ascrnet Posted November 3, 2018 Share Posted November 3, 2018 Below I share some small changes 1. All the elements adjust automatically when modifying the size of the window to be able to read all the options. 2. Correctly remove the double quotes that appear in the log 3. New Spanish language update for the current version v4 Regards Quote Link to comment Share on other sites More sharing options...
ebiguy Posted November 3, 2018 Share Posted November 3, 2018 Below I share some small changes 1. All the elements adjust automatically when modifying the size of the window to be able to read all the options. 2. Correctly remove the double quotes that appear in the log 3. New Spanish language update for the current version v4 Regards Hi, FYI, I already removed the double quotes in 4.1 beta. I may build a 4.2 beta very soon. Would you like to give me your changes so that they are in my next build ? Quote Link to comment Share on other sites More sharing options...
ascrnet Posted November 3, 2018 Author Share Posted November 3, 2018 Hi, FYI, I already removed the double quotes in 4.1 beta. I may build a 4.2 beta very soon. Would you like to give me your changes so that they are in my next build ? hi, perfect no problem . All my changes are uploaded to my branch of RespQT here is the link https://github.com/ascrnet/RespeQt regards Quote Link to comment Share on other sites More sharing options...
ebiguy Posted November 3, 2018 Share Posted November 3, 2018 (edited) hi, perfect no problem . All my changes are uploaded to my branch of RespQT here is the link https://github.com/ascrnet/RespeQt regards Well, I am puzzled with branches. I see that you worked on master but TheMontezuma worked on develop. I am not sure which branch I should use. BTW: the changes to optionsdialog.ui are very difficult to merge. I made also a lot of changes (added several panels,...) and both versions are now very different... Will be a hassle to do it ! Edited November 3, 2018 by ebiguy Quote Link to comment Share on other sites More sharing options...
ascrnet Posted November 3, 2018 Author Share Posted November 3, 2018 Well, I am puzzled with branches. I see that you worked on master but TheMontezuma worked on develop. I am not sure which branch I should use. BTW: the changes to optionsdialog.ui are very difficult to merge. I made also a lot of changes (added several panels,...) and both versions are now very different... Will be a hassle to do it ! Hi, the master is the last thing that was released to the public for version v4, formerly there was no developer branch. I will have if I can pass my change to that branch. regards Quote Link to comment Share on other sites More sharing options...
ebiguy Posted November 3, 2018 Share Posted November 3, 2018 Hi, the master is the last thing that was released to the public for version v4, formerly there was no developer branch. I will have if I can pass my change to that branch. regards I know. I started also on master but I discovered later that develop is the latest state with merges from TheMontezuma already accepted. I guess we should all work on develop otherwise we won't have all features at once. Quote Link to comment Share on other sites More sharing options...
ascrnet Posted November 3, 2018 Author Share Posted November 3, 2018 I know. I started also on master but I discovered later that develop is the latest state with merges from TheMontezuma already accepted. I guess we should all work on develop otherwise we won't have all features at once. perfect, I'm going to clone from the development branch and upload my changes again Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted November 3, 2018 Share Posted November 3, 2018 Ah, the joys of open-source projects. I sure wish Joey Z. would come out of hiatus and either merge the spate of changes in the last year or so into the Master branch or relinquish the role of maintainer to someone else. Of course, the alternative is pretty easy - just clone the current Master into someone else's repository, it rename that clone with the changes implemented and then name it something else like "RespeQt 2018", and then do future releases from there. Until/unless Joey returns to the scene, that's kind of the only way forward. Quote Link to comment Share on other sites More sharing options...
ascrnet Posted November 3, 2018 Author Share Posted November 3, 2018 (edited) Hi, good idea to follow. I tried to upload my changes to the developer branch but I do not have access to it I also wrote to Joey Z to see if it appears. regards Edited November 3, 2018 by ascrnet Quote Link to comment Share on other sites More sharing options...
