The Missing Link
14 replies to this topic
#1 Vorticon OFFLINE
Vorticon
  • 3,495 posts
Posted Wed Oct 24, 2018 6:23 AM
Can TML be converted to a cartridge by any chance?
#2 ti99iuc ONLINE
ti99iuc
  • 1,603 posts
Posted Wed Oct 24, 2018 7:48 AM
maybe i haven't understand good but here is not The Missing Link you search ?
http://atariage.com/...-6#entry3217247
or you mean only this one as .BIN ?
#3 Vorticon OFFLINE
Vorticon
  • 3,495 posts
Posted Wed Oct 24, 2018 9:19 AM
I was looking for a single .bin if available.
#4 Lee Stewart OFFLINE
Lee Stewart
  • 3,871 posts
Posted Wed Oct 24, 2018 9:20 AM
Not unless you make it part of Extended Basic—Vorticon’s XB or VXB, say.  I suppose you could increase the ROM size of XB and set it up to either copy the routines to RAM or to convert the routines to run from ROM.
...lee
#5 --- Ω --- OFFLINE
--- Ω ---
    Sunbaenim
  • 13,499 posts
Vorticon, were you looking for a single version of the program that could be run from the FinalGROM?  If so, I don't think it exists yet.  :(
Until that time, if you don't mind it being on a cartridge with two other versions of BASIC, the link Ciro posted works, although it does require an UberGROM and both 1284P and 49F040 chips.
** EDIT **
Looked like you posted when I was typing.  Maybe someone will be kind enough to make a FinalGROM version for you...
Edited by --- Ω ---, Wed Oct 24, 2018 9:22 AM.
#6 arcadeshopper OFFLINE
arcadeshopper
  • 4,073 posts
Posted Wed Oct 24, 2018 3:04 PM
I have TML as a cartridge, requires a ubergrom  https://www.arcadesh...tegory=15846004
Greg
#7 RXB OFFLINE
RXB
  • 3,460 posts
Posted Wed Oct 24, 2018 3:24 PM
...lee
That would be really really tough to do. See the interpreter is in GPL and calls XB ROMs that calls other XB ROM routines.
Best you could do is upon loading would move from ROM to Lower 8K and run that way, but not from ROM all the time as would be huge conflicts.
#8 arcadeshopper OFFLINE
arcadeshopper
  • 4,073 posts
Posted Wed Oct 24, 2018 3:55 PM
Gazoo figured it out :)
#9 senior_falcon OFFLINE
senior_falcon
  • 1,333 posts
Posted Thu Oct 25, 2018 9:17 AM
Yes, by doing it pretty much the way Rich described. The lower 8K is stored somewhere in the cartridge, probably in a GROM. When you select TML it is copied into low memory and the interrupt routine is started up.
Edited by senior_falcon, Thu Oct 25, 2018 11:15 AM.
#10 RXB OFFLINE
RXB
  • 3,460 posts
Posted Fri Oct 26, 2018 1:27 AM
Now that is something I should do with RXB, but lack the GROM space.
Wonder if I could use extra ROM pages?
#11 Vorticon OFFLINE
Vorticon
  • 3,495 posts
Posted Fri Oct 26, 2018 6:47 AM
Please do! That would be the ultimate package!
  • RXB likes this
#12 RXB OFFLINE
RXB
  • 3,460 posts
Posted Fri Oct 26, 2018 2:54 PM
So how do you set that up so it does not interfere with normal XB ROMs?
I could include TML, F18 Support and some other packages.
#13 Vorticon OFFLINE
Vorticon
  • 3,495 posts
Posted Fri Oct 26, 2018 3:42 PM
That's beyond my pay grade :) I'll have to let Senior Falcon answer that one.
  • RXB likes this
#14 senior_falcon OFFLINE
senior_falcon
  • 1,333 posts
Posted Sun Oct 28, 2018 1:11 PM
TML is designed to run from low memory (>2000 to >3FFF). Gazoo found a place in the cartridge to store the TML code so it could be copied into low memory. That's all I know about it.
#15 RXB OFFLINE
RXB
  • 3,460 posts
Posted Sun Oct 28, 2018 2:08 PM
I imagine the Cart uses a 8K ROM page to load the Lower 8K  from there just before XB starts up.
If lower 8K is already initialized any CALL LINK or CALL LOAD checks each time to see if Lower 8K has been Initialized.
That is why even if you switch off the console off and on again it still will work as long as you have not turned off P-Box (32K).
