Chipper
17 replies to this topic
#1 mvirtuale OFFLINE
mvirtuale
    Chopper Commander
  • 175 posts
Posted Fri Oct 19, 2018 6:37 PM
Hi, I'm trying to make an initial melody and some sound effects for my game.
In this page:
https://chipmusic.org/forums/topic/4060/chipper-atari-lynx-sound-gen-tracker-tool-early-beta/
I've read that you use chipper, but the download link does not work.
http://bjoern.spruck.net/lynx/Chipper.zip
Does any of you have this program?
Alternatively, can you recommend some other program and tell me where to find it?
Thank you
#2 Turbo Laser Lynx OFFLINE
Turbo Laser Lynx
    Dragonstomper
  • 537 posts
Posted Fri Oct 19, 2018 11:45 PM
Hi, I checked and they are there, but you need to download the older version: "Lynx Chip Editor (beta v1.7.6).", the new one has not been released. I would also download the "Christmas Release: HiColor Slideshow Builder" that contains chipper with some more example songs and sounds.
Good luck! Chipper can look intimidating at first, but if you find some general documentation about how trackers work, it's the fastest and easiest way to create music for the lynx. Other than that I think Karris abc music might be easier if the chipper learning curve is too steep at first. There's links and documentation for abc music here as well: http://atariage.com/...-tutorials-wip/
Edited by Turbo Laser Lynx, Sat Oct 20, 2018 1:11 AM.
#3 Turbo Laser Lynx OFFLINE
Turbo Laser Lynx
    Dragonstomper
  • 537 posts
Posted Sat Oct 20, 2018 1:16 AM
The info is really spread out on these forums, but here's a couple of notes to get you started:
You can look past all the windows and menus and diagrams and focus on the really simple stuff and the main tracker window.
1. Eye through some tracker basics: http://wiki.openmpt.org/Manual:_Basics
2. In every row of every column there's three cells where you can put in:
- CELL1: the number of the simple instrument you're going to use for that note. (This is really smart 'cause you can get a lot of stuff done with only four channels).
- CELL2: the note or nothing (a pause)
- CELL3: the part of the song in the playlist (if I remembercorrectly)
3. The simple instrument is for creating sounds but there's already some good sounds in the insts folder
4. There's some really great songs in the demosongs folder to look at too.
*Note you put in the notes with the keyboard (I was clicking aroung with the mouse for much longer than I care to admit) :P
I'm in the middle of a Lynx project right now, but hopefully I will have the time to add a small "chipper basics" tutorial with images here on the AA forums as soon as possible.
#4 karri ONLINE
karri
  • 2,684 posts
Posted Sat Oct 20, 2018 5:31 AM
I have published a few chipper instruments on my whitelynx.fi site. There is a lot more instruments I could publish but the downside is that every game starts sounding the same if we all use the same sounds. Perhaps the best solution would be to slightly tweak the sounds before using them.
If you look at Chicken dance on my site the B-part with the slightly out-of-tune orchestra. It is actually just a single note melody.
#5 Turbo Laser Lynx OFFLINE
Turbo Laser Lynx
    Dragonstomper
  • 537 posts
Posted Sat Oct 20, 2018 6:24 AM
I added a long overdue 'getting started' Chipper guide here:
http://atariage.com/...-wip/?p=4137925
(Yay!)
#6 mvirtuale OFFLINE
mvirtuale
    Chopper Commander
  • 175 posts
Posted Sun Oct 21, 2018 4:24 AM
Thanks, I downloaded the program.
Now, I have to learn to use it, but with the guide I should not have too many problems
#7 mvirtuale OFFLINE
mvirtuale
    Chopper Commander
  • 175 posts
Posted Fri Oct 26, 2018 2:07 PM
I have melodies in midi files.
I'd like to put one of these melodies in the game. On the internet I read I can reproduce this melody without problems and penalties.
I wanted to know if you can convert the melody for the lynx with Chipper or some other program.
Thanks in advance for your help.
#8 romualdl OFFLINE
romualdl
    Space Invader
  • 19 posts
Posted Sun Nov 18, 2018 2:45 PM
Hi there,
Been reading everything available for Chipper (thanx to all of you taking time to put these things together). Nevertheless I'm still unable to get something out of Chipper. I've been playing a little with trackers on Atari St, Amiga and even Oric (sonix from Twilighte) but I'm facing hard times with Chipper. ;)
Sorry for "well I guess I'm too stupid to do it" but I've tried differents ways but none works. I'm able to fill in the Cell 1/2/3 etc with what's necessary but it seems I'm facing some problems with the instruments stuff. I would like to use some "preset" instruments but how to listen to them? How to assign an instrument to on-going project? If I try to assign some pre-existing instrument to a simple instrument "instr1" through "load instrument", I have no way to check which instrument it is. Furthermore if I hit play on the "simple instrument" window it's kinda weird sound coming out and no way to have something correct when the track is played.
So anyplace where I could find some help on this one? (as said before I've already been reading Turbo Laser Lynx 'getting started' and the Chipper threads...).
Thanks to anyone which could help me on this one ;)
#9 karri ONLINE
karri
  • 2,684 posts
Posted Mon Nov 19, 2018 12:23 AM
I try to maintain a page with instrument screenshots that I have been using. So if you just tick the boxed and click on Play you should hear the same sound as in my samples.
Have a look at  http://whitelynx.fi/sounds/
#10 Turbo Laser Lynx OFFLINE
Turbo Laser Lynx
    Dragonstomper
  • 537 posts
Posted Mon Nov 19, 2018 1:04 AM
Also possibly worth noting: the play button often bugs out (at least for me), so I have to change back and forth between two sounds in the drop down list to make it work again.
#11 Nop90 OFFLINE
Nop90
    Chopper Commander
  • 144 posts
Posted Mon Nov 19, 2018 2:29 AM
Play button never works for me, but I use the keyboard to play the instruments at different notes. W key should be a nice D4 (or D5 can't remember now) on the +0 octave.
#12 romualdl OFFLINE
romualdl
    Space Invader
  • 19 posts
Posted Mon Nov 19, 2018 4:33 PM
Thanks Karri for the link. So I guess there is no easy way to "build" a set of instruments than setting them one by one with their different parameters.
Turbo Laser Lynx and Nop90 ok for the play button.
#13 romualdl OFFLINE
romualdl
    Space Invader
  • 19 posts
Posted Thu Nov 22, 2018 5:25 PM
Ok I managed to deal with these instruments and to set a list ;)
Thanks
#14 sage OFFLINE
sage
  • 1,005 posts
Posted Fri Nov 23, 2018 3:21 AM
I never imagined that someone is able to use it...
#15 karri ONLINE
karri
  • 2,684 posts
Posted Fri Nov 23, 2018 3:38 AM
I am currently disassembling Shadow of the Beast sounds. Once I find out how those wonderful special effects are done I might have a chat with you sage.
#16 sage OFFLINE
sage
  • 1,005 posts
Posted Tue Dec 25, 2018 8:34 AM
... recently I even made some changes for TCM export.
#17 Cyprian_K OFFLINE
Cyprian_K
    Chopper Commander
  • 143 posts
Posted Tue Dec 25, 2018 2:25 PM
I faced an issue with Chipper.
Also I noticed Chipper uses Windows 95 "file selector". Would be cool to have a bit newer one.
Also "Simple Intrument"-->"Play" button doesn't work. I have to check/uncheck "Tremolo/Envelope" to hear any sound.
Edited by Cyprian_K, Tue Dec 25, 2018 2:36 PM.
#18 sage OFFLINE
sage
  • 1,005 posts
Posted Tue Dec 25, 2018 3:43 PM
THats is the only one supported by this ancient ide.
