I have an Atari Hockey Pong that is overall in pretty good condition and works quite well in all respects except one; when the ball hits a paddle in game, it fails to register and just passes straight through. Anyone know what might cause this?
Posted Wed Nov 21, 2018 11:24 AM
Posted Wed Nov 21, 2018 11:43 AM
Pulled the goalie too early in the 3rd.
Posted Thu Nov 29, 2018 8:10 PM
Unfortunately everything is contained on a single IC within the unit.
So it is possible the IC may be failing, you can do some basic investigative work, check the ohms on the resistors to see if one or more is not within tolerance, its very possible a cap may have failed and the IC may not be getting proper voltage, check that it is getting proper voltage and also check around the pcb for any corrosion and possible contact grounds. Sorry I can't really offer you more than that, but it could just be a bad component or the IC itself may starting to take the long walk...
Edited by Curt Vendel, Thu Nov 29, 2018 8:11 PM.
Gaming General →
Classic Gaming General →
Anyone here collect old Pong games?Started by z3k3, 14 Feb 2019 ![]() |
Atari Systems →
Atari 2600 →
Paddles in HD, the current stateStarted by YeOldeTARDIS, 3 Nov 2018 ![]() |
Community →
Events →
Retrogathering 2018, September 29 (Västerås, Sweden)Started by carlsson, 18 Sep 2018 ![]() |
Atari Systems →
Atari 2600 →
![]() Atari Flashback 2 GamesStarted by Atari PAC-MAN Fan, 7 Aug 2018 ![]() |
Atari Systems →
Atari 8-Bit Computers →
![]() Anyone has this game ?Started by slydc, 1 Aug 2018 ![]() |
