Faulty reset switch
3 replies to this topic
#1 atari-dna OFFLINE
atari-dna
    Moonsweeper
  • 290 posts
Posted Wed Oct 24, 2018 9:36 AM
No function on the switch. Ive replaced C3 1uF to a 10uF. The manual operation is fine, but there is no reset triggered when activating the switch. I welcome all input on diagnosing this problem.
Edited by atari-dna, Wed Oct 24, 2018 9:39 AM.
#2 Hannacek OFFLINE
Hannacek
    Moonsweeper
  • 432 posts
Posted Wed Oct 24, 2018 10:53 AM
Did you test the switch for continuity with a multimeter? A broken trace would be the likely problem.
#3 atari-dna OFFLINE
atari-dna
    Moonsweeper
  • 290 posts
Posted Wed Oct 24, 2018 10:57 AM
I'll get the meter on it this evening.  This is SPST, correct?  Doesn't the reset switch tie directly to the reset line on the Z80 ?
#4 Hannacek OFFLINE
Hannacek
    Moonsweeper
  • 432 posts
Posted Wed Oct 24, 2018 2:10 PM
It is a momentary switch. I would assume it connects a signal to ground (the signal is probably the reset line on the Z80 or another chip). You could first connect a paperclip or something to the two leads on the board to see it it resets.
It is just a simple 2 sided board with no layers, so you can just follow the traces on the bottom and top of the board to see where it connects.
