Possible to adapt Eladdin Joysticks for Jaguar Use?
Eladdin Joystick Arcade Pad
13 replies to this topic
#1 travistouchdown OFFLINE
travistouchdown
  • 4,410 posts
  • Do the math!
Posted Thu Nov 8, 2018 8:37 AM
I've been playing some SHMUPS for Jag recently (Raiden, Xenon II) and was thinking how nice it would be to have a big fat arcade joystick on my lap for playing these.  How hard would it be to adapt the Eladdin joysticks that are on the AA store for the 7800 for use with the Jag?  Would a cable do it?  There really aren't many action buttons on a lot of these games and I feel like it's doable in regards to button function/needs.
Or is there a better solution for a Jag arcade pad?  I've only seen highly custom one-off's in the past...
#2 madman OFFLINE
madman
  • 2,817 posts
Posted Thu Nov 8, 2018 12:32 PM
The controller input is matrixed on the Jag, so I don't believe it'd be possible with just a cable.
#3 travistouchdown OFFLINE
travistouchdown
  • 4,410 posts
  • Do the math!
Posted Thu Nov 8, 2018 1:15 PM
Got it.  Maybe i'll reach out to Eladdin and see if he'd be willing to do one model for Jag enthusiasts.  I'd invest in two for fighting games, SHMUPS, etc.
#4 madman OFFLINE
madman
  • 2,817 posts
Posted Thu Nov 8, 2018 1:23 PM
It shouldn't be hard to build the necessary circuit on a little bit of perf board or maybe even direct wired inside a db9 hood.
Edit: This is assuming the 7800 controller uses a 1:1 mapping for each button to a pin. With only 6 on a db9 I imagine this is the case. Also in the time I spent typing this I could've looked this info up.
#5 Zerosquare OFFLINE
Zerosquare
  • 2,752 posts
Posted Thu Nov 8, 2018 3:20 PM
One possibility is this:
https://www.jagware....jaguar-adapter/
It's intended for 2600 joysticks, so there's only one action button, but it should work with 7800 joysticks.
The other possibility is to modify the joystick to make it directly compatible with the Jaguar, either by reusing the PCB from a Jaguar pad, or by building the same circuit on a piece of perfboard like madman says.
Edited by Zerosquare, Thu Nov 8, 2018 3:20 PM.
#6 skip OFFLINE
skip
    Moonsweeper
  • 406 posts
Posted Thu Nov 8, 2018 9:33 PM
Hacking a Jagpad to make a dedicated arcade stick isn't too hard. If you can solder (even at an amateur level like me) it's relatively straightforward. Hacking a prebuilt one like this ( https://www.ebay.com...bl4Sq:rk:2:pf:0) wouldn't be too bad an idea, especially if you can navigate the wire spaghetti in order to keep its originally designed functionality as a bonus.
#7 joeyaage OFFLINE
joeyaage
    Space Invader
  • 49 posts
Posted Thu Nov 8, 2018 10:45 PM
I am surprised there has not been more interest in an arcade/fighting joystick for the jaguar. Look how many different Atari 9 pin D type compatible joysticks were made back in the 80s and 90s. What with the recent interest in a mouse adapter. It would be great if someone could come up with a design that you could plug in a standard 9 pin joystick (or a mouse) and have a pass through so you could plug in a jagpad as well. I do understand that the wiring is different with a jagpad compared to an old style Atari joystick. Hasn't there been an arcade stick made for the Jaguar already? Anyone got any photos or information?
#8 joeyaage OFFLINE
joeyaage
    Space Invader
  • 49 posts
Posted Thu Nov 8, 2018 10:57 PM
My apologies to zerosquare. I have just had a look at his design for an adapter as mentioned in his post just up a bit. Has anybody actually made one of these? Would it be possible to have 3 independent fire buttons with this design?
#9 madman OFFLINE
madman
  • 2,817 posts
Posted Fri Nov 9, 2018 12:40 AM
Yeah, considering all the great fighting games on the Jag is a real shocker.
#10 shaggyneo OFFLINE
shaggyneo
    Combat Commando
  • 9 posts
Posted Fri Nov 9, 2018 12:57 AM
I did something similar for my jag using an old pelican real arcade stick. It has the button layout of the pro controller and a rotary for Tempest. Still need to add new buttons but it works great.20171121_200223313_iOS.jpg
#11 nicolaspersijn OFFLINE
nicolaspersijn
    Star Raider
  • 66 posts
Posted Fri Nov 9, 2018 1:57 AM
I converted a 20th Anniversary SF2 xbobx/ps2 stick to a 6 button Jag stick. Works great but was a ton of work.
#12 skip OFFLINE
skip
    Moonsweeper
  • 406 posts
Posted Fri Nov 9, 2018 2:29 AM
That Pelican stick looks great. Somewhat similar to mine, but mine is completely home made and a bit shoddy on the woodwork side of things ;)
Does it have keypad functionality somehow?
#13 slx OFFLINE
slx
  • 1,625 posts
Posted Fri Nov 9, 2018 6:32 AM
It would be great to have an Edladdin Universal Atari Stick with both 9-pin and Jag outputs selectable via a switch. Best dual to allow for Robotron like games. Hardest choice would be how to build the keypad, telephone style or compatible with overlays. (Over the top would be LCD keycaps selectable for specific games....;-))
Gesendet von iPhone mit Tapatalk
#14 Zerosquare OFFLINE
Zerosquare
  • 2,752 posts
Posted Fri Nov 9, 2018 7:57 PM
I made one for CJ. It works fine.
Unfortunately, no, at least not without adding a second IC.
Also tagged with one or more of these keywords: Eladdin, Joystick, Arcade Pad
