Just bought a Jaguar
5 replies to this topic
#1 grips03 OFFLINE
grips03
  • 3,792 posts
Posted Fri Nov 9, 2018 1:27 PM
I just bought a Jaguar and I was looking forward to playing it this weekend.
However....  Looks like I'll need to wait a bit.
#2 bradd1978 OFFLINE
bradd1978
  • 1,081 posts
Posted Fri Nov 9, 2018 1:33 PM
If you have a Sega model 1, Master System or TG16 power supply, they will all work on the Jaguar. Hope you get to play this weekend :)
#3 Gummy Bear OFFLINE
Gummy Bear
    Dragonstomper
  • 734 posts
Posted Fri Nov 9, 2018 1:35 PM
It's probably just the casing.
Give it a thorough inspection, glue it back together and test it out.
That's what I'd do.
#4 sdamon OFFLINE
sdamon
  • 1,690 posts
Posted Fri Nov 9, 2018 1:42 PM
Can verify... I have a Master System, TurboGrafx, Famicom, and Jaguar all hooked to the same TV and I just rotate that Sega power supply between the four of them as needed.
#5 travistouchdown OFFLINE
travistouchdown
  • 4,417 posts
  • Do the math!
Posted Fri Nov 9, 2018 1:43 PM
Electrical tape around the case.  Will probably work just fine.
Who packs like that though?  Idiot.
Edited by travistouchdown, Fri Nov 9, 2018 1:44 PM.
#6 jaybird3rd OFFLINE
jaybird3rd
  • 9,143 posts
  • "Excuse me, sir? I have a question ..."
Posted Fri Nov 9, 2018 1:46 PM
Ugh, I'm so sorry.  After all the safely-delivered packages that these people must have opened, one would think they'd learn by observation how to pack properly themselves.
Whatever replacement power supply you end up using, if it comes to that, be sure to carefully check the specs.  The Jaguar power supply is 9VDC, 1.2A, center negative.  Do not use a center positive power supply, or it will damage the Jaguar!
