Limbo game
84 replies to this topic
#1 Yaron Nir OFFLINE
Yaron Nir
    Chopper Commander
  • 204 posts
Posted Tue Dec 4, 2018 3:31 AM
Now that a preview was released for c64
What do you guys think , anyone up for a port for Atari ?
#2 pirx OFFLINE
pirx
    Moonsweeper
  • 457 posts
Posted Tue Dec 4, 2018 8:40 AM
looked at it at the time - tremendous effort to port, might be a bit easier to port it from C64, but not necessarily when C64 uses hi-res sprites and stuff.
#3 emkay OFFLINE
emkay
  • 9,883 posts
  • What's up?
Posted Tue Dec 4, 2018 8:46 AM
Ofcourse the game is possible on the Atari. More than any other "hires" game.
#4 R0ger ONLINE
R0ger
    Moonsweeper
  • 426 posts
Posted Tue Dec 4, 2018 9:13 AM
Not being as experienced as emkay, I don't really see how. It would have to be very different.
#5 Yaron Nir OFFLINE
Yaron Nir
    Chopper Commander
  • 204 posts
Posted Tue Dec 4, 2018 9:44 AM
No reason why it cant be ported
Hi res for scene , using the shades and luminous of grey black and white
Parallax scrolling can be done , mostly I saw trees like moving around.
Main dude can be combined out of 2 sprites with his eyes as 2 pixels
All scenares will use software sprites (spider and traps and rope )
Screen uses fine scrolling
Each level should use the same address space (overwrite the previous level) and id there is not enough men then use a carrridfe and use its mem to use levels
I am going to start working on main char sprites animation
#6 Wrathchild OFFLINE
Wrathchild
  • 2,233 posts
Posted Tue Dec 4, 2018 9:45 AM
Try approaching the author and ask to collaborate on an A8 version?
https://www.lemon64....=64140&start=47
#7 emkay OFFLINE
emkay
  • 9,883 posts
  • What's up?
Posted Tue Dec 4, 2018 10:06 AM
Seeing the latest entries, I understand your position ;)
But, I tell you that a reasonable version of that game is possible, not needing the eye cancer causing transitions as in the C64 version.
You can use basically 3 colors for hires. additionally the hardware priority of the PMg will help adding all possibles tones (0,2,4,6,8,A,e) for the graphics. Playfield is giving the needed hires for the details.
There is not too much going on on the screen. So things can be prepared . The only problem is to get Atari coders to the point that several "treads" have to be used then. If the protagonist is walking alone, the rest of the CPU time needs to handle parts of the upcoming graphics. Loading Stuff from a cartridge is recommended.
Talking to C64 guys for help is like asking a fish for getting milk from a cow.
For the books ;) :
the black color needs to be $D017 and the brighter value $D01A .
For that, the protagonist can be underlaid by a PLAYER , to get the eyes. Adding the other PLAYERS and missiles offers 4 distinguished colors .
PM should be carefully placed to get filtered at the edges by the playfield. Vertical changes allow to use 4x width, which means a little compromise with the background shading.
Edited by emkay, Tue Dec 4, 2018 10:17 AM.
#8 R0ger ONLINE
R0ger
    Moonsweeper
  • 426 posts
Posted Tue Dec 4, 2018 10:12 AM
How do you want to use PMG for the whole screen ? You can do it easily in 4x mode .. but you can only change color 5 times per line. You can use 2x and move PMG in DLI .. I was able to spread them to 144 pixels out of 160. Maybe I could do even more. But all you do is shifting the PMG position. You don't have time to change colors or shape.
I just don't see it.
#9 emkay OFFLINE
emkay
  • 9,883 posts
  • What's up?
Posted Tue Dec 4, 2018 10:25 AM
If you have the PMg , why do you want to do color changes in a scanline?
The most relevant color is black. Then a brighter color builds a huge part of the background, too.
The available PMg will allow to add shade values, while the main impression of the black color, which is actually the relevant part of the game, shows all in hires.
#10 R0ger ONLINE
R0ger
    Moonsweeper
  • 426 posts
Posted Tue Dec 4, 2018 10:43 AM
I guess I'll wait for the images ..
#11 ivop OFFLINE
ivop
    Dragonstomper
  • 922 posts
Posted Tue Dec 4, 2018 11:26 AM
emkay as usual. All talk, no code.
#12 Irgendwer OFFLINE
Irgendwer
  • 1,484 posts
Posted Tue Dec 4, 2018 2:48 PM
Why not supporting the strength of the A8 with it's 16 greys?
The boy would be a PMG, interactive objects maybe too:
The scattered resolution of JAG could be also useful to show e.g. the spider with a sufficient granularity:
Executables:
Attached File  Limbo.zip   4.45KB   70 downloads
#13 flashjazzcat ONLINE
flashjazzcat
  • 14,592 posts
Posted Tue Dec 4, 2018 4:03 PM
Yes: this would make a lot more sense IMO.
#14 MrFish OFFLINE
MrFish
  • 5,474 posts
Posted Tue Dec 4, 2018 8:44 PM
Good idea.
Here's a quick render in Gr. 9 and the boy as a PMG.
Note, the I didn't do anything with the other smaller graphics there.
They could be improved by editing, and using some pmgs too.
Attached File  Limbo Background 1 (lighter).xex   8.16KB   60 downloads
Edited by MrFish, Tue Dec 4, 2018 8:45 PM.
#15 Stephen OFFLINE
Stephen
  • 7,642 posts
  • A8 Gear Head
Posted Tue Dec 4, 2018 10:01 PM
Executables:
attachicon.gifLimbo.zip
Why code or show examples when you can just talk shit about how it's not possible?  Man, you people that actually "do" stuff :)
#16 Yaron Nir OFFLINE
Yaron Nir
    Chopper Commander
  • 204 posts
Posted Wed Dec 5, 2018 3:39 AM
Good idea.
It looks good. Main char though doesnt look hi res as he should.
Is there anyone up for the task of porting this? Even just the demo level ?
#17 Josť Pereira OFFLINE
Josť Pereira
  • 4,251 posts
Posted Wed Dec 5, 2018 11:13 AM
Because if is going to be that 4:1 ratio using 16luminances black/grays&white then the guy and other choosed things to use PMGs can only be in 2:1 ratio.
#18 MrFish OFFLINE
MrFish
  • 5,474 posts
Posted Wed Dec 5, 2018 11:24 AM
I think it's a fair trade-off, considering you're now bringing in a 16 luminance background.
A 2:1 character looks fitting on a 4:1 background.
Edited by MrFish, Wed Dec 5, 2018 3:01 PM.
#19 Josť Pereira OFFLINE
Josť Pereira
  • 4,251 posts
Posted Wed Dec 5, 2018 11:39 AM
I think it's a fair trade-off, considering your now bringing in a 16 luminance background.
I agree in 101% :grin:
:thumbsup:
#20 MrFish OFFLINE
MrFish
  • 5,474 posts
Posted Wed Dec 5, 2018 12:05 PM
:thumbsup:
Haha...
It would all look different when he's animated anyway.
#21 MrFish OFFLINE
MrFish
  • 5,474 posts
Posted Wed Dec 5, 2018 1:11 PM
Another quick test...
Attached File  Limbo Spider.xex   8.19KB   45 downloads
#22 Yaron Nir OFFLINE
Yaron Nir
    Chopper Commander
  • 204 posts
Posted Wed Dec 5, 2018 3:37 PM
Looks amazing!
#23 emkay OFFLINE
emkay
  • 9,883 posts
  • What's up?
Posted Wed Dec 5, 2018 4:26 PM
Have you ever realized that most of your entries point so something like trolling?
I see, you're a subscriber. I wonder, if you only "subscribe" to get a right for trolling?
Of Course , I'd also like to see a game, using gr. 9 that way. But people want to have that "hires" touch. And this time I'm on that point (given by the Atari's specs) that it is possible to have a well rendition of this game , if PMg is used well, underlaying Antic F.
But you guys only live in your own pre-rolled world, as it seems.
Edited by emkay, Wed Dec 5, 2018 4:27 PM.
#24 flashjazzcat ONLINE
flashjazzcat
  • 14,592 posts
Posted Wed Dec 5, 2018 5:09 PM
Too vague. Some people here who actually write code struggle to see how the requisite number of grey shades are possible in hi-res mode at the required resolution. You assert that it is possible, but haven't managed so much as a mock-up.
#25 MrFish OFFLINE
MrFish
  • 5,474 posts
Posted Wed Dec 5, 2018 5:51 PM
Admittedly the details can be made to look pretty nice in hi-res, and the dither is decent too; but I'm also not
sure about P/M usage here.
So, I'll help you out a little, emkay. Here's a decent playfield screen. Go ahead and add some P/M's to it, if
you like, and see what you can come up with.
[Graph2Font & XEX included]
Attached File  Limbo bw.zip   4.81KB   30 downloads
Edited by MrFish, Wed Dec 5, 2018 5:52 PM.
