XB256 - Which address for VDP signal on/off?
26 replies to this topic
#1 gekido_ken OFFLINE
gekido_ken
    Space Invader
  • 33 posts
Posted Tue Nov 27, 2018 3:23 PM
Hi, I have a question for XB256.
I know that the TMS9918 has 7 registers plus 1, and that register 1 is used to set the different text / graph modes.
However I know that it is possible (as I do on MSX) to disable the video signal while the screen is drawn, and then reactivate it after the construction of the graphics. This is to prevent the visualization process of the on-screen graphics from appearing and showing everything only at the end of the process.
With which address and command CALL LOAD is it possible to do the same?
Thank you.
Edited by gekido_ken, Tue Nov 27, 2018 3:44 PM.
#2 HOME AUTOMATION OFFLINE
HOME AUTOMATION
    Moonsweeper
  • 384 posts
Posted Tue Nov 27, 2018 4:32 PM
Hi,
I'm not familiar with the MSX, or XB.
but the 9918, mmm a little.
Maybe Register 1, Bit 1...
Edited by HOME AUTOMATION, Tue Nov 27, 2018 4:40 PM.
#3 Stuart ONLINE
Stuart
    Dragonstomper
  • 853 posts
Posted Tue Nov 27, 2018 5:44 PM
Register 1 bit 1 as message above … but you can't set that directly using a CALL LOAD. You'll need to write and load a small assembly program to set the register bit, and call that program through a CALL LOAD.
(Although I now wonder if you can use CALL LOAD to set the screen timeout counter to blank the screen?)
#4 RXB OFFLINE
RXB
  • 3,550 posts
Posted Tue Nov 27, 2018 7:19 PM
Or use RXB to do that it has CALL POKER(VDP register #,numeric variable)
POKER subprogram                                      PAGE P4
Format CALL POKER(vdp-number,numeric-variable[,...])
CALL POKER(numeric-variable,number[,...])
Description
The POKER command writes to vdp register a byte value. Only
registers 0 to 7 are valid. The byte value ranges 0 to 255.
Programs
This sets text mode.        | >100 CALL POKER(7,244,1,240)
This is a delay loop.       | >110 FOR L=1 TO 500 :: NEXT L
This sets multi color mode  | >120 CALL POKER(1,232)
This is a delay loop.       | >130 FOR L=1 TO 500 :: NEXT L
This sets bit map mode.     | >140 CALL POKER(0,2,1,2)
This is a delay loop.       | >150 FOR L=1 TO 500 :: NEXT L
This sets normal XB mode.   | >160 CALL POKER(0,0)
Not released yet RXB next version has CALL VDPSTACK(address) to move the VDP stack location in VDP to where you want it.
Not release yet is RXB next version has CALL PRAM(address) to move the RAM end address in RAM to where you want it.
So in RXB you can customize XB to where everything is located.
#5 senior_falcon OFFLINE
senior_falcon
  • 1,411 posts
Posted Tue Nov 27, 2018 10:42 PM
Thank you.
With a little cleverness this can be done XB256.
Here is the description of SCREEN in the XB256 manual:
CALL LINK(“SCREEN”,color-code) (both screen1 and screen2)
This can be used to change the background color in the current screen. This is identical to
CALL SCREEN except the background colors of the screens are saved/restored when you
switch screens.
Here is the assembly code for SCREEN:
SCREEN LWPI WKSP
              CLR R1
              BL @GETNUM
              DATA 1
              DATA 16
              MOV @>834A,R0
              AI R0,>070F REGISTER 7, foreground=black
              BLWP @VWTR
              (and a few omitted lines that save the screen color)
The 1 and 16 are limit checks so the screen color is a valid number from 1 to 16. But with CALL LOAD(14864,128) you can defeat the lower limit check by making the 1 into >8001.
Now with CALL LINK("SCREEN",-1391 you can set VDP R1 to >A0 which blanks the screen. (-1391 is >FA91. When you add >070F you get >01A0 which tells VWTR to write A0 to VR1)
With -1327 you can set it back to the default >E0 to make the screen visible.
If you wanted to totally disable both lower and upper limit checks, you can CALL LOAD(14864,128,0,127,255) and then any VDP register can be changed to any desired value - just remember that >070F will be added.
If you will be compiling the program you don't need the CALL LOAD because the compiler does not do limit checks.
Edited by senior_falcon, Wed Nov 28, 2018 6:58 AM.
#6 gekido_ken OFFLINE
gekido_ken
    Space Invader
  • 33 posts
Posted Wed Nov 28, 2018 1:05 PM
Computer left message BAD VALUE
#7 Tursi OFFLINE
Tursi
  • 5,557 posts
  • HarmlessLion
Posted Wed Nov 28, 2018 1:16 PM
XB256 is an add-on suite you need to load. :) There's no way to do it with pure XB.
The closest you can get is to set all color sets to transparent (CALL COLOR) then load the correct colors after your screen is ready. It's not quite instantaneous, but it's not bad.
#8 gekido_ken OFFLINE
gekido_ken
    Space Invader
  • 33 posts
Posted Wed Nov 28, 2018 2:38 PM
Infact I load and run XB256.
I write my DATA routines for colorset, charset and mapscreen. But before the routine of drawscreen I insert this:
REM DRAW MAP(S)
1420 CALL CLEAR
1423 CALL LOAD(14864,128)
1425 CALL LINK("SCREEN",-1391)
1430 RESTORE 900
1440 READ W,H,SC::CALL SCREEN(SC)::CALL CLEAR
1450 FOR Y=1 TO H
1460 FOR X=1 TO W
1470 READ CP::CALL VCHAR(Y,X,CP)
1480 NEXT X
1490 NEXT Y
1495 CALL LINK("SCREEN",-1327)
1500 CALL KEY(0,K,S)::IF S=0 THEN 1500
1510 END
The error message il "BAD VALUE IN 1425"
Where is the wrong?
Edited by gekido_ken, Wed Nov 28, 2018 2:38 PM.
#9 senior_falcon OFFLINE
senior_falcon
  • 1,411 posts
Posted Wed Nov 28, 2018 7:54 PM
REM DRAW MAP(S)
1420 CALL CLEAR
Where is the wrong?
This works for me. Make sure you are using the "Frappato" version. One drawback of using direct CALL LOADs to poke a value into a memory location is that revisions to the code can put it in a new location. This means the CALL LOAD is specific to a particular version and may need to be changed for different versions. Frappato can be found in  "TI99/4A development resources" or in 99er.net under downloads.
Edited by senior_falcon, Wed Nov 28, 2018 7:55 PM.
  • RXB likes this
#10 LASooner OFFLINE
LASooner
    Moonsweeper
  • 389 posts
Posted Thu Nov 29, 2018 12:25 AM
Might I recommend the compressed data feature? It captures VDP data and reads it in so fast you don't even need to blank the screen
  • RXB likes this
#11 Retrospect OFFLINE
Retrospect
  • 1,139 posts
Posted Thu Nov 29, 2018 4:43 AM
Yes, this is the trick I use sometimes and even with your code compiled, it still makes a visible difference (if you're looking for it) ... especially in the case of say "Eric In Monsterland" where sometimes the screens can be fairly graphics-heavy.  :)
  • RXB likes this
#12 senior_falcon OFFLINE
senior_falcon
  • 1,411 posts
Posted Thu Nov 29, 2018 11:27 AM
This brings up an interesting possibility for both XB256 and RXB. Normally CALL SCREEN expects a value from 1 to 16. Make that 0 to 16 and have a CALL SCREEN(0) that blanks the screen. CALL SCREEN(1 to 16) enables the screen and sets the screen color. It would be nice to save the sprite magnification and size.
#13 Asmusr OFFLINE
Asmusr
  • 3,086 posts
Posted Thu Nov 29, 2018 11:43 AM
I tried that, but it doesn't seem to work. Not sure why.
#14 gekido_ken OFFLINE
gekido_ken
    Space Invader
  • 33 posts
Posted Thu Nov 29, 2018 12:56 PM
OK THANKS!! I've downloaded "Frappato" version and it works!!!! :)
#15 RXB OFFLINE
RXB
  • 3,550 posts
Posted Thu Nov 29, 2018 8:05 PM
Hmm just looked at code for XB and RXB both use 1 for Transparent in CALL COLOR and CALL SCREEN commands.
The value of 1 is used in Decimal but there is no 16 in HEX (>F0) so every value is decremented thus when you put in 1 it is actually decremented to 0 by GPL GROM.
That means XB and RXB both have 1 for Transparent (>00 in GPL) and 16 White (>0F in GPL).
Edited by RXB, Thu Nov 29, 2018 8:07 PM.
#16 senior_falcon OFFLINE
senior_falcon
  • 1,411 posts
Posted Fri Nov 30, 2018 9:56 PM
This is in the EA manual and is nothing new. What does it have to do with the proposed CALL SCREEN(0)?
#17 RXB OFFLINE
RXB
  • 3,550 posts
Posted Sat Dec 1, 2018 12:52 AM
Is CALL SCREEN(0) supposed to be BLANK SCREEN or TURN SCREEN OFF or just CALL SCREEN(transparent) ??
#18 senior_falcon OFFLINE
senior_falcon
  • 1,411 posts
Posted Sat Dec 1, 2018 8:15 AM
What would the point be in having CALL SCREEN(0) do the same as CALL SCREEN(1)?
What is this thread about? It's about how to blank the screen from XB. You do that by setting bit 1 of VR1 to 0. You make the screen visible again by setting that bit to 1. So..
CALL SCREEN(0) sets bit 1 to zero
CALL SCREEN(1 to 16) sets bit one to 1 and sets the color as specified. It would be nice, though not essential, to keep the sprite magnification the same. Since you can't read VDP registers, you'd have to store the value for VR1 somewhere and then MAGNIFY would update both the register and also the stored value.
#19 RXB OFFLINE
RXB
  • 3,550 posts
Posted Sat Dec 1, 2018 8:59 AM
Yea that would be better. And you can do that in RXB of course using a variable in XB for storage CALL VPOKER(register-variable,numeric-variable,numeric-variable)
Would love a version of 256RXB...
#20 sometimes99er OFFLINE
sometimes99er
  • 4,222 posts
Posted Sat Dec 1, 2018 9:33 AM
This brings up an interesting possibility ... Normally CALL SCREEN expects a value from 1 to 16. Make that 0 to 16 and have a CALL SCREEN(0) that blanks the screen. CALL SCREEN(1 to 16) enables the screen and sets the screen color ...
Absolutely. Should have been like that in the original XB. :)
#21 RXB OFFLINE
RXB
  • 3,550 posts
Posted Sat Dec 1, 2018 6:44 PM
Well that would mean a 1 of a kind routine as here is the GPL Code from TI Extended Basic:
[2336]               ***********************************************************
[2337]               * SUBROUTINE FOR 'RANGE' USED IN ALL SOUND AND GRAPHICS
[2338]               ***********************************************************
[2339] ACA0 0F,7E    RAN16  XML  SPEED             Insure in range
[2340] ACA2 02              BYTE RANGE          *   of 1 to 16
[2341] ACA3 01              BYTE 1
[2342] ACA4 00,10           DATA 16
[2343] ACA6 92,4B           DEC  @FAC1             Adjust to internal range
[2344] ACA8 00              RTN
This subroutine is used by CALL COLOR, CALL SCREEN,  CALL SOUND so like I said a special version would be needed for CALL SCREEN(0)
Also a new routine would been needed for blanking the screen.
Thus what use would this be? I mean a CALL CLEAR is normally used in XB for this effect?
#22 OLD CS1 OFFLINE
OLD CS1
    Technomancer
  • 6,000 posts
  • Technology Samurai
Posted Sat Dec 1, 2018 10:17 PM
[2344] ACA8 00              RTN
Not talking about just clearing the screen, they are talking about setting the bit which turns off all layers except the background, same as how the screen blanker works.  It would require detecting that 0 has been sent to SCREEN() and then setting the proper register bit.  It also means that any other value passed to SCREEN() will need to either track that bit manually (which, IIRC, there is a copy of the register in CPU RAM) or simply set the proper value for that bit to make sure the screen is turned back on.
#23 senior_falcon OFFLINE
senior_falcon
  • 1,411 posts
Posted Sat Dec 1, 2018 10:58 PM
Read the original post.
#24 RXB OFFLINE
RXB
  • 3,550 posts
Posted Sun Dec 2, 2018 1:01 AM
The only way to track that would be in the TI OS that I can see.
Now in RXB POKER is POKE VDP Register using Classic99 I typed in:
CALL POKER(0,0) :: CALL KEY("",0,K,S) :: CALL POKER(0,1)
And Classic99 Debugger showed It changed VDP Register # 0 but nothing happened????
This should have disabled Video Display???
And CALL POKER(0,1) should have re-enabled it...so can someone try this on real iron TI99/4A?
Edited by RXB, Sun Dec 2, 2018 1:03 AM.
#25 Asmusr OFFLINE
Asmusr
  • 3,086 posts
Posted Sun Dec 2, 2018 1:20 AM
You need something like CALL POKER(1,-96) to turn off the screen, and CALL POKER(1,-32) to turn it on again.
Edited by Asmusr, Sun Dec 2, 2018 1:21 AM.
  • RXB likes this
