TI99 DIS/VAR Disk
15 replies to this topic
#1 videofx OFFLINE
videofx
    Moonsweeper
  • 257 posts
Posted Mon Dec 3, 2018 3:26 PM
I just found a bunch of TI99 Disks and I am checking them to see if they work. The first disk I loaded says TI99 COM22. All the files are _I extension. I tried loading them in TI Basic and Extended basic and get an error on any file I try to load.
When I do a directory on my basic programs it says PROGRAM.
What is DIS/VAR 80, what is an _I file and how to I load them and run them? Here is a photo if that helps
Thanks!
Bill
Attached File  IMG_3580.jpg   2.7MB   2 downloads
#2 mizapf OFFLINE
mizapf
  • 3,678 posts
Posted Mon Dec 3, 2018 3:28 PM
DIS/VAR 80 is the standard text file format, which can be loaded by Editor/Assembler. Or you can OPEN the file in Extended Basic and do a loop with LINPUT #1:A$ :: PRINT A$.
  • RXB likes this
#3 videofx OFFLINE
videofx
    Moonsweeper
  • 257 posts
Posted Mon Dec 3, 2018 3:40 PM
When I hit 1 for load in Assembler/Editor I get I/O 7 error. Does that mean it can read the disk?
#4 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 14,042 posts
Posted Mon Dec 3, 2018 3:46 PM
TI-Writer, BA-Writer or Fred Kaal's new Editor program will work as well.
#5 RXB OFFLINE
RXB
  • 3,605 posts
Posted Mon Dec 3, 2018 3:49 PM
Thanks!
Bill
Dis/Var 80 with a filename _I is for Image Programs and I think for TI Artist if I remember correctly.
#6 sparkdrummer OFFLINE
sparkdrummer
  • 1,099 posts
  • Status? I don't need no stinkin' status!
Posted Mon Dec 3, 2018 4:05 PM
The _I extension was used in Ti-Artist. It stood for Instance. Those disks you have were probably COMPANION disks sold by Texaments I believe. Instances were small graphic files that could be loaded for use when creating a TI-Artist page. It would be good to see your collection uploaded here because a certain newsletter editor is always looking for new art.
#7 mizapf OFFLINE
mizapf
  • 3,678 posts
Posted Mon Dec 3, 2018 4:14 PM
You need the Editor program. The cartridge loads the Editor on demand. The Editor is on E/A disk 1 (file name EDIT1).
#8 videofx OFFLINE
videofx
    Moonsweeper
  • 257 posts
Posted Mon Dec 3, 2018 4:19 PM
LOL, I realized after thinking that I need the Assembler / Editor disks. I am making them now.
THanks
#9 videofx OFFLINE
videofx
    Moonsweeper
  • 257 posts
Posted Mon Dec 3, 2018 4:22 PM
Thanks! I downloaded the TI-Artist disk. I will make a disk and see if these can be loaded!
#10 Ksarul OFFLINE
Ksarul
  • 5,328 posts
Posted Wed Dec 5, 2018 9:59 AM
I recognize several of the TI Artist Instances on that disk. They should load fine once you use Artist to load them. I think there is an Artist Instance viewer out there too that will let you look at all of the Instances on a disk. . .
#11 videofx OFFLINE
videofx
    Moonsweeper
  • 257 posts
Posted Wed Dec 5, 2018 10:04 AM
As soon as my new motherboard arrives I will make the TI-Artist disk and show you guys this pics and see if anyone wants any of the files
#12 Ed in SoDak OFFLINE
Ed in SoDak
    Moonsweeper
  • 434 posts
Posted Thu Dec 6, 2018 12:32 AM
And the UVETICA1_F is a font for TI-Artist. It's larger since it contains an instance for all the characters. It's based on the Helvetica font.
-Ed
  • RXB likes this
#13 videofx OFFLINE
videofx
    Moonsweeper
  • 257 posts
Posted Thu Dec 6, 2018 5:40 PM
-Ed
I was wondering why that file was so much bigger than the others :)
  • RXB likes this
#14 videofx OFFLINE
videofx
    Moonsweeper
  • 257 posts
Posted Fri Dec 7, 2018 10:00 PM
Ok I got TI-Artist running, I load the instance and all I get is a flashing square box.  Show in the pic below.  This happens no matter what instance I load.
#15 sparkdrummer OFFLINE
sparkdrummer
  • 1,099 posts
Posted Fri Dec 7, 2018 11:53 PM
Hit T for Test and the Instance will be shown. If you want to place it on the screen press enter or the fire button on joystick 1.
#16 videofx OFFLINE
videofx
    Moonsweeper
  • 257 posts
Posted Sat Dec 8, 2018 4:47 PM
Thanks!
Every time I hit T I got to see the picture!  If anyone is intererested in any of the instances let me know.
