+videofx Posted November 16, 2018 Share Posted November 16, 2018 I just got a brand new Kaypro PC (built 1989). It has a 5.25 360K floppy drive and 20mb hard disk. I copy all the files to my hard drive. I then do TI99_PC /menu or I have also tried just from the command line and I try to format and create a disk and as soon as I hit F6, the floppy drive LED never comes on and the PC locks up and have to power down to reboot. Ctl-alt-del has no effect Anyone have any idea? Thanks Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted November 17, 2018 Share Posted November 17, 2018 I just got a brand new Kaypro PC (built 1989). It has a 5.25 360K floppy drive and 20mb hard disk. I copy all the files to my hard drive. I then do TI99_PC /menu or I have also tried just from the command line and I try to format and create a disk and as soon as I hit F6, the floppy drive LED never comes on and the PC locks up and have to power down to reboot. Ctl-alt-del has no effect Anyone have any idea? Thanks are you in DOS or windows? It's a dos program that requires direct access to the hardware.. Also it may be a incompatibility with the DOS, what version do you have? Greg Quote Link to comment Share on other sites More sharing options...
+videofx Posted November 17, 2018 Author Share Posted November 17, 2018 are you in DOS or windows? It's a dos program that requires direct access to the hardware.. Also it may be a incompatibility with the DOS, what version do you have? Greg Greg I am running the PC as a strictly DOS machine, I have tried Compaq DOS 3.31 and MS-DOS 5.0 and same problem Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted November 17, 2018 Share Posted November 17, 2018 Greg I am running the PC as a strictly DOS machine, I have tried Compaq DOS 3.31 and MS-DOS 5.0 and same problem Ok good, I have had this working on a 286 with dos 6.22 and a 3.5" 720k disk.. it may be your disk controller isn't compatible.. do you know what controller is on the floppy card? Quote Link to comment Share on other sites More sharing options...
+videofx Posted November 17, 2018 Author Share Posted November 17, 2018 do you know what controller is on the floppy card? Yup, Its a Zilog Z0765A08PSC Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted November 17, 2018 Share Posted November 17, 2018 Nice so did you read the doc file about controller compatibility Sent from my LG-H872 using Tapatalk Quote Link to comment Share on other sites More sharing options...
+videofx Posted November 17, 2018 Author Share Posted November 17, 2018 Nice so did you read the doc file about controller compatibility It's not the controller. It the PC. I thought and XT with 360K floppy would work. When reading the manual I found this: You will need an AT class PC. An XT class PC will not work, because the software uses some AT reserved instructions. I was going to try my IBM PC XT I will try just for fun. It should show the same behavior as my Kaypro XT 4 Quote Link to comment Share on other sites More sharing options...
