What will be your Fall/Winter project for the TI?
34 replies to this topic
#26 Airshack OFFLINE
Airshack
    Dragonstomper
  • 846 posts
Posted Thu Nov 15, 2018 2:32 PM
Project #2 is going well!  Console is working (easy fix - the switch cover was not seated on the switch) and now is painted. I am awaiting an F18A to become available.
This orange TI is awesome! Looks like something from 1965-1974 era. Details please on how to best paint the beige away.
Sanding? Primer? Special plastic paint?
Sent from my iPhone using Tapatalk Pro
Edited by Airshack, Thu Nov 15, 2018 2:32 PM.
#27 --- Ω --- OFFLINE
--- Ω ---
    HexaCoreRunner
  • 13,027 posts
Posted Thu Nov 15, 2018 3:01 PM
It's probably the only TI here on AtariAge that most closely resembles the original TI black & orange cartridge labels!   :grin:  :thumbsup:
#28 twoodland OFFLINE
twoodland
    Star Raider
  • 73 posts
Posted Thu Nov 15, 2018 3:16 PM
I used Rust-Oleum Painters Touch 2X "Real Orange" and "Satin Clear" spray paint.  I disassembled the console.  I only painted the top bezel.  I removed the cartridge cover bracket.  Using a hair dryer, I heated up the logo sticker on the top and removed it using a small plastic screwdriver (this worked well and I would have re-used it but it had a scratch on it, so I printed a new one on photo paper, laminated it, then cut it to fit.  I used double-sided tape to reattach).  I cleaned the top bezel using dish soap and warm water, then rinsed with warm water.  After it had dried, I took a cotton ball with 91% Isopropyl Alcohol and rubbed the entire top bezel (over and under).  I then painted the top bezel, doing a very thin coat. I let it dry for 1 hour, then did a second thin coat.  After another hour, I did a third thin coat. I held the can about 8" from the top bezel and would start spraying and stop spraying in the air away from the top bezel, then using a sweeping motion from side to side taking care to paint evenly.  I let it dry for 24 Hours and then did the same process to the underside of the top bezel.  I then let the top bezel dry for 48 Hours. After that, I sprayed the clear coat using the same process (3 thin coats) on the top bezel, top side only (not the underside).  I did not use primer as it was integrated into the paint.  I did not sand between coats (I would have if something had gotten into the wet paint).  After 48 hours, I reassembled the console!
Attached File  Real Orange Paint.jpg   16.39KB   2 downloads
Attached File  Clear Coat Paint.jpeg   13.42KB   2 downloads
Attached File  Label.JPG   14.07KB   2 downloads
I made the TI-99/4A on the label green to compliment the orange color.  I also filled in the line on the power switch using a green crayon.
#29 Airshack OFFLINE
Airshack
    Dragonstomper
  • 846 posts
Posted Sat Nov 17, 2018 2:03 PM
Perfectly detailed response. I’ve saved this message for a future De-Beige-ing.
#30 TI99_IN_TX OFFLINE
TI99_IN_TX
    Combat Commando
  • 6 posts
Posted Sun Nov 18, 2018 1:35 PM
Hello Hello, fairly New 99er here. I've recently bought a few machines and repaired and restored some of them to working condition. I recently purchased a large lot of cassette tape programs and will be recording them and archiving them for people to download and try out on their machines. There isn't a very large library of cassette programs online and I figured this would be a good winter project of TI-99 Program Archiving. Please feel free to contact me if you have interest in a project like this.
 Attached File  ebayti.jpg   132.74KB   0 downloads
#31 Opry99er ONLINE
Opry99er
  • 9,981 posts
Posted Sun Nov 18, 2018 1:37 PM
Cool!!!
#32 arcadeshopper OFFLINE
arcadeshopper
  • 3,848 posts
Posted Sun Nov 18, 2018 2:57 PM
before you make too much effort look at http://ftp.whtech.com/Cassettes
and make sure they aren't already there.. and I'm happy to upload anything new you come up with that's not there.
Greg
#33 --- Ω --- OFFLINE
--- Ω ---
    HexaCoreRunner
  • 13,027 posts
Posted Sun Nov 18, 2018 7:43 PM
Nice thing about those WAV files is that you can load them up in JS99'er if you do not have a real TI.  If you do have have a real TI you can load them up, see if you like them, and if you do, save them as a DSK image on your PC then you can transfer the program to your TI using various methods.
#34 FarmerPotato OFFLINE
FarmerPotato
    Chopper Commander
  • 144 posts
Posted Yesterday, 8:05 AM
Greg
I never looked in the Cassettes directory before. Under Mini Memory it looks like it contains copies of the LINES demo?
I find myself in need of the Mini Memory Line by Line Assembler cassette. Recently I have been hand entering machine code into Easy Bug.
If someone could add the wav file I could really use it.
http://ftp.whtech.co...es/Mini_Memory/
#35 pjduplooy ONLINE
pjduplooy
    Chopper Commander
  • 109 posts
Posted Yesterday, 8:20 AM
Hi
Contains both a dsk image and a wav file.  Works in js99er
  • Attached File  LBLA.zip   90.33KB   4 downloads
