load atari basic programs in turbo basic xl
14 replies to this topic
#1 pmgraphics OFFLINE
pmgraphics
    Space Invader
  • 23 posts
Posted Fri Nov 9, 2018 5:21 PM
I read that turbo basic xl can run atari basic programs at about 3 times the speed. I have some atari basic programs that I made ages ago that are slow. I tried to load them with turbo basic xl but I keep getting an error 170 ?FILE. The progams load fine in atari basic. is it not possible to load atari basic programs in turbo basic xl?
I am using Altirra 2.7 as 600XL/800XL.
thanks
#2 gozar OFFLINE
gozar
    Dragonstomper
  • 956 posts
Posted Fri Nov 9, 2018 6:48 PM
thanks
Error 170 is "File not found". In TBXL type DIR to get a drive listing. Double-check the filename.
#3 Kyle22 OFFLINE
Kyle22
  • 3,753 posts
  • Call my BBS! telnet://broadway1.lorexddns.net
Posted Fri Nov 9, 2018 10:12 PM
LOAD "D:FILENAME.EXT" or, if they are saved as text files, ENTER "D:FILENAME.EXT"
#4 pmgraphics OFFLINE
pmgraphics
    Space Invader
  • 23 posts
Posted Fri Nov 9, 2018 10:41 PM
The file name is correct, it's QUEST.SAV. whether I use load "D:QUEST.SAV" or load "D:QUEST.EXT" they both have the same error-   170 ?file.
Using load "D:QUEST.SAV" in atari basic the program loads and runs.
In altirra I attach
disk one to: Turbo_Basic_XL.atr
disk two to: my_programs.atr
Edited by pmgraphics, Fri Nov 9, 2018 10:51 PM.
#5 MrFish ONLINE
MrFish
  • 5,261 posts
Posted Fri Nov 9, 2018 11:31 PM
In altirra I attach
Well, there's your problem...
If your programs are in D2, then your load command should be LOAD "D2:QUEST.SAV"... not "D:QUEST.SAV".
Edited by MrFish, Fri Nov 9, 2018 11:33 PM.
#6 _The Doctor__ OFFLINE
_The Doctor__
    Flux Capacitor Master Craftsman
  • 5,968 posts
Posted Sat Nov 10, 2018 7:20 AM
face palm...
#7 pmgraphics OFFLINE
pmgraphics
    Space Invader
  • 23 posts
Posted Sat Nov 10, 2018 4:03 PM
Actually I did use LOAD "D2:QUEST.SAV". the D was just a typo in this post.
#8 slx OFFLINE
slx
  • 1,631 posts
Posted Sat Nov 10, 2018 4:16 PM
Do you see your file if you do DIR "D2:*.* ?
If you don't load Turbo BASIC, does it load normally from Disk 2?
Depending on the DOS you use, is the DOS set up for dual drives?
I have attached a more or less "blank" Turbo BASIC XL with XDOS which is capable of dual drives. You can boot with that version and try if it loads from Disk 2.
AFAIK Turbo BASIC XL will not work correctly with DOSes that use memory below the OS (as TBXL uses that area for itself). It didn't work with DOS XL for me but I have not tried a lot of others. Depending on the DOS you use you might have to remove the RAMDISK.
Edited by slx, Sat Nov 10, 2018 4:18 PM.
#9 pmgraphics OFFLINE
pmgraphics
    Space Invader
  • 23 posts
Posted Sat Nov 10, 2018 8:37 PM
The command DIR "D2:*.* produces the message: 999+free sectors.
If I use the disk (the atr file) with QUEST on it by itself, the game does load and play.
I can use this atr in drive2 and a second atr in drive1, load a program from drive1 and save it to drive2.
The atr file is DOS3 if that matters.
I tried your turbobasicxl_dos.atr and it produced the same load error and DIR "D2:*.*" created a similar message: ??? free sectors.
If I need to transfer my programs from dos3 atr files to a different dos atr file, how can I do that?
Thanks
#10 Sikor OFFLINE
Sikor
  • 1,443 posts
Posted Sun Nov 11, 2018 1:44 AM
@pmgraphics: extension *.sav? I think, you dont use any DOS and save savestate of altirra, yes? So, simplyu copy your listing as text in altirra, next - load Turbo Basic XL with any DOS, paste text from clipboard and save as "D:name.ext". Run it now.
Edit:
ohh, you attach Load from D2. You load Turbo Basic first? Step by step:
- Attach disk 1 with Turbo Basic XL and DOS
- attach disk 2 with your programs
- boot without Basic
- DIR "D2:*.*" - list of your games
- now LOAD "D2:name.ext"
good luck.
Edited by Sikor, Sun Nov 11, 2018 2:05 AM.
#11 phaeron OFFLINE
phaeron
  • 2,651 posts
Posted Sun Nov 11, 2018 1:49 PM
Your disk being DOS 3 formatted is the problem. Those disks typically can't be read from any other DOS, including the one that Turbo-Basic XL is booting from.
To resolve this, upgrade to Altirra 3.10 and use its option to convert the disk from DOS 3 to DOS 2 format. This option is on the triangle button for the drive in the Disk Drives dialog, under Convert Filesystem > DOS 2.0S/2.5. Do this on a copy of the disk image. You can also use Disk Explorer to copy the files out to the PC and back into a DOS 2 disk image.
#12 _The Doctor__ OFFLINE
_The Doctor__
  • 5,968 posts
Posted Sun Nov 11, 2018 2:22 PM
or copy the turbo basic disk to a dos 3 disk if it's not going to be a memory conflict.... all of these DOS disk came with conversion utils to copy from one format to another... 2-3 3-2.5 (and that would cover 2 if sd) etc. etc.
but seriously, who would think to try to use incompatible formats together like this, it is akin to using dos 2 and trying to read a dos 2.5 extended file or even just using a MyDos disk to read SDFS or something...
we don't have his specific disks so we can't know what DOS he is using on his turbo basic disk... even though folks tried to get him to copy his files to other dos disks to be certain about this..
so again. Palm - Face
on the other hand it's probably solved so :) thumbs up.
Edited by _The Doctor__, Sun Nov 11, 2018 2:32 PM.
#13 pmgraphics OFFLINE
pmgraphics
    Space Invader
  • 23 posts
Posted Sun Nov 11, 2018 8:24 PM
the basic turbo xl atr, according to disk explorer, is DOS 2.x. So I need to get my programs from the DOS3 atr onto a DOS 2 atr. How exactly do I, "...use Disk Explorer to copy the files out to the PC and back into a DOS 2 disk image," as phaeron mentioned. In disc explorer I don't see the option to copy files out to the Pc and back then back into altirra.
Also the DOS3 menu system seems to only have an option to convert DOS2 to DOS3, if I understood it correctly, as below, the source is DOS2 and destination DOS3.
Access DOS 2 utility
Copyright 1983, Atari
Source drive number? 2
DOS 2 filename? Q.SAV
Destination drive number? 3
DOS 3 filename?
#14 Wrathchild OFFLINE
Wrathchild
  • 2,130 posts
Posted Sun Nov 11, 2018 8:31 PM
You can drag drop files between the disk explorer window and a file explorer window and vice-versa
#15 pmgraphics OFFLINE
pmgraphics
    Space Invader
  • 23 posts
Posted Sun Nov 11, 2018 8:52 PM
Thanks Wrathchild that was simple. My program now loads in turbo basic xl, and it is fast, crazy fast. (thanks phaeron, I now see what you meant)
Edited by pmgraphics, Sun Nov 11, 2018 9:10 PM.
