Show that you like the new cart style
20 replies to this topic
#1 karri OFFLINE
karri
  • 2,549 posts
Posted Mon Dec 3, 2018 2:31 AM
I had to order some new boards and found out that there is a competition going on. So I shared my order in order to participate in the competition.
So please vote for my design. Like it. Download the gerbers.
https://www.pcbway.c...XX13_order.html
The design is now shared with all who wants to make games for the Lynx.
#2 davidcalgary29 OFFLINE
davidcalgary29
  • 6,140 posts
Posted Mon Dec 3, 2018 6:48 AM
LOVE that new design!!
#3 Turbo Laser Lynx OFFLINE
Turbo Laser Lynx
    Moonsweeper
  • 496 posts
Posted Mon Dec 3, 2018 7:19 AM
Liked and voted! :thumbsup: :)
#4 42bs OFFLINE
42bs
    Moonsweeper
  • 276 posts
Posted Mon Dec 3, 2018 9:03 AM
Is it programmed by the Lynx (through ComLynx)?
Edited by 42bs, Mon Dec 3, 2018 9:03 AM.
#5 karri OFFLINE
karri
  • 2,549 posts
Posted Mon Dec 3, 2018 10:25 AM
Unfortunately no. I use a Raspberry Pi with two SPI parallell chips. The programmer board, schematics and code is in the lynx/contrib/blankcarts directory.
#6 42bs OFFLINE
42bs
    Moonsweeper
  • 276 posts
Posted Mon Dec 3, 2018 11:32 AM
So it would be possible if one makes a ComLynx to SPI ... ;-)
#7 high voltage OFFLINE
high voltage
  • 6,758 posts
Posted Mon Dec 3, 2018 12:04 PM
I like the mug (cup)
#8 Kosmic Stardust OFFLINE
Kosmic Stardust
    Princess Rescuer
  • 18,383 posts
Posted Mon Dec 3, 2018 12:52 PM
i love the bamboo! :lust:
#9 mvirtuale OFFLINE
mvirtuale
    Chopper Commander
  • 175 posts
Posted Mon Dec 3, 2018 3:03 PM
I wait for my bamboo copy to give my vote.
From the photos I can not give a judgment.
For now, I appreciate the reason for the choice. Save our planet.
#10 karri OFFLINE
karri
  • 2,549 posts
Posted Mon Dec 3, 2018 3:07 PM
Actually I have a cart that controls 3-colour LEDs using clock and data lines only. Almost SPI.
#11 mvirtuale OFFLINE
mvirtuale
    Chopper Commander
  • 175 posts
Posted Mon Dec 3, 2018 3:12 PM
I'm sure I'll like it
Edited by mvirtuale, Mon Dec 3, 2018 3:15 PM.
#12 necrocia OFFLINE
necrocia
    Moonsweeper
  • 282 posts
Posted Tue Dec 4, 2018 2:47 PM
Nice work Karri. Maybe I should have submitted my cart slot adapter too - though it's such a simple PCB it would not be worth it.
#13 karri OFFLINE
karri
  • 2,549 posts
Posted Wed Dec 5, 2018 7:00 AM
Thanks. My two chip design is not rocket science either.
#14 42bs OFFLINE
42bs
    Moonsweeper
  • 276 posts
Posted Wed Dec 5, 2018 7:29 AM
No picture, no kicad, so I guess: One needs a Lynx-connector and the programmer is an SPI to parallel mimicking the Lynx?
So programming from the Lynx should also be possible, or not?
#15 gambler172 OFFLINE
gambler172
  • 3,336 posts
  • none
Posted Wed Dec 5, 2018 3:55 PM
great style....also voted
#16 karri OFFLINE
karri
  • 2,549 posts
Posted Thu Dec 6, 2018 1:24 AM
Actually the pictures, KiCad's are in the repo. I just did not want to rub lots of technical bits in the face of the readers.
git clone https://bitbucket.or...rilynx/lynx.git
cd lynx/contrib/blankcart/LynxProogrammer (contains the KiCad files for the programmer)
cd lynx/contrib/blankcart/programmer (contains the software to read or write flash carts. Required a Pi)
cd lynx/contrib/blankcart/TsopCart (contains the KiCad files for the cart itself)
There is also other KiCad carts like the original large cart and a new 2M Tsop cart that I showed at eJagfest.
#17 karri OFFLINE
karri
  • 2,549 posts
Posted Thu Dec 6, 2018 1:29 AM
If programming from a Lynx would be important I would use the same chips I used at my developers flash. But unfortunately these chips are BIG. and therefore also expensive. I only used 8MB and 16MB chips in the past. So after looking at the amount of pins required I would say that programming from a Lynx could be easier to do using the SD cart.
#18 42bs OFFLINE
42bs
    Moonsweeper
  • 276 posts
Posted Thu Dec 6, 2018 2:27 AM
:-) I meant: I have no KiCAD installed, so the schematics are of no help. So putting the PDFs or pictures in the repo might help.
But the Lynx adapter must be ripped of some old Lynx, or can one by those ... a quick search did not find any.
#19 karri OFFLINE
karri
  • 2,549 posts
Posted Thu Dec 6, 2018 2:58 AM
Ripping the adapter from a Lynx is no longer necessary. I can easily make pogo-pin adapters :)
I have not yet solved how to replace my thumb to press down the cart while I am programming it. But it works.
For soldering the pogo pins I made a jig with 16mm long holes. So I just drop in all pins in the jig and solder the board from the back side.
And a picture of the cart.
Edited by karri, Thu Dec 6, 2018 3:03 AM.
#20 42bs OFFLINE
42bs
    Moonsweeper
  • 276 posts
Posted Thu Dec 6, 2018 3:21 AM
Ah, test adapter pins. Great idea. Would a rubber band give enough pressure?
Maybe let the block you place the card on go left and right as wide as the pins:
#21 necrocia OFFLINE
necrocia
    Moonsweeper
  • 282 posts
Posted Thu Dec 6, 2018 3:41 AM
The PCB I mentioned is a replacement Lynx cart slot adapter using the smallest pogo pins you can buy. Should have it assembled soon, assuming it arrives. I have the pogo pins and the programmer board, just waiting for the rest of the PCBs I've had manufactured. Will have the whole design revealed soon. It solve's karri's press down issue (hopefully).
