Playstation controllers can work on Colecovision now
Colecovision Omega Race Playstation Dual Shock controller adapter joystick controller
3 replies to this topic
#1 ave1 OFFLINE
ave1
    Moonsweeper
  • 499 posts
Posted Wed Oct 31, 2018 7:54 AM
Today I've got some information to share on how you can get your Playstation controller working on your Colecovision with adapters.  This required some experimenting with using a current-day USB hub with power supply.  Check out my results here:
Here are the adapters you'll need:
1) 9 pin Sega Genesis extension cords (2)
2) Edladdin Seagull 78 controller adapter (converts Genesis controllers to be fully-compatible with the Atari 7800)
3) Tototek Joypad Converter version MD (converts Playstation controllers to be compatible with the Sega Genesis console)
4) PS1 Multitap
5) Speedlink Redeemer Beyond Total Control Playstation 2 mouse/keyboard adapter
6) powered USB hub with power supply
The method:
1) Plug in a Colecovision controller into port 2 of your Colecovision (consider connecting a 9 pin extension cable to it in case you want to sit a little ways away from the console.)
2) Plug a 9 pin extension cable into port 1 of your Colecovision, but don't plug any adapter into it yet. (wait)
3) Connect all the above adapters/PS1 Multitap together but leave the Seagull78 adapter unconnected to the 9 pin extension cable that's plugged into port one of the console.
4) Plug your Playstation controller into port A of the multitap
5) Plug the Speedlink Redeemer into port B of the multitap
6) Connect a powered USB hub (with power supply plugged into the wall)  to the lower USB connector of the Speedlink.
7) Turn on your Colecovision and use the keypad of the port 2 Colecovision controller to make your game selection and start up the game.
8 ) Now plug in the adapters to the extension cable that's plugged into port 1 of your Colecovision and play your game with the connected Playstation controller.  8)
This method works for many,  but not all Colecovision games. The ones that are incompatible with this method are the ones which don't allow a keypad controller that's plugged into port 2 of the console to start up the game, but only a keypad that's plugged into port 1 of the console. If you want to know how to get around that with a 9 pin splitter cable method, take a look at the video presentation.
The nice thing about using Playstation controllers is that both buttons- not just one button- will work in the games that have the 2 button access.
Another really nice aspect is that you can use a flightstick to play games like Zaxxon and River Raid.  Also, it's nice to be able to use an arcade stick to play games like Q-bert or Ladybug.
Edited by ave1, Wed Oct 31, 2018 8:01 AM.
#2 dj_convoy OFFLINE
dj_convoy
    Dragonstomper
  • 892 posts
Posted Wed Oct 31, 2018 10:06 AM
 I admire the dogged persistence that goes into figuring out if a crazy daisy chain like this will work. Kudos. :D
#3 Video OFFLINE
Video
  • 9,389 posts
Posted Thu Nov 1, 2018 5:32 AM
Jesus chri... I mean, cool. What kind of input lag is all that going to give you?
Pretty cool still though.
#4 ave1 OFFLINE
ave1
    Moonsweeper
  • 499 posts
Posted Thu Nov 1, 2018 9:53 AM
I noticed no input lag. It's working great for me.
Also- there is a new development on this. In the U.S., the Speedlink Redeemer adapter (which is a mouse/keyboard Playstation controller adapter) that I've used is hard to find. Well, I've got a new solution to solve that. Replace the Speedlink with a Brook "Game Controller Super Converter" (a PS3/4 controller to PS2 console adapter). This is a much easier adapter to find. I'll show you what both adapters look like:
http://i.imgur.com/Mrf3qmA.jpg
Also tagged with one or more of these keywords: Colecovision, Omega Race, Playstation, Dual Shock, controller adapter, joystick, controller
