JZINTV and Raspberry Pi
43 replies to this topic
#26 TPR OFFLINE
TPR
  • 2,191 posts
Posted Wed Oct 17, 2018 10:36 PM
So I think I might have got it working....
map 0      ;
; joystick #0 - left controller
JS0_BTN_16 QUIT
JS0_BTN_13 PD0L_A_T
JS0_BTN_15 PD0L_A_L
JS0_BTN_14 PD0L_A_R
JS0_BTN_03 PD0L_KPE
JS0_BTN_00 PD0L_KP1
JS0_BTN_10 PSH3
map 3      ;
JS0_BTN_12 PD0L_KP4
JS0_BTN_13 PD0L_KP2
JS0_BTN_14 PD0L_KP3
JS0_BTN_15 PD0L_KP5
JS0_BTN_10 PSH0
In this config, as soon as I release BTN_10 it goes back to map 0
#27 mr_me ONLINE
mr_me
  • 3,681 posts
Posted Wed Oct 17, 2018 10:46 PM
Yes, you needed another push action in MAP 3. Although the documentation would have you put the exact same line in MAP 3.
JS0_BTN_10 PSH3
I guess it doesn't matter since it's popping back to the previous map either way.
Edited by mr_me, Wed Oct 17, 2018 10:49 PM.
#28 TPR OFFLINE
TPR
  • 2,191 posts
Posted Wed Oct 17, 2018 11:02 PM
Yep!  That all worked out!  Thank you for that!
For the first time on my Pi I have all 10 keypad buttons mapped to a control pad!
#29 intvnut OFFLINE
intvnut
  • 3,207 posts
Posted Wed Oct 17, 2018 11:21 PM
And it worked where if I hit BTN_10 + BTN_13 I got KP2 using the Zcontroller_test.
But then I would have to hit F5 on my keyboard to make BTN_13 be PD0L_A_T again.
Is there a way to only temporarily have that button mapped while I hold down BTN_10 and then it reverts back to map 0 when I release the button?
OK, this is counterintuitive:  You need to map JS0_BTN_10 in both MAP 0 and MAP 3.   The button-release event will get processed when you're in map 3, and will use whatever binding you have on JS0_BTN_10 in map 3.
map 0      ; activate with F5
JS0_BTN_13 PD0L_A_T
JS0_BTN_15 PD0L_A_L
JS0_BTN_14 PD0L_A_R
JS0_BTN_00 PD0L_KP1
JS0_BTN_03 PD0L_KPE
JS0_BTN_10 PSH3
map 3      ;
JS0_BTN_12 PD0L_KP4
JS0_BTN_13 PD0L_KP2
JS0_BTN_14 PD0L_KP3
JS0_BTN_15 PD0L_KP5
JS0_BTN_10 PSH3      ; <--- add this
Can you post an example on how to set the flag ... I'm nothing more than  a hack over here :)
I don't know the process for adding flags with respect to any of the various front-ends, since I don't use them.
However, if you can find where the flags for jzIntv are specified, you can add the flag -b10 or -b20 to the list of flags.  10 means "add a 10% border around the window", while 20 means "add a 20% border".  You can try other sizes as well.
Now, if the output display has to be a particular resolution to display properly on your TV, then we have to bust out some math, and provide a second flag to force jzIntv's resolution.
#30 mr_me ONLINE
mr_me
  • 3,681 posts
Posted Thu Oct 18, 2018 6:20 AM
With retropie I think you'll find the command to launch jzintv at the location below. Just put the switch anywhere after the jzintv command. Separate all switches with spaces.
/opt/retropie/configs/intellivision/emulators.cfg
Edited by mr_me, Thu Oct 18, 2018 6:20 AM.
#31 dalves OFFLINE
dalves
    Chopper Commander
  • 150 posts
Posted Wed Oct 24, 2018 8:01 AM
You can tell jzIntv to add a thicker border all around to make the effect less noticeable with the -b flag.  (I see mr_me mentioned that a few minutes ago as well.)  Something in the range -b10 to -b20 works pretty well.
I don't think it's correct to say that the TV shifts the image to the left.  Rather, it's just less noticeable on a TV due to the larger border displayed there.  If I toggle the left border on/off the rest of the image stays put
I am interested to try this, but wondering if there is a specific place I need to enter the -b flag in the retropie config I'm using. Below is what I currently have. I didn't know if I would add it between the -z1 and -p?
jzintv = "/opt/retropie/emulators/jzintv/bin/jzintv -z1 -p /home/pi/RetroPie/BIOS -q %ROM%"
default = "jzintv"
#32 mr_me ONLINE
mr_me
  • 3,681 posts
Posted Wed Oct 24, 2018 8:25 AM
The order of the switches don't matter.  You could even put it after the rom filename.
#33 DZ-Jay ONLINE
DZ-Jay
  • 11,960 posts
  • The P-Machinery AGE is almost here!
Posted Wed Oct 24, 2018 9:40 AM
That is true, but just to be extra thorough, I'll just mention that some of those switches take a parameter, like a path, etc.; and those need to be followed specifically by their parameters.
The order of all the options themselves (whether parametized or not) is not important.
#34 ColecoJoe OFFLINE
ColecoJoe
    Moonsweeper
  • 463 posts
Posted Thu Oct 25, 2018 6:18 PM
When I add the -b10 or 20 flag non of my roms will open.
This is what I have.
jzintv="/opt/retropie/emulators/jzintv/bin/jzintv -v1 --kbdhackfile=/opt/retropie/emulators/jzintv/hackfile.cfg -f1 -q -z800x600  %ROM%"
#35 mthompson OFFLINE
mthompson
    Dragonstomper
  • 873 posts
Posted Thu Oct 25, 2018 6:28 PM
Make sure you are using a recent build of jzIntv that supports the -b flag. It was added in the last year, I think.
#36 ColecoJoe OFFLINE
ColecoJoe
    Moonsweeper
  • 463 posts
Posted Thu Oct 25, 2018 6:45 PM
Ahh, that makes sense. I'm using a Byte Knight flashback.
#37 pimpmaul69 OFFLINE
pimpmaul69
  • 4,857 posts
  • INTV Brotherhood Technician
Posted Fri Oct 26, 2018 12:57 AM
retropie does not i stall the latest version either. Download the new one from jzintvs website. To install on the pi you need to have root user permissions as the /opt/retropie/emulators/jzintv/ folder and its contents belong to user root and not user pi. Then you need to use a program like winscp to put it on the pi.
#38 dalves OFFLINE
dalves
    Chopper Commander
  • 150 posts
Posted Sun Nov 4, 2018 9:27 AM
So I upgraded the old version of jzintv that was on my Raspberry Pi with the newest Linux version from the website. The -b setting looks great and it now looks like what I am used to seeing with Intellivision games.
That said, all the games load and play great with the exception of the Intellivoice games and Space Patrol. With the updated jzintv files, they won't run. If I use the older jzintv files, the intellivoice games and Space Patrol work perfectly. I'm trying to figure out what I may be missing with the upgrade.
Edited by dalves, Sun Nov 4, 2018 9:27 AM.
#39 mr_me ONLINE
mr_me
  • 3,681 posts
Posted Sun Nov 4, 2018 10:38 AM
I can't imagine anything missing. Even if intellivoice was disabled intellivoice games would still run. Space Patrol and jzintv were written by the same guy. One thing to check with linux systems is that any rom cfg file extensions are lowercase.
Test with the old jzintv executable, then test with the new executable without the /b switch. Did you make any other changes to the command other than the /b switch. Maybe post the contents of your intellivision/emulators.cfg file. Ideally we'd want to see the jzintv error message.
Edited by mr_me, Sun Nov 4, 2018 10:46 AM.
#40 Byte Knight OFFLINE
Byte Knight
  • 1,126 posts
  • Intellivision / Apple II
Posted Sun Nov 4, 2018 12:37 PM
I noticed that the Intellivoice games launch in ECS mode for some reason with the newer version.  My guess is that you don't have the ECS.BIN file and so it won't run.  Try adding "-s0" to your command line to turn off ECS.
#41 mr_me ONLINE
mr_me
  • 3,681 posts
Posted Sun Nov 4, 2018 1:13 PM
Byte Night is correct. It looks like the intellivoice ecs games bug started in 2018 but the Space Patrol ecs bug started in late 2017. The bug is likely with an internal games database in jzintv rather than the program.
Edited by mr_me, Sun Nov 4, 2018 1:14 PM.
#42 dalves OFFLINE
dalves
    Chopper Commander
  • 150 posts
Posted Mon Nov 5, 2018 8:46 AM
I feel I've almost got it... When I added "-s0" to the command line, then none of my Intellivision ROMS would launch. I found the ecs.bin file on my computer and added it to my Raspberry Pi. Now my Intellivision ROMS work. I removed the "-s0" line and the Intellivoice games launch in ESC mode. If I add the "-s0" back to the command line, the games now load directly. Space Patrol works fine, and the Intellivoice games launch. However none of the Intellivoice games have the Intellivoice voices. There is still sound in those games, but it's missing the voices. I do have the "exec.bin, grom.bin, ivoice.bin, and ecs.bin in the Retropie BIOS folder. Just as a heads up, below is the config lines I currently have.
jzintv = "/opt/retropie/emulators/jzintv/bin/jzintv -z1 -b10 -p /home/pi/RetroPie/BIOS -q %ROM%"
default = "jzintv"
#43 mr_me ONLINE
mr_me
  • 3,681 posts
Posted Mon Nov 5, 2018 9:10 AM
Add the -v1 switch; that turns on the intellivoice. Looks like jzintv is not correctly identifying these rom files as intellivoice rom files. The switch would be needed for any new intellivoice games that comes out anyway. The ivoice.bin file isn't used by jzintv.
Edited by mr_me, Mon Nov 5, 2018 9:27 AM.
#44 intvsteve OFFLINE
intvsteve
  • 3,293 posts
Posted Mon Nov 5, 2018 11:12 AM
Newer versions of the tools are doing a lot more work with ROM metadata picked up from the .cfg files.  I haven't looked at how jzintv is interpreting it and taking action based on it.
From what I gather, just doing the "ECS presence detect" in IntyBASIC programs may result in adding 'ecs = 1' to the [vars] section of the .cfg file produced by as1600.  That means 'ECS is ​required​'. When bin2rom runs, that metadata is preserved in the .rom file.  The recent updates to metadata features (starting in January) expand the notion of some of the settings:
ecs = 1 => ecs is REQUIRED
ecs = 0 => ecs is DO NOT CARE (TOLERATES)
The newer, preferred settings would be (I think...):
ecs_compat = 0 => INCOMPATIBLE
ecs_compat = 1 -> DO NOT CARE (TOLERATES)
ecs_compat = 2 => ENHANCES (e.g. Space Patrol gets 6-CH sound, similar for Deep Zone)
ecs_compat = 3 => REQUIRED (program will not function without ECS)
There is a similar mapping for Intellivoice, though voice = 1 should map to 'ENHANCES' -- I don't think there's a "REQUIRED" mapping.
Not as familiar w/ the Ultimate Flashback setup - mine's still a WIP at the moment, though it's using a pretty new build of jzintv as well.
So - you may be able to alter the .cfg files for the games that are causing trouble, too.  If you have .rom files, then you'd have to do a rom2bin -> edit .cfg -> bin2rom round trip with the newer versions of those tools.
