Which Intellivision console to buy?
23 replies to this topic
#1 Tidus79001 OFFLINE
Tidus79001
    Star Raider
  • 214 posts
  • I will not comply
Posted Fri Nov 2, 2018 9:22 AM
I am looking to buy an Intellivision, and don't know the pros and cons of the different models. Which is generally considered to best model to own?
Intellivision Master Component - model 2609
Intellivision II
Intv System III
I'm looking forward to playing Jr. Pac-Man on this system :)
#2 mr_me ONLINE
mr_me
  • 3,682 posts
Posted Fri Nov 2, 2018 9:36 AM
I like the sears intellivision. I prefer the original controller design to the intellivision ii and on the sears unit they are detachable with straight cords. Be carefull with intv system iii, many have flat keypads.
Edited by mr_me, Fri Nov 2, 2018 9:37 AM.
#3 Tidus79001 OFFLINE
Tidus79001
    Star Raider
  • 214 posts
  • I will not comply
Posted Fri Nov 2, 2018 10:11 AM
Excellent information. I agree with your reasoning as to why the Sears version would be best to go with. Hopefully it will not be to difficult to get my hands on that model.
#4 mthompson OFFLINE
mthompson
    Dragonstomper
  • 873 posts
Posted Fri Nov 2, 2018 10:21 AM
+1 for the Sears branded Intellivision for the reasons mr_me stated. Easy to use Flashback controllers with it if you want (with adaptor cables).
#5 Hannacek OFFLINE
Hannacek
    Moonsweeper
  • 432 posts
Posted Fri Nov 2, 2018 10:25 AM
I think the best way to go is Intellivision II because it has removable controllers. The best setup in my opinion is to find or make the adapter to make the Intellivision Flashback controllers work on the Intellivision II
For whatever reason the ColecoVision Flashback controllers are complete junk, but the Intellivision Flashback controllers are pretty good. I'm not sure how that happened, because they were both made by the same company at the exact same time.
#6 mr_me ONLINE
mr_me
  • 3,682 posts
Posted Fri Nov 2, 2018 10:31 AM
All intellivisions have detachable controllers. With the original 2609, you have to remove the top cover to detach the controllers. I still find the original more comfortable than the flashback controllers but it's a good solution for intellivision ii.
It's a minor issue but the Intellivision II has a different sound chip that affects some sounds in a few games.
The difference between the colecovision and intellivision flashbacks was the lincensor.
Edited by mr_me, Fri Nov 2, 2018 10:36 AM.
#7 Hannacek OFFLINE
Hannacek
    Moonsweeper
  • 432 posts
Posted Fri Nov 2, 2018 11:22 AM
I don't consider opening up a console, taking the plastic covers off, and removing the 9 pin header for the controllers, detachable. Under that definition every component, resistor, and capacitor of the Intellivision is removable. Some require soldering, and some do not.
The problem with the original controllers is that they have been used, and are 30 years old. The Flashback controllers are nearly identical, except that they are not 30 years old.
#8 mr_me ONLINE
mr_me
  • 3,682 posts
Posted Fri Nov 2, 2018 11:29 AM
Chips that are socketed are removable too, although not as easy as the controllers. Anything soldered, is not easily removable.
If you want to use flashback controllers with an original 2609 intellivision there are adapter cables that anyone can easily install.
Edited by mr_me, Fri Nov 2, 2018 11:33 AM.
#9 CharonPDX OFFLINE
CharonPDX
    Chopper Commander
  • 154 posts
Posted Fri Nov 2, 2018 12:00 PM
If you have an LTO Flash, an Intellivision II is great, since the LTO can bypass the "third party block" some games have on the Inty2. Without an LTO Flash, I'd go with an original, or if you can get one, a Sears.  With an Inty2, I'd definitely get the Flashback adapter or a Sears controller. They keypad is nasty, and the side buttons are evil.
#10 grips03 ONLINE
grips03
  • 3,786 posts
Posted Fri Nov 2, 2018 6:20 PM
Sears
#11 wolfy62 OFFLINE
wolfy62
  • 3,205 posts
Posted Fri Nov 2, 2018 7:07 PM
I have been using an Intellivision 2 for 35 years,and it sounds like from what I have read here,I should get a Sears console and check it out!
I do use the Flashback controllers  with the adapters on my Inty 2 of course.
Edited by wolfy62, Fri Nov 2, 2018 7:10 PM.
#12 Miketage OFFLINE
Miketage
    Space Invader
  • 25 posts
Posted Fri Nov 2, 2018 8:01 PM
Sears definitely!
#13 mr_me ONLINE
mr_me
  • 3,682 posts
Posted Fri Nov 2, 2018 8:15 PM
The only thing with sears intellivisions is the exec titlescreens don't say mattel electronics presents.
#14 -^CrožBow^- OFFLINE
-^CrožBow^-
  • 6,737 posts
  • Collector of Fine Atari and Sega Antiquities!
Posted Sat Nov 3, 2018 12:22 AM
They do if you swapped the innards from a 2609 into one like I did many years ago.
#15 Lathe26 OFFLINE
Lathe26
  • 3,798 posts
Posted Sat Nov 3, 2018 1:32 PM
+1 Sears
#16 Tidus79001 OFFLINE
Tidus79001
    Star Raider
  • 214 posts
  • I will not comply
Posted Wed Nov 7, 2018 7:52 PM
I purchased a Sear's Super Video Arcade off eBay.  The console was listed as untested.  When I powered up the console it would only display a black screen (tried multiple cartridges).  I cleaned the unit out (blew a bit of dust that was inside the unit) and tried again, but still was getting only a black screen.  I then decided to try not inserting the cartridge in all the way, perhaps about 1/4 millimeter from fully inserted into the cartridge slot (I found this to be a similar issue with the NES) and upon doing that the system was able to load the game without issue.  Is this common?  Is the cartridge port on the Sear's Video Arcade, and Intellivision consoles fiddly like this by design, or is my unit just a bit of an oddball?  Overall not a big deal as I just need to remember that when I insert a cartridge.
Edited by Tidus79001, Wed Nov 7, 2018 8:23 PM.
#17 CharonPDX OFFLINE
CharonPDX
    Chopper Commander
  • 154 posts
Posted Wed Nov 7, 2018 9:28 PM
Try using a cotton swab (aka "Q-tip") lightly dipped in rubbing alcohol on the cartridge slot and on the cartridges themselves to remove any corrosion/dirt. Worked wonders for my systems.  Let them dry a good half hour before applying power again.
#18 boxpressed OFFLINE
boxpressed
  • 2,930 posts
Posted Wed Nov 7, 2018 9:37 PM
This is very common across all models of the Intellivision.
#19 blainelocklair OFFLINE
blainelocklair
    Chopper Commander
  • 232 posts
Posted Thu Nov 8, 2018 1:52 PM
Well, I own two Inty IIs. My main one is off getting recapped (done) and A/V modded (pending) for composite video and RCA audio. The reason I own two of them is because the number pads on my main controllers are starting to deteriorate, one of them badly. I bought the 2nd system just for the controllers, which are really nice. That's the rub with the Inty II: finding original replacement controllers in good shape. The mylar that has the numbers of the number pads on them are not replaceable. Well, they might be, if they were actually reproduced. They're not like the overlays, which are completely flat, of course. The mylars for the Inty II are moulded with frames around the numbers and bottom keys, making them impossible to source, to my knowledge. You'd have to do like I did and find one with good controllers and either resell #2 with the crummy controllers or keep it for parts. It was a cost-cutting system from Mattel, and it shows a bit in some areas.
As far as the A/V port mods go, they can be done, but so far it kind of looks like the mods might not be as effective as they are on the original Inty. DIfferent boards are being tried, but there's some experimentation going on with it. Apparently, getting A/V mods on the original Inty is a well-established and solid process.
I haven't played an original model Inty in a while, but I can tell you for sure that the numbers are hard to find while playing on an Inty II controller. Although the mylars have the raised frames around the numbers, it isn't much help. The original Inty controllers had the dome switch buttons, which I remember being very easy to find without looking. Last time I played an Inty, I found that the stuff that moved around and to which I needed to pay attention was on the TV screen and not the controllers. Better to look there than keep looking down for the numbers. On an aside, I'll have to look into that adapter to use the Inty controllers from the Flashback.
Another small negative is that the Intellivoice doesn't match at all, if you plan to get one. Works fine, just ugly together.
One big reason to get an Inty II, however, is if you plan to ever get the ECS hardware. It is a perfect match in style and color to the ECS products.
So, yeah, I'd follow the wisdom of the Elders and get the Sears Inty or a gen 1 Mattel Inty. I'm sticking with the II for the mod work done, but if I had it to do over again, I'd get the gen 1.
#20 IMBerzerk OFFLINE
IMBerzerk
    Chopper Commander
  • 232 posts
Posted Thu Nov 8, 2018 2:08 PM
+1 on Sears model. I prefer the Inty 1 era, they're just classics.
#21 spacecadet OFFLINE
spacecadet
  • 2,964 posts
Posted Fri Nov 9, 2018 5:27 PM
I have owned an Inty 1, Inty 2 and Sears Super Video Arcade. They're all cool in their own ways. If I were going to own just one, though, it'd probably be just the regular old Intellivision 1. It's kind of the six switch 2600 of Intellivisions; it's the one that just feels the most "Intellivision-like".
The Sears Super Video Arcade is definitely cool because it just looks so, so retro (and did even at the time). I don't think the detachable controllers are that much of an advantage, though, because they can be really hard to find on their own. It's actually easier to replace controllers on a regular Intellivision 1 because they're just much easier to find, and it's really five minutes to open the system and replace them once you know how to do it.
The Intellivision II is cool just to see how much more modern it is, but functionally it's just not quite as good as the original model. The combined on/off/reset button is annoying to use, and the controller keypads suck.
#22 blainelocklair OFFLINE
blainelocklair
    Chopper Commander
  • 232 posts
Posted Fri Nov 9, 2018 6:10 PM
... and the On/Off/Reset dome switch on my spare Inty II just went out today. Guess I'll be placing an order at Console5.
#23 arcade124 OFFLINE
arcade124
    Chopper Commander
  • 228 posts
Posted Sat Dec 29, 2018 4:44 PM
Bumping this to throw in that though I don't own a Sears model (only an INTV I right now), an advantage of its detachable controllers is the opportunity for extensions cables.
#24 mr_me ONLINE
mr_me
  • 3,682 posts
Posted Sat Dec 29, 2018 4:54 PM
It's not hard to turn a "hard wired" model into one that has external de-9 connectors. All you need are a couple of sega genesis extension cables and a knife.
Edited by mr_me, Sat Dec 29, 2018 4:54 PM.
