Updating Firmware
Harmony Cart Firmware
3 replies to this topic
#1 matalog OFFLINE
matalog
    Combat Commando
  • 2 posts
Posted Sun Nov 25, 2018 7:02 PM
I recently got a harmony cart from the maker, sent to Ireland.
It was sent with NTSC firmware installed, and upon plugging it into my PC (I have tried 2 PCs, one with Windows 8.1 and one with Windows 7) I found that it was not recognised.  I tried 4 different cables and eventually one of the cables let one of the PCs recognise the device and install it.
I had also installed the recommended drivers.
This is the info showing what USBDeview can see, and that at the same time the cart is seen in it, it is not seen by the Harmony cart software.
I then noticed that the latest NTSC firmware could be loaded from SD and that ability arrived quite a few years ago, which made me wonder if the same facility existed for PAL?
I can currently see the menu, but it is in greyscale and not great to load from, as it causes the TV to flicker for 2 seconds everytime it changes mode from NTSC in the menu to PAL in the games.
Any ideas on what I might do to change the firmware?
Edited by matalog, Sun Nov 25, 2018 7:10 PM.
#2 Thomas Jentzsch OFFLINE
Thomas Jentzsch
    Thrust, Jammed, SWOOPS!, Boulder Dash, THREE·S, Star Castle
  • 24,032 posts
  • Always left from right here!
Posted Mon Nov 26, 2018 6:38 AM
AFAIK there is no official PAL latest firmware existing. And the latest official NTSC firmware (1.07) is already some years old.
#3 iesposta OFFLINE
iesposta
  • 3,904 posts
  • Retro-gaming w/my VCS
Posted Sat Dec 8, 2018 4:38 AM
Where is this official NTSC firmware (1.07)?
I looked in this forum’s pinned official firmware thread, github, Internet.
I found your modded version called “hbios_107_NTSC (unofficial).bin” for adding menu selection with joystick in Player 2 for when the Trak-Ball is in Player 1.
Thank you for all you do for Atari 2600 and AtariAge.
P.S. On my 2012 iMac, my Harmony and now also Harmony Encore only work when I uninstalled the recommended FTDI drivers I downloaded and installed. The iMac already has FTDI drivers built in, and installing downloaded drivers causes failure.
Also as mentioned, I found that most USB to Harmony cables do not work. The reason being they are charging cables (2 wire) and not data cables (4 wires). More often than not the cheap ones are data, and the nice sturdy ones are only charging.
Edited by iesposta, Sat Dec 8, 2018 4:49 AM.
#4 Thomas Jentzsch OFFLINE
Thomas Jentzsch
  • 24,032 posts
Posted Sat Dec 8, 2018 4:41 AM
Sorry, my bad. 1.06 was the last official firmware.
