more than one missile question
6 replies to this topic
#1 waderain OFFLINE
waderain
    Space Invader
  • 26 posts
Posted Tue Oct 16, 2018 1:51 PM
I know using NUSIZ0, NUSIZ1 can give me 2 or 3 copies of a player and missile but is there a way just to make copies of the missile and not the player?
#2 Karl G ONLINE
Karl G
    Dragonstomper
  • 651 posts
Posted Tue Oct 16, 2018 2:12 PM
Unfortunately not.  Ditto with color.  They are controlled by the same register.
#3 Coolcrab OFFLINE
Coolcrab
    Moonsweeper
  • 401 posts
Posted Tue Oct 16, 2018 2:28 PM
You can probably hack it in with assembly somehow depending on how the game looks. Like if you have a space invaders like setting you could set NUSIZ0 to different values above scanline X and to something else below it. But that would limit the move space of your character. (Not sure if you can change something like that after like half a scanline if you want the game to be flipped 90 deg.)
I'm not an assembly wizard like others here, so they can probably call out my BS or give a magical script. But I think any possible fix will be very specific so explaining your game might help.
#4 orange808 OFFLINE
orange808
    Space Invader
  • 48 posts
Posted Tue Oct 16, 2018 4:14 PM
Flicker them. Your bigger issue may be finding enough variables to keep track of all the missiles you create and to implement reliable collisions.  You should be able to get six missiles from the ball, missile0, and missile1.
Use a byte as a counter and let it increment and roll over. The first bit will toggle on and off each frame.  Use that to draw the missiles in different locations each frame.
You will need to make considerations for this when you detect collisions, but it can be managed.
if fooCounter{0} then misslex = foo : missiley = foo else misslex = bar : missley = bar
Edited by orange808, Tue Oct 16, 2018 4:14 PM.
#5 waderain OFFLINE
waderain
    Space Invader
  • 26 posts
Posted Tue Oct 16, 2018 4:49 PM
What I'm wanting to have is 5 vertical lines spaced out to make 4  tracks along the left side of the screen. I'm planing on using the multi sprite kernel so I can have more than two sprites but I don't want the play field mirrored
A missile looks great with a height of 80 or so, it's nice and thin looking. I've tried flickering them but it's really annoying.
Just thought maybe someone had a good trick to achieve this
Edited by waderain, Tue Oct 16, 2018 4:52 PM.
#6 Coolcrab OFFLINE
Coolcrab
    Moonsweeper
  • 401 posts
Posted Wed Oct 17, 2018 12:21 AM
Try the icing on a cake effect
http://atariage.com/...al-shooter-wip/
#7 Gemintronic OFFLINE
Gemintronic
    Jason S. - Lead Developer & CEO
  • 9,291 posts
Posted Thu Oct 18, 2018 7:10 AM
I have the source code to a game called M.M.S.B.C. 2 here:
http://atariage.com/...6-mmsbc-2-done/
It's not an example per se but it does showcase using missiles as player ships.  It also timeshares the ball as a projectile for both players.  It also manages to have different colors for the virtual projectiles even though it's the ball.  Basically, it swaps a bluish color with a reddish color.  This messes with the playfield color BUT you don't notice it so much because your eyes resolve it down to grey.
