reset.
Edited by mr_me, Wed Oct 17, 2018 10:04 PM.
#24 ColecoJoe OFFLINE
ColecoJoe
    Moonsweeper
  • 463 posts
Posted Wed Oct 17, 2018 10:22 PM
Can you post an example on how to set the flag ... I'm nothing more than  a hack over here :)
#25 TPR ONLINE
TPR
  • 2,191 posts
Posted Wed Oct 17, 2018 10:23 PM
So I did a test....
JS0_BTN_13 PD0L_A_T
JS0_BTN_15 PD0L_A_L
JS0_BTN_14 PD0L_A_R
JS0_BTN_00 PD0L_KP1
JS0_BTN_03 PD0L_KPE
JS0_BTN_10 PSH3
map 3      ;
JS0_BTN_12 PD0L_KP4
JS0_BTN_13 PD0L_KP2
JS0_BTN_14 PD0L_KP3
JS0_BTN_15 PD0L_KP5
And it worked where if I hit BTN_10 + BTN_13 I got KP2 using the Zcontroller_test.
But then I would have to hit F5 on my keyboard to make BTN_13 be PD0L_A_T again.
Is there a way to only temporarily have that button mapped while I hold down BTN_10 and then it reverts back to map 0 when I release the button?
