How to clean your connectors
Jaguar cleaning connectors cartridge
25 replies to this topic
#1 Gummy Bear OFFLINE
Gummy Bear
    Dragonstomper
  • 787 posts
Posted Sun Nov 11, 2018 1:59 PM
Since I'm always rapping about people cleaning their cart connectors, I thought I'd make this guide on how to do it properly :)
It's amazing how many supposed issues can be fixed by clean connectors.
Things you will need:
A Jaguar and a cartridge (preferably dirty):
Some isopropyl alcohol swabs and 2 pieces of plastic card. One roughly the same width as the swabs (like the one pictured) and one small enough to fit in the little end of the connector (which I can't find...) :
If you want to go ghetto instead, you will need a clean t-shirt and some isopropyl or lighter fluid:
Wrap your swab over the edge of your plastic card and insert into one end of the cartridge slot, pull it straight up, move along a bit, then down and up again.
Repeat, repeat. Do NOT move the card sideways while it's inside the slot as you could bend the connectors.
You'll need your small card to get your swab into the small end of the connector.
Keep doing this until the swabs are coming out gleaming white:
Or do the same, ghetto style, with your (preferably white) t-shirt.
Keep the shirt tight over the card so no baggy parts will snag the connector pins, keep wetting it with isopropyl or lighter fluid, move onto a clean patch of shirt, up and down and up and down:
That's your console done!
Now onto the cart!
Isopropyl or lighter fluid and cotton buds (q-tips) :
Grasp your cartridge by the bottom as shown.
I try to keep my fingers off the label so I don't leave any impressions (though the cart shown is a ratty second hand one) :
Dip your cotton bud in your IPA or lighter fluid and scrub those connectors real good!
Keep doing both sides of the connector with fresh buds and fresh liquid until they are coming away gleaming white:
You will likely find that some cotton threads get stuck in there. Just get some tweezers and pull them out.
You're pretty much done at this point, but I like to give my carts the GOLD treatment!
If you want to do the GOLD treatment, you will need another cotton bud and some DeOxit contact enhancer.
The correct use of DeOxit not only protects the contacts and enhances the electrical connection, but it also lubricates the connector so that insertion and removal of the carts is smoother.
This can only be good for the cartridge slot.
Similar procedure to before, but use the DeOxit sparingly! Just one drop on one side of the cotton bud will do for both sides of the connector. Make sure you also wet the beveled edge of the connector:
Now use the clean end of the cotton bud to clean any DeOxit from the plastic parts, then wipe any excess from the connectors, while leaving a nice, light sheen on the pins and the beveled edge:
And that's it!
Every cart I get for every system goes through this, even if it's brand new (my OCD demands it...)
As long as you clean your carts and make sure they stay clean, you should only have to do your console once.
#2 Machine OFFLINE
Machine
    Dragonstomper
  • 579 posts
Posted Sun Nov 11, 2018 2:51 PM
Nice guide, although when I first saw the picture with the red arrows, I thought you wanted us to slide sideways until I read "Do NOT move the card sideways ".
Amazingly, I used your exact cleaning method on my teeth.
Edited by Machine, Sun Nov 11, 2018 2:52 PM.
#3 Gummy Bear OFFLINE
Gummy Bear
    Dragonstomper
  • 787 posts
Posted Sun Nov 11, 2018 2:58 PM
Oh wow... My arrows have failed me!
I thought they would make it extra clear: down up across down up.
Ah well :)
#4 Stage_1_Boss OFFLINE
Stage_1_Boss
    Dragonstomper
  • 918 posts
  • The key is in the skull.
Posted Sun Nov 11, 2018 6:21 PM
I clean my carts but I've never cleaned inside my console's cart slot, I bet that sucker could use it.
#5 Machine OFFLINE
Machine
    Dragonstomper
  • 579 posts
Posted Sun Nov 11, 2018 7:01 PM
Ah well :)
No, it's very clear.........if you can read (which I can't). :)
#6 JagChris OFFLINE
JagChris
  • 3,640 posts
Posted Sun Nov 11, 2018 8:46 PM
[url="%5Burl="http://atariage.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=604176%22%5D20181110_170412.jpg"]http://atariage.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=604176"]20181110_170412.jpg[/url][/url]
I'm real sorry about what happened to your family in Mordor
Edited by JagChris, Sun Nov 11, 2018 8:47 PM.
  • jhd likes this
#7 Gummy Bear OFFLINE
Gummy Bear
    Dragonstomper
  • 787 posts
Posted Mon Nov 12, 2018 3:04 AM
It's probably not too bad if all you have plugged into it are clean carts :)
#8 Gummy Bear OFFLINE
Gummy Bear
    Dragonstomper
  • 787 posts
Posted Mon Nov 12, 2018 3:05 AM
I'm real sorry about what happened to your joke right here
#9 CyranoJ ONLINE
CyranoJ
    RAPTOR Wrangler
  • 5,702 posts
  • reBOOTed
Posted Mon Nov 12, 2018 3:31 AM
He can put that joke in the freezer for a few hours, that'll fix it :)
#10 LinkoVitch OFFLINE
LinkoVitch
  • 2,638 posts
Posted Mon Nov 12, 2018 4:09 AM
You clean your teeth with Isopropyl Alcohol or lighter fluid and a T-shirt???  weird!
I just get my other half to tilt my head back and blow on them strongly :D :D
#11 Gummy Bear OFFLINE
Gummy Bear
    Dragonstomper
  • 787 posts
Posted Mon Nov 12, 2018 6:27 AM
I just blow my own strongly!
Wait...
#12 jericho_21 OFFLINE
jericho_21
    Chopper Commander
  • 189 posts
Posted Mon Nov 12, 2018 10:39 AM
I have a question. The DeOxit. Can a person get something like that in the United States? I would like to find something similar to that here in my country. I am sure you can, but I never heard of it before, hence the question. Or, is it sold as something similar in the US? Thanks. :)
#13 jericho_21 OFFLINE
jericho_21
    Chopper Commander
  • 189 posts
Posted Mon Nov 12, 2018 10:42 AM
I guess they have it on their website sold in US dollars, and I just did a Google search on it. Sorry. Novice question. I was just curious. Thanks anyway for the great guide. I will try it. :D
Edited by jericho_21, Mon Nov 12, 2018 10:43 AM.
#14 JagChris OFFLINE
JagChris
  • 3,640 posts
Posted Mon Nov 12, 2018 12:56 PM
What the hell are you talking about?
#15 Gummy Bear OFFLINE
Gummy Bear
    Dragonstomper
  • 787 posts
Posted Mon Nov 12, 2018 1:00 PM
Yes! Your Jag deserves the gold treatment. :)
DeOxit should be easy to find in the US as I think it is a US product.
I got mine from ebay.
It'll last you for years as well.
#16 Machine OFFLINE
Machine
    Dragonstomper
  • 579 posts
Posted Mon Nov 12, 2018 1:31 PM
I just order it from ebay and it wasn't too expensive:
https://tinyurl.com/y9wmt9xm
#17 jericho_21 OFFLINE
jericho_21
    Chopper Commander
  • 189 posts
Posted Mon Nov 12, 2018 3:07 PM
Yeah, I could order it from eBay as well. I like cleaning my Jaguar products to make them work better. Oxidation happens eventually. So, I do it as a fail-safe measure for that. I live in a basement apartment, so that makes it even more likely. Thanks for the info. It is appreciated.  :)
Edited by jericho_21, Mon Nov 12, 2018 3:08 PM.
#18 jericho_21 OFFLINE
jericho_21
    Chopper Commander
  • 189 posts
Posted Tue Nov 13, 2018 3:15 PM
Agreed. The company that sell the DeOxit, whose website I found, are located in the US state of California. Music to my ears. I might buy a kit. I want my Jag to purr longer and better. So, it isn't expensive. I want to try it. :)
#19 Video OFFLINE
Video
  • 9,422 posts
Posted Thu Nov 15, 2018 5:36 PM
Nice tutorial pretty much covers everything. I'm a cleaner too, I've gotten many games (and a few systems) over the years because they were "dead" and many have been brought back by simple cleaning.
a place to get card stock, I'd add. Use an old credit card, or key card, these make great poser carts for cleaning your console, and are easy to cut to the required shape of size you need.
#20 Guitari OFFLINE
Guitari
  • 1,711 posts
Posted Fri Nov 16, 2018 4:46 AM
Not for Jag carts, but ones a care a little less about, such a gameboy carts I actually use cotton buds and brandy.
#21 Gummy Bear OFFLINE
Gummy Bear
    Dragonstomper
  • 787 posts
Posted Fri Nov 16, 2018 10:40 AM
Remind me never to buy a console from you ;)
#22 Guitari OFFLINE
Guitari
  • 1,711 posts
Posted Fri Nov 16, 2018 10:45 AM
Gets the console a little tipsy but otherwise works well..
#23 Gummy Bear OFFLINE
Gummy Bear
    Dragonstomper
  • 787 posts
Posted Fri Nov 16, 2018 11:36 AM
Brandy contains sugar :)
You're unlikely to wreck anything, but I doubt sugar is a great conductor.
Just as long as you don't sand the contacts though...
I saw some YouTube wanker trying to tell people that sanding cart contacts is great. I gave him a piece of my mind, let me tell ya!
#24 Guitari OFFLINE
Guitari
  • 1,711 posts
Posted Fri Nov 16, 2018 11:50 AM
Well it was really about the alcohol removing the shite.
Is a YouTube wanker like a bus stop wanker?
#25 Gummy Bear OFFLINE
Gummy Bear
    Dragonstomper
  • 787 posts
Posted Fri Nov 16, 2018 2:08 PM
I am unfamiliar with such a specimen.
If it's a wanker that is located at a bus stop, then probably similar :)
Also tagged with one or more of these keywords: Jaguar, cleaning, connectors, cartridge
