ElementalChaos Posted November 20, 2018 Share Posted November 20, 2018 Hi all, I have a question/concern about the Atari brick power supply I'm using to power my 800. It obviously is working, but I always check the voltages my power supplies are putting out using a multimeter just to make sure I'm not gonna be frying my system. Measuring the plug without any load, I am getting 11 volts. Now I don't know if it droops down to a more reasonable level under load or if the 800's power circuitry is able to handle a bit of an overvoltage like that, but is that normal to be getting out of one of these supplies? Should I play it safe and stop using this one? Is there any test point on the 800 power board where I can see the raw voltage after it goes in the machine? Thank you. Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted November 20, 2018 Share Posted November 20, 2018 It's fine. That is a normal no-load measurement. The regulators can easily handle it. 2 Quote Link to comment Share on other sites More sharing options...
+Nezgar Posted November 20, 2018 Share Posted November 20, 2018 Looks good to me! Some background: The 7805 regulator requires a minimum of 7V input, and can handle up to 35V (with extra heat generated) for 5V output. So, 11V AC (closer to 9V AC under load) is in a nice place at the lower end of this spectrum. For the 7812 regulator, the 9V input gets doubled to 18, also a nice position between the 14.5V to 30V input requirements for 12V output. 2 Quote Link to comment Share on other sites More sharing options...
BillC Posted November 20, 2018 Share Posted November 20, 2018 As Kyle22 mentioned there is a difference between loaded and unloaded voltage measurements. There is also peak versus RMS voltage, most meters give peak voltage measurements. https://en.wikipedia.org/wiki/Root_mean_square 2 Quote Link to comment Share on other sites More sharing options...
tjlazer Posted November 20, 2018 Share Posted November 20, 2018 (edited) Make sure you don't have the 5200 DC power supply! I made that mistake when trying to power my 1050 disk drive and it was not working correctly! Edited November 20, 2018 by tjlazer Quote Link to comment Share on other sites More sharing options...
shoestring Posted November 20, 2018 Share Posted November 20, 2018 Hi all, I have a question/concern about the Atari brick power supply I'm using to power my 800. It obviously is working, but I always check the voltages my power supplies are putting out using a multimeter just to make sure I'm not gonna be frying my system. Measuring the plug without any load, I am getting 11 volts. Now I don't know if it droops down to a more reasonable level under load or if the 800's power circuitry is able to handle a bit of an overvoltage like that, but is that normal to be getting out of one of these supplies? Should I play it safe and stop using this one? Is there any test point on the 800 power board where I can see the raw voltage after it goes in the machine? Thank you. My 1050 is brand new and I can confirm the same readings on the DMM Quote Link to comment Share on other sites More sharing options...
