RespeQt 4.2 beta
23 replies to this topic
#1 ebiguy OFFLINE
ebiguy
    Chopper Commander
  • 215 posts
Posted Sun Nov 4, 2018 3:38 AM
Here is a new beta version called r4.2
What are the changes ?
Only one : now Happy 1050 Rev.7 is supported.
You can use RespeQt and your Happy 1050 drive to create floppies from your ATX images.
Note that this version is now based on the 'develop' branch, meaning that the latest changes from TheMontezuma are embedded in this version.
How to create floppies from ATX images ?
Yes, you know how to use Happy Warp Speed Software v7.1 but there is something special with RespeQt you don't know yet.
I did not manage to fully support Happy double speed (38400) between Happy drive and RespeQt:
- When Happy reads sectors at double speed from RespeQt, it works.
- When Happy writes sectors at double speed to RespeQt, it fails.
Happy Backup program uses the double speed (arg !).
So, to make it work, I had to patch Happy Warp Speed Software v7.1 to make it compatible with RespeQt.
The Backup program now identifies drives as real Happy drives or RespeQt drives.
When writing sectors to a RespeQt drive, the normal speed (19200) is used to be compatible with RespeQt.
Where is the patched Happy Warp Speed Software v7.1.atr ?
There is no patched ATR.
Instead, you have to boot from your Happy Warp Speed Software v7.1.atr image loaded in slot 1 (D1:) and RespeQt will patch it on the fly:
- Change your real Happy disk drive to device number 2 (D2:)
- Load the image Happy Warp Speed Software v7.1.atr in slot 1 (D1:). RespeQt will patch the backup program only if it is located in slot 1 !
- Activate the Happy mode (face with smile)
- Boot your Atari: the Happy main menu appears
- Select option '4' to run the backup program.
- NOW is the time to change the content of slot 1 in RespecQt, load the image you want to copy into slot 1
- Answer 'N' to the question about PDB files.
- Activate Skew option if needed (if you do not know, then activate it) with the keys: 'S', then 'A', and 'X'
- Start the copy process by pressing the 'C' key.
If you do not follow this procedure and you boot from your Happy drive with Happy software inside, then the backup program will not be patched and it will not work with RespeQt.
As you see, the recommanded setting for software preservation using Happy is to set the Happy drive as D2:.
That way, you can either:
- create floppies from ResspeQt (D1:) to Happy drive (D2:) or
- backup floppies from Happy drive (D2:) to RespeQt (D3:) by setting D1: in Unhappy mode just before answering 'N' to the PDB question.
A final note: PDB files are not supported yet ! I did not test that feature. Maybe in a next beta version...
This version should be compatible with Windows XP
Edited by ebiguy, Sun Nov 4, 2018 4:33 AM.
#2 ebiguy OFFLINE
ebiguy
    Chopper Commander
  • 215 posts
Posted Sun Nov 4, 2018 1:30 PM
I just discovered a bug in the version r4.2 above.
The Happy backup feature can copy protected tracks but, sometimes, normal tracks are detected as 'UNREADABLE FORMAT'.
Here is the fix called r4.2.1.
#3 ascrnet OFFLINE
ascrnet
    Chopper Commander
  • 205 posts
Posted Sun Nov 4, 2018 1:52 PM
good work, are these changes in the development branch? I ask why I do not see anything of the HAPPY support :?
#4 ebiguy OFFLINE
ebiguy
    Chopper Commander
  • 215 posts
Posted Sun Nov 4, 2018 2:18 PM
I explained in the thread 'RespeQt 4.1 beta' that I will push my commit when the beta test will be over.
Not a very long time to wait...
My next move will be to support PDB files I guess.
#5 ascrnet OFFLINE
ascrnet
    Chopper Commander
  • 205 posts
Posted Sun Nov 4, 2018 2:42 PM
perfect, I was asking it to generate the .TS to translate the messages. then I will wait :D
regards
#6 DrVenkman ONLINE
DrVenkman
  • 3,970 posts
  • Back off, man! I'm a scientist.
Posted Sun Nov 4, 2018 4:25 PM
It looks like Joey is back accepting pull requests for at least a little bit, per a PM from him last night and some Github activity today. I know he's looking to contact an acquaintaince, TheMontezuma, to potentially take over as the "official" RespeQt maintainer.
In the meantime, it's good to see continued development work by others. :)
#7 _The Doctor__ ONLINE
_The Doctor__
    Flux Capacitor Master Craftsman
  • 6,756 posts
Posted Sun Nov 4, 2018 4:46 PM
I suggest you push what you can right now and perform the pull request, it will make sure the ball is rolling until someone takes over. Time is kind of limited. Here's to hoping whoever takes the wheel is talented and willing to hold the reigns long enough to see the project through.
#8 ebiguy OFFLINE
ebiguy
    Chopper Commander
  • 215 posts
Posted Mon Nov 5, 2018 3:30 PM
I just saw your message now. Hope it is not too late.
I just did the pull request.
If you are in contact with Joey, could you please tell him.
#9 rdea6 OFFLINE
rdea6
  • 2,813 posts
Posted Mon Nov 5, 2018 5:39 PM
Is this just for floppy sized atr's because I can not get a directory of any SpartaDos X 512 sector size.
#10 _The Doctor__ ONLINE
_The Doctor__
  • 6,756 posts
Posted Mon Nov 5, 2018 7:01 PM
why would you have happy activated during 512 sdx sector slot? happy never handled 512 sdx... are you saying a source as that perhaps?
#11 rdea6 OFFLINE
rdea6
  • 2,813 posts
Posted Mon Nov 5, 2018 7:14 PM
So are saying that this version is only for floppy and diskette atr's.
Happy is not activated so version should react to all atr's as the original 4.1 version does....
pclink is working correctly from SpartaDos x
#12 _The Doctor__ ONLINE
_The Doctor__
  • 6,756 posts
Posted Mon Nov 5, 2018 7:43 PM
If I understand? You are saying all happy buttons off with slots normal and it is messing up ATR's that used to work?
#13 Wilheim OFFLINE
Wilheim
    Chopper Commander
  • 221 posts
Posted Sun Nov 18, 2018 7:06 AM
Thank you for the newest version!
Are you planning to make Respeqt work with the SIO2PC USB from Atarimax? I think that device can work at higher speeds directly.
Cheers!
#14 ebiguy OFFLINE
ebiguy
    Chopper Commander
  • 215 posts
Posted Sun Nov 18, 2018 3:10 PM
Cheers!
Short answer is no,
Long answer:
I am a big fan of Steven's products and I bought many products from him.
I like very much Sio2Usb also and I used it for many years.
I wanted to add support for Super Archiver and Happy commands into APE so I contacted Steven to ask how I could do that.
The answer is that it is not possible because the Sio2Usb hardware is intelligent.
If I understood correctly, the hardware transmit only commands it understands to the PC (so it filters Happy and Super Archiver commands).
Changing the firmware to transmit these new commands or implement a passthru mode is complex and Steven did not implement that.
That's why I started to implement Happy and Super Archiver support in RespeQt because the hardware has no intelligence and all data sent by the Atari is received by the PC.
Even if the two devices offer the same features, they are indeed very different.
#15 Wilheim OFFLINE
Wilheim
    Chopper Commander
  • 221 posts
Posted Sun Nov 18, 2018 3:14 PM
Thanks for the answer! I never realize that the ape device is intelligent.
Cheers!
#16 MrFish ONLINE
MrFish
  • 5,474 posts
Posted Mon Nov 19, 2018 11:55 PM
I'm sure everyone understands what you're talking about (I do); but, for clarity, SIO2USB is a stand-alone device
that uses USB flash drives to load disks and files through the SIO port (similar to how an SIO2SD works).
What you're talking about is correctly termed SIO2PC USB, same as all the devices that are used with RespeQt.
#17 _The Doctor__ ONLINE
_The Doctor__
  • 6,756 posts
Posted Tue Nov 20, 2018 12:55 AM
ever use ape with the vapi.dll and a sio2pc.usb? works pretty well.  I am pretty sure more could be done.
#18 morelenmir OFFLINE
morelenmir
  • 1,544 posts
Posted Wed Nov 21, 2018 1:21 PM
Is there any chance that some kind of system to allow *.CAS images to be played back from different points in their run length? For instance, as it stands now all cassettes are played from the beginning. However I have quite a few compilation cassettes that have multiple programmes on them then begin consecutively along the tape. It would be very convenient to be able to 'fast forward' or 'rewind' to one of the later/earlier programmes. I mentioned this once to JoeyZ but--totally understandably--his focus was elsewhere at the time.
It wouldn't need to be anything super fancy like a waveform and visual selector. Just an edit box where you could manually enter the time offset to begin from would be absolutely fine, although a horizontal slider that scrubs from the start time to the finish time would be even better while remaining minimalist. The latter would also automatically take care of bounds checking.
Obviously these are all nothing more than polite suggestions and nebulous ideas. Absolutely no demands of any kind are being made!!!
#19 firebottle OFFLINE
firebottle
    Star Raider
  • 57 posts
Posted Fri Dec 7, 2018 6:52 AM
After reading the above, I'm a little confused about what you can use for this new revision. I have a Happy 1050 board and SIO2PC usb version from Lotharek. I also have the original SIO2PC serial port device. Am I good to go with both or...?
#20 ebiguy OFFLINE
ebiguy
    Chopper Commander
  • 215 posts
Posted Fri Dec 7, 2018 1:09 PM
Yes, you are good !
That's what I am using: Happy 1050 and SIO2PC usb version from Lotharek.
You can use this version for
- running ATX images on your real Atari (load an ATX file in slot D1: of RespeQt)
- creating a real floppy disk from an ATX image (lfollow the instructions in the first post) then you can boot the game from your real drive
#21 firebottle OFFLINE
firebottle
    Star Raider
  • 57 posts
Posted Fri Dec 7, 2018 8:59 PM
Yes, you are good !
Ok, thanks for the info... I'll try it out.
#22 _The Doctor__ ONLINE
_The Doctor__
  • 6,756 posts
Posted Fri Mar 15, 2019 7:11 AM
not sure if it's windows, the usb driver, the pclink portion or whatever but in the last few revisions of respeqt during large drive back up at high speeds a crash sometimes occurs, kyle can get it to happen every time it seems.....   I have had random results... we both went back a couple revs but gave up as it got late, it's important moreso for kyles use because this method is how the boards backs up....
Edited by _The Doctor__, Fri Mar 15, 2019 7:13 AM.
#23 DrVenkman ONLINE
DrVenkman
  • 3,970 posts
Posted Mon Mar 18, 2019 7:14 AM
I’m running on Raspbian Linux. Both these features worked in prior versions of RespeQt but I don’t remember exactly what version they stopped working for me.
I have Windows binaries for this branch on my laptop as well. I can check tonight to see if the issue affects that platform.
#24 _The Doctor__ ONLINE
_The Doctor__
  • 6,756 posts
Posted Mon Mar 18, 2019 11:03 AM
kyle was talking to me about it and we concluded that if we follow the backup and paid attention to the last file to copy and the next file that was to copy we might find a reason for some of this. We agreed to this path and Kyle sifted though the files in as written order and discovered a time/date stamp commonality. It was then verified this was in play as we both have the files it was choking on. It is now in the hands of the current respeqt crew.
I see you have noted some issues with explorering as well, time to play with that some more.
Edited by _The Doctor__, Mon Mar 18, 2019 11:08 AM.
Reply to this topic
