Favourite text (programmers) editor on the TI-99/4a
10 replies to this topic
#1 retroclouds OFFLINE
retroclouds
  • 1,684 posts
Posted Thu Nov 1, 2018 11:20 AM
What is your favorite text editor on the TI-99/4a and what features does make it stand out the most?
Also what feature would one appreciate most in 2018 ? For me it would be 80 columns and SAMS
#2 --- Ω --- OFFLINE
--- Ω ---
    Sunbaenim
  • 13,502 posts
Posted Thu Nov 1, 2018 11:41 AM
<< Fred Kaal's EDIT80 >> is my personal favorite.
While it does not support the SAMS card, it does have 80 columns, works flawlessly with the F18A and plays well with TIPI.
Editing BATCH FILES for 4A/DOS is a snap with this program as it does not include the tabular and column information (what I used to unknowingly call garbage) at the end of the files which broke 4A/DOS text files.  It's small, and easy to use.  Since Fred released it, I no longer mess with TI-Writer, BA-Writer or have a need for the E/A editor.
#3 RXB OFFLINE
RXB
  • 3,460 posts
Posted Thu Nov 1, 2018 10:31 PM
Project in future is 80 column Editor Assembler.
Will be combined with 80 Column Text on XB EDIT MODE (RXB) but requires some changes to XB ROMs to work.
Nice upgrade to Fred Kaal's EDIT80 in the future.
#4 retroclouds OFFLINE
retroclouds
  • 1,684 posts
Posted Thu Nov 1, 2018 11:57 PM
ok, here is what I have in mind for a 21st century text progs' editor on the TI-99/4a:
* Support for SAMs
* f18a support (80x24, 80x30)
* split-screen support, panes (e.g. editing/viewing 2 files at once)
* open-file dialog with possibility to select file from list
* command-line option for running #EA5 directly from inside the editor
* cartridge based
* config options
#5 BeeryMiller OFFLINE
BeeryMiller
    Dragonstomper
  • 765 posts
Posted Fri Nov 2, 2018 5:16 AM
Going to throw something out there for people to consider.  Seems like Funnelweb's source may have been released, and if so, probably the easiest for any TI-99/4A development to use that program.
However, Peter Muys wrote an editor for the Geneve 9640 for MDOS mode.  While file access was using the Geneve's XOP's, the video access was through your normal direct video writes.  Just change port addresses, and modify the routine for scanning the keyboard, and you are well on your way to converting the program.
I know the program can handle some pretty large text files.  What I do not recall is if handling those files if it uses paged memory.  If so, the basis for mapped memory may already be in place to allow modifications for the SAMS, etc. to be easier.
Anyways, just throwing it out there should anyone have an itch.
Beery
#6 FarmerPotato OFFLINE
FarmerPotato
    Chopper Commander
  • 220 posts
Posted Fri Nov 2, 2018 12:10 PM
I used TI-Writer, Funlweb, and MyWord into the 90s to do programming, schoolwork and writing.
I used Clint Pulley's QDE the most at the end for coding under MDOS.
#7 F.G. Kaal OFFLINE
F.G. Kaal
    Space Invader
  • 44 posts
Posted Sat Nov 3, 2018 4:59 AM
While it does support the SAMS card, it does have 80 columns, works flawlessly with the F18A and plays well with TIPI.
Just to be correct: EDIT80 is the Editor (version 3.0) of the Editor/Assembler module which doesn't need the module with some features added/changed, like:
  • Added: Upper and lower case character set.
  • Added: Menu option Load: Load file.
  • Added: Menu option Save: Save file.
  • Added: Menu option Purge: Purge file.
  • Added: Menu option eXit: Exit the editor.
  • Changed: Menu option Show (line) into Goto (line), used the character S for Save file.
  • Removed: Menu option Tab (edit tabs) ... can't save this anyway.
  • Added: Hollow cursor when in insert mode.
  • Changed: Number of menu lines to 4 (was originally 2).
  • Added: Error messages (if any) on line 3 of the menu.
  • Changed: Maximum file name length from 20 to 40 characters so that files can be loaded from and saved in a sub directory.
This editor can be loaded like any other E/A option 5 program and is just a bit below 8Kb in size and loads into the LOMEM (>2000) area.
Fred ;-)
Edited by F.G. Kaal, Sat Nov 3, 2018 5:01 AM.
#8 Vorticon ONLINE
Vorticon
  • 3,495 posts
Posted Sat Nov 3, 2018 6:48 PM
PrEditor by far. 80 columns with the F18A, great features like copy and paste, block select, toggle states for line and character inserts, merging of files... Discovered a complete copy with manual in the free bin at one of the Chicago Faires a few years back and have never looked back again! No SAMS support unfortunately, which limits the size of the source files.
#9 Vorticon ONLINE
Vorticon
  • 3,495 posts
Posted Sat Nov 3, 2018 6:50 PM
* Support for SAMs
* cartridge based
* config options
Is this something you are working on? It would be totally awesome!!!
#10 retroclouds OFFLINE
retroclouds
  • 1,684 posts
Posted Sun Nov 4, 2018 2:11 AM
It is something I'm seriously thinking about and last week I started doing some first design work.
Keeping my fingers crossed, I don't have a track programming record lately ;-)
#11 Vorticon ONLINE
Vorticon
  • 3,495 posts
Posted Sun Nov 4, 2018 7:36 AM
Yessss!
