I designed a NanoPEB Case...
36 replies to this topic
#26 Opry99er OFFLINE
Opry99er
  • 9,981 posts
Posted Mon Nov 12, 2018 10:29 AM
Yes, mine has an adapter and so it sets close to the body of the cf7+. You should be able to do the same.
Interesting. I wasn't aware such an adapter existed. I know Jamie M. eventually started building the CF7s with the more recognizable components (the 90 degree angle) but I had assumed it was a custom job, and required a different layout on the board itself. I'll have to look for an adapter.
#27 RickyDean OFFLINE
RickyDean
    Dragonstomper
  • 991 posts
Posted Mon Nov 12, 2018 11:18 AM
You can get this type, as well as others by doing a search on google. As well as on Ebay.
This pic came from https://usb.brando.c...8c0042d015.html
Edited by RickyDean, Mon Nov 12, 2018 11:20 AM.
#28 jdgabbard OFFLINE
jdgabbard
    Moonsweeper
  • 284 posts
Posted Thu Nov 15, 2018 9:43 AM
Yeah, I agree.  You should be able to just get a 90* adapter.  At that point it is just matching the size characteristics.  I'll try to put together a list of dimensions that I would need to design one.  But I'll need accurate measurements down to the 0.5mm.  Do you have a Micrometer?
#29 arcadeshopper OFFLINE
arcadeshopper
  • 3,848 posts
Posted Thu Nov 15, 2018 3:17 PM
printing!
#30 Opry99er OFFLINE
Opry99er
  • 9,981 posts
Posted Thu Nov 15, 2018 3:48 PM
If I make the modification, I would be happy to send you the device for measurement. :)
#31 jdgabbard OFFLINE
jdgabbard
    Moonsweeper
  • 284 posts
Posted Thu Nov 15, 2018 4:38 PM
Thats another option... it looks like the CF adapter has a female end on it. It might be as easy as desoldering it and soldering on a 90* header. Wouldnt be difficult...
#32 jdgabbard OFFLINE
jdgabbard
    Moonsweeper
  • 284 posts
Posted Thu Nov 15, 2018 4:42 PM
printing!
Post pictures when you get it done. I want to see the quality of the print on other peoples machines. Also, what type of machine you printed it on if you dont mind.
#33 jdgabbard OFFLINE
jdgabbard
    Moonsweeper
  • 284 posts
Posted Fri Nov 16, 2018 1:21 PM
arcadeshopper, How did this turn out?
#34 arcadeshopper OFFLINE
arcadeshopper
  • 3,848 posts
Posted Fri Nov 16, 2018 2:55 PM
Did ok may need a little support near the power switch. Prusa mk2 pla+..  It fits the nano perfectly though, very nice job!
814fc995ba3edbf688d14ddc68a276bc.jpg9769b342b674d5736d587a91a07b796d.jpg2e55f343c882220c7e30e4ef2018b6fb.jpg
Sent from my LG-H872 using Tapatalk
#35 jdgabbard OFFLINE
jdgabbard
    Moonsweeper
  • 284 posts
Posted Fri Nov 16, 2018 4:43 PM
Awesome! How was the clearance for the power switch, DB9, and Power Jack? Were the LEDs sufficiently aligned?
#36 arcadeshopper OFFLINE
arcadeshopper
  • 3,848 posts
Posted Fri Nov 16, 2018 6:39 PM
Power switch is perfect.. jacks are good too.. I haven't turned it on yet as i don't use my nano much anymore since I have TIPI but first glance the led's seem good
Greg
#37 jdgabbard OFFLINE
jdgabbard
    Moonsweeper
  • 284 posts
Posted Sat Nov 17, 2018 9:24 AM
Awesome!
